March 18th, 2013, 08:33 PM | #1 |
Join Date: Mar 2013 Motorcycle(s): 2005 Ninja 250 Posts: 64
Koso RX-1N guage install help
I've been searching the forums for any previous installs but only found skilletmos thread on the newgen. Has anyone out there figured what wires are the correct wire to tap into to? Possibly from a trail tech vapor install.
I have picked up a cluster harness off eBay so I don't have to hack mine and I'm picking up the cluster tomorrow. I've also printed out the wiring diagram to start and plan the install I'm sure eventually ill figure it out myself but if anyone has some input or ideas that would be great, and if I'm the first I'll be sure to post the how to |
March 22nd, 2013, 08:51 PM | #3 |
Skilletmos write up on the gauges install worked perfectly for mine. All the wires matched up the same for my 2005. I will work on a DIY for mounting it.
March 29th, 2013, 01:36 PM | #4 |
Check that, all the wires are correct although I am having trouble with the tach signal. It is very jumpy, has anyone had similar issues? Also if the tach wire is near the speedo sensor wiring it is picking up an irratic speed signal (speed starts jumping around while bike is stationary. I have tried wiring the tach to the original tach feed, wrapping around the plug wire and connecting to the igniter box, all three with a jumpy tach. It also reads 4000-5000 rpm at idle and the bike is simply not idling that high. Although it seems accurate at higher rpm although it still jumps.
May 11th, 2014, 09:28 PM | #5 | |
Did you ever solve the jumpy tach, @UnshavenCanuck? Did you try a 600k .25w resistor like @Chicagobob suggested? |
May 12th, 2014, 10:12 AM | #6 |
Never totally solved it. I'm using a 100k 2w resistor whith ok results. After long rides the tach drops to 500 rpm all the time. Even Koso wasn't very helpful.
DIY: koso gauge install | dyeforever | 2008 - 2012 Ninja 250R Tech Talk | 207 | March 30th, 2017 03:50 PM |
need help with install Koso DL spedometer! | rawbert625 | 2008 - 2012 Ninja 250R Tech Talk | 6 | July 7th, 2012 11:38 PM |
Koso gauge install question | randomwalk101 | 2008 - 2012 Ninja 250R Tech Talk | 6 | February 17th, 2012 01:54 PM |
Koso gauge & gear Indicator install | randomwalk101 | 2008 - 2012 Ninja 250R Tech Talk | 4 | February 20th, 2011 10:32 PM |
For the next person to install a Koso gauge cluster... | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 8 | October 26th, 2010 06:25 AM |
