Old February 3rd, 2013, 02:12 PM   #1
iplante
I ride like a granny
iplante's Avatar
Motorcycle(s): 2003 Ninja 250R - EX250F
Anyone try this "headlight mesh" to 'reshape' their headlight?
I was thinking of trying something like this: http://www.ebay.com/itm/330868146189...84.m1423.l2648
and use it to give my headlight a more "modern" shape. What do you guys think? What I like about it is that light still passes through.
WANTED for 88-07 Ninja 250:
Corbin Gunfighter & Lady seat
iplante is offline   Reply With Quote
Old February 3rd, 2013, 02:51 PM   #2
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
Doesn't look to me like it reshaped anything, just merely a way to make it blend into bike's color. Headlight tinting if you will, and not that great looking in any of those example pics in link.
Old February 3rd, 2013, 02:54 PM   #3
Reyno2ac
Reyno2ac's Avatar
Motorcycle(s): Red 2009 Ninja 650r
It looks like you're dressing you bike up in lace...
Reyno2ac is offline   Reply With Quote
Old February 4th, 2013, 09:31 AM   #4
I have the Lockhart-Philips green headlight mesh that I will be putting on a pregen, but I have a slightly different idea. I overlaid the J/K "newgen" and F "pregen" headlights and traced the outline of both. I then bought a fairing that covers the headlight completely, which I will paint black and blend with the windscreen (also painted black).
I will overlay my trace on the fairing and cut out the area that the two light designs share, which will result in a funny shape-BUT I'M NOT DONE! I will then use green paint, vinyl, or headlight mesh to extend the shape beyond the cutout so that the green area completes the shape of the J-bike's headlight. Of course, that will still look weird if the cut-out is not also green to blend, so that's where the headlight mesh comes in to play. I have seen clear green tint that I may combine with the mesh to make it more consistent.
I have another fairing with no headlight hole that I plan to actually mount a J-bike's headlight in, but it is cracked so I intend to hide the crack with the same mesh. I'm going to use green vinyl or more mesh to make a false windscreen shape after I blend the old windscreen.
Wrong mindset. You use shaped cuts to continue the color of the fairing and leave your custom shape UNcovered. The illusion is blown during riding, but you are blinded by the light at that point. For example, one thing that exacerbates the blocky-shaped headlight is the straight line formed from where the windscreen meets it with no fairing in between. On a green bike, a bit of green across the top solves that. With a clever shape you can also add a curve to the headlight.
Old February 4th, 2013, 10:52 AM   #5
iplante
iplante's Avatar
My bike will soon be VW Fahrenheit orange to match my car.
I have two options:
1. Buy BLACK mesh and cut a better shape
2. Buy WHITE mesh and spray paint it orange (more $$$, since I have to buy the rattle can of that color)
I'm not sure which would look better.
Old February 4th, 2013, 10:58 AM   #6
I have two options:
Third option: Buy GREEN and match the fairings.
Anyway, headlights get hot and the automotive paint may not hold up. Also, applying after painting may not work so well as the paint probably isn't meant to be flexible.
Good luck!
Old February 4th, 2013, 11:03 AM   #7
iplante
iplante's Avatar
Good luck!
Ha! But I want my bike to be orange like my car!
Thanks for the tip about the flexibility. I didn't think of that. I'm not sure what I'm gonna do now
Old February 4th, 2013, 01:32 PM   #8
Hmm. You could get an orange mesh as close to the VW orange as you can then get a pint of paint computer-matched to the mesh. Mix that with your VW paint to get an "in between" color that you paint your upper fairing with. Paint the rest with the straight VW orange color. Next, make a fade into the headlight area orange using the spray you already planned to get. The expense and effort are ratcheting up, but the orange mesh will no longer stick out and the overall bike will seem to match the car.
Yeah, I'd probably try spraying the mesh first.
Old February 9th, 2013, 05:12 PM   #9
This would look better. Leave it square
http://www.ninjette.org/forums/showthread.php?t=119789
Old February 9th, 2013, 07:06 PM   #10
iplante
iplante's Avatar
Ha!
Maybe I'll try it one of these days. I'm just a bit poor right now
Pregen with a 7" headlight azaizai 1986 - 2007 Ninja 250R Farkles 4 March 13th, 2015 12:36 PM
Can you easily clean up the square headlight? Reflective stickers to "reshape" it? CZroe 1986 - 2007 Ninja 250R Farkles 26 June 9th, 2014 02:47 PM
Replacing the undertail with colored hexagonal mesh. Can I "curve" like a wheel well? CZroe 1986 - 2007 Ninja 250R Farkles 6 June 26th, 2012 09:15 AM
