March 10th, 2014, 01:29 PM | #1 |
Join Date: Mar 2013 Motorcycle(s): 1998 Ninja 250 red Posts: 5
15t front sprocket loose
Hi I need to know if it's normal for the front sprocket with the 2 bolts tightened to have a little side to side play in it. I put a new 15t jt sprocket on and the splines on the shaft are fine, but with the 2 bolts tightened over the sprocket washer it still can move a little. Thanks
March 10th, 2014, 01:38 PM | #2 |
Join Date: Sep 2012 Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B Posts: 315
It's normal. It's a "floating sprocket" design that reduces chain stress and wear.
See http://faq.ninja250.org/wiki/My_fron..._%22wobbles%22 for details. |
March 10th, 2014, 02:07 PM | #3 |
Thanks! For the info and the link
Suggestions for a 15T front sprocket? | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 7 | June 21st, 2013 03:31 PM |
15t front sprocket swap! | play2pwn | 2008 - 2012 Ninja 250R Tech Talk | 3 | October 17th, 2011 09:17 AM |
15t jt front sprocket and now noise? | greatwhiteninja | 2008 - 2012 Ninja 250R Tech Talk | 25 | August 30th, 2011 08:34 PM |
15t front sprocket top speed | greatwhiteninja | 2008 - 2012 Ninja 250R Tech Talk | 13 | June 21st, 2011 02:03 PM |
15T Front sprocket is greeaaatt! | Hokie11 | 2008 - 2012 Ninja 250R Tech Talk | 16 | September 1st, 2009 03:47 PM |
