Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 General Discussion
Old May 21st, 2017, 08:41 AM   #1
Speedy3
Motorcycle(s): 2008 Triumph Speed Triple (Blazing Orange); 2010 Nina 250r (Race Project)
Idle High, Adjuster All the Way Down
Hello,
Just installed the R77 full exhaust. Sounds so nice! I am noticing that the idle is a bit high ~1700/1800 rpms. First thing I did was check the adjuster, but it isn't even in contact.
I know this bike is EFI, with an ecu and all that. What would be the first order of business to drop this idle?
Speedy3 is offline   Reply With Quote
Old May 21st, 2017, 07:51 PM   #2
Check adjustment of TPS. Is there an idle switch and is it activated at idle/closed-throttle position.
Check cable housing adjuster. Might be too tight and cable is keeping throttle plate open.
Also check throttle boot for leaks after throttle body.
Old May 22nd, 2017, 08:48 AM   #3
Fluidlogic
Fluidlogic's Avatar
Motorcycle(s): 2017 Ninja 300
The 300 has a high-idle mode for warm-up, kinda-sorta like an auto-choke. Does it ever settle down? Mine runs idle around 1.4-1.6 after ten to fifteen minutes of riding, but she can hit 2k+ right at start from cold.
Fluidlogic is offline   Reply With Quote
High idle issue dannyb 1986 - 2007 Ninja 250R Tech Talk 14 July 11th, 2015 06:58 PM
High Idle problems with my first bike stealthyninj 1986 - 2007 Ninja 250R Tech Talk 4 May 8th, 2015 01:14 PM
High Idle RPM (during/after riding) Maielstrom 2008 - 2012 Ninja 250R Tech Talk 6 October 23rd, 2013 07:05 PM
Idle - too high ninja_sleeper 2008 - 2012 Ninja 250R Tech Talk 26 August 30th, 2011 06:11 PM
High Idle RPM... wayanlam 2008 - 2012 Ninja 250R Tech Talk 4 July 20th, 2010 09:59 PM
