Old July 12th, 2020, 07:35 PM   #1
arthury
arthury's Avatar
Motorcycle(s): 2008 Ninja EX250J; 2005 CBR1000RR
Front Brake : went limp (zero resistance)
I completed the rear brake fluid flush without any incident.
But, I goofed with the Front Brake bleeding. Made a mistake and got air in there.
Now, no matter how much I pumped and bleed, although there are still fluid being bled, the brake lever has zero resistance. I don't see any bubbles coming out in the bleeding tube nor do I see any bubbles rising out in the Master cylinder.
Any thoughts on how I can solve this?
I have tied the Brake Lever to see if that helps by tomorrow.
arthury is offline   Reply With Quote
Old July 12th, 2020, 07:50 PM   #2
You're fighting gravity because the bubbles are rising faster in the line than you can pump them down. Trick is to remove caliper and hold it above the master cylinder so that bubbles go only one-way in direction you want, master -->> caliper. Probably need an assistant for this.
Also rotate your bars so master-cylinder reservoir is as level as possible. Keep it filled to very top and don't squeeze more than 3x before refilling.
One thing that really helps is replacing bleeder-screw with Speed Bleeders. Then unscrew Speed Bleeder and attach hose going down to bucket and forget about it. Hold bottle of new fluid in one hand and continually pour to refill reservoir while you repeatedly squeeze lever with other hand. Takes less than 3-minutes from beginning to end to flush new fluid through.
Old July 12th, 2020, 08:06 PM   #3
arthury
arthury's Avatar
Since I was planning to replace the brake hose with the new Galfer Stainless ones, I thought this is a perfect time to do so.
Old hose was removed.
The Galfer one is in place, loosely bolted on both ends.
Master Cylinder is completely empty.
Caliper is attached to the new Galfer line.
Brake pads are also out.
I wonder what is the correct and least problematic way to refill from scratch.
Last futzed with by arthury; July 12th, 2020 at 10:10 PM.
Old July 12th, 2020, 11:27 PM   #4
arthury
arthury's Avatar
Fixed: using the dirty method
Dirty Method:
  • Unscrew Banjo Bolt at caliper end
  • Depress Lever and HOLD (brake fluid should stream out of the bolt crack.
  • Tighten Banjo Bolt
  • Pump Lever a few full strokes normally (no need to be fast)
  • Untighten bleeding valve, bleed and tighten.
I repeated this above steps 3-4 times and each time I re-gain more and more resistance at the Lever until it became normal.
Now, I just need to re-install the caliper and pads back properly.
PS: Along the way, after many Lever pulling, the Brake Light Switch got "healed". Weird. When The new one arrives, I'll replace it.
Last futzed with by arthury; July 13th, 2020 at 07:00 AM.
Old July 13th, 2020, 06:05 PM   #5
Hhahhahaha!!! Was probably corrosion on contacts in brake-lever switch. All that squeezing probably rubbed off corrosion and it worked again!
Good job on clearing out bubbles! Yeah, that's awfully messy. Hopefully brake-fluid didn't get into any critical areas. Only thing I'd worry about is fork-seals.
Old July 13th, 2020, 08:55 PM   #6
arthury
arthury's Avatar
Yup, gave it a good shower.
File Type: jpeg 1C5DE29D-77B6-49F7-A370-F49F55F53124.jpeg (155.8 KB, 5 views)
Clutch handle went limp! BoKing 1986 - 2007 Ninja 250R Tech Talk 9 March 16th, 2015 07:40 AM
Rear Brake Doesn't activate Brake Light And DOT3/4 FRONT BRAKE OIL coelgrim 2008 - 2012 Ninja 250R Tech Talk 16 March 11th, 2013 05:10 PM
Shifting lever completely limp BoKing 1986 - 2007 Ninja 250R Tech Talk 8 January 16th, 2013 11:36 AM
Front tire resistance? 02337 1986 - 2007 Ninja 250R Tech Talk 5 August 31st, 2012 08:05 PM
[crash.net - WSBK] - Haslam leaps over pain barrier to limp onto podium Ninjette Newsbot Motorcycling News 0 September 8th, 2010 03:50 AM
