Old February 2nd, 2014, 09:47 PM   #1
TS250
Motorcycle(s): 2008 NINJA 250, BLACK, 650 NINJA 2009, RED, F 650GS BMW 2012 YELLOW
Idle issue 2008 250
I have a 250 08 ninja, the idle is good when not giving it gas. But once you give it gas and it returns to normal idle it take about3-4 seconds to idle normally(2500 t0 3000 rpms) It does it every time even when fully warmed up. It goes to 1500 and slowly goes to normal. Anyone has the same issue? Is it just the carburated model or does it need some adjustment? Thanks for any input.
TS250 is offline   Reply With Quote
Old February 2nd, 2014, 09:54 PM   #2
corksil
Motorcycle(s): A lot.
Idle mixture screws.
Sounds like it's a little lean at idle.
There are two idle mixture screws hidden under caps that must be drilled out. I recommend you google "mixture screw ninja 250r"
---- That should pull up the exact link to the ninja faq with detailed instructions.
However it may be smart to wait for a second opinion before taking power tools to your carbs.
Old February 3rd, 2014, 06:34 AM   #3
mgentz
Board Member
jetting or vacuum leak.
Old February 3rd, 2014, 07:05 AM   #4
DaBlue1
DaBlue1's Avatar
Originally Posted by TS250 View Post
.... But once you give it gas and it returns to normal idle it take about3-4 seconds to idle normally(2500 t0 3000 rpms)
2500-3000 rpms is not normal idle speed. 1300 +/- 50 rpms is normal for a fully warmed bike. If your idle speed is up to 2500, something is wrong.
Any modifications to your bike? (i.e. carbs work, exhaust , etc...)
Does the bike run OK at 1500 rpms?
Have you tried adjusting the idle speed?
Old February 3rd, 2014, 09:26 AM   #5
broilmebk
broilmebk's Avatar
Motorcycle(s): '12 ninja 250r
Yea, it's a little confusing when OP is saying 'normal idle' is 2500-3000.
So it is at 1500 and then slowly goes to 'normal'?? 1500 is already above the real normal. Is your choke on?
broilmebk is offline   Reply With Quote
Old February 3rd, 2014, 03:44 PM   #6
TS250
Both the ninjas I have call for idle to be 2500 to 3000. I could be wrong.
Old February 3rd, 2014, 04:08 PM   #7
broilmebk
broilmebk's Avatar
Where did you get that from?
Attached is from the service manual for 08+ 250s
Old February 3rd, 2014, 06:31 PM   #8
mgentz
Board Member
1300 is ideal.
Old February 7th, 2014, 09:50 PM   #9
TS250
Yes you are right I miss read the numbers for both.
Idle issue djjontran 1986 - 2007 Ninja 250R Tech Talk 27 August 18th, 2013 09:00 AM
idle issue PEN25 1986 - 2007 Ninja 250R Tech Talk 10 June 30th, 2013 02:14 PM
