November 12th, 2009, 12:42 PM | #1 |
Join Date: Nov 2009 Motorcycle(s): 1990 Ninjette 250 Posts: 32
Help me pick out a rear shock...
Well I've been having a ton of fun on my little ninjette, but its time for a new rear shock.
Why? Several reasons. Primarily I want adjustability and and re-buildability. I don't like that the stocker is neither. What I want the new one to be able to handle: -aprox stock ride height, pref adjustable -adjustable pre-load (adjustable damping is a plus) -not too harsh for my scrawny (120lb) butt. -able to easily handle two-up riding without bottoming out all the time... i bottom the stock thing out several times every ride when two up! With that in mind I went looking through the wikis and forums, and found a bunch of options... now I'm trying to decide which would work best for me. Its largely a commuter bike but I do love to get into the twistiest on the parkway etc. I've looked at: 1) new-gen shock. has adjustable pre-load, but thats it. not re-buildable? 2) ex500 shock, seems to have about the same pros as #1 3) zx600 shock, re-buildable, adjustable, relatively easy install. Cons: more pricey than 1 or 2 and all of them are older (pre 97?) 4) zx6r shock, 3-way adjustable. Not sure if re-buildable. Harder to install, but thats not a big deal. Newer and cheaper than #3 I'm leaning towards #4. Anyone have any input? |
November 12th, 2009, 02:12 PM | #2 |
what's your budget?
November 12th, 2009, 02:21 PM | #3 |
Cheap is good.
Since you can get zx6r shocks that are only a few years old for <$50, unless something out there drastically out-performs them for not terribly much more I'd say about $50 or so is what I'm looking to spend. |
November 12th, 2009, 04:49 PM | #4 |
Although it is not rebuildable several members here have installed the new gen shock with very good results.
November 13th, 2009, 09:48 AM | #5 |
I like my Hagon shock....
It's from England.
Very good quality, adjustability, really makes the bike responsive (assuming you've upgraded the front suspension also). It's not a racing shock (no remote reservior - emulsion type, but I'm not a track racer so I don't care). Here's a listing that includes the Hagon along with a few other possibilities, http://faq.ninja250.org/wiki/Aftermarket_Shocks In my opinion, for everything short of multi-lap track racing, you can't go wrong with the Hagon. Although, it seems that a lot of the EX-250 world is (rather myopically) centered around low-budget solutions (the lower the cost, the longer the install write-up will be about how cheaply the mod was done). I forget that fact sometimes and post something like this only to get lectured on how expensive it is. But I do hang around to read the later posts where the really-cheap EBay ZX-600 shock starts leaking oil like an early 1960's British car. |
November 13th, 2009, 02:55 PM | #6 |
Join Date: Apr 2009 Motorcycle(s): 2000 Honda CBR600F4 (sold) 1999 Ninja 250 (sold) Posts: 586
The new gen shock is plenty for me.. why do you need rebuildable? Are you going to keep the bike for 15 years? Why do you need so much adjuability? The F chassis doesnt lend itself to 'getting in there to adjust' anyway..
Here is my experience with the J shock. http://www.ninjette.org/forums/showthread.php?t=17382
2000 Honda CBR600F4 Silver and Red 1999 Kawi Racing Green Ninja 250 sold |
November 13th, 2009, 03:22 PM | #7 |
Greg - the hagon looks nice, as do most of the other aftermarket shocks, but when sufficiently good shocks are available for < $50 its hard to spend $400+!
Adam - do I need rebuildable? no. But it would be nice to at least be able to change the oil. I plan on keeping the bike for a while... it may be my first bike, but I've had my first car for the past 6 years and have yet to 'upgrade' as so many people call it. Furthermore I am a tinkerer. When I put coilovers, bigger brakes, swaybars, poly mounts, swap motors, etc on my '91 ford festiva (which to most people is just a crap car) did I need it? no, but I have fun with it. I have a welder, grinder, drill press, etc. so installing a zx6r shock isn't a big deal. If I can get one of those for the same price as a J speck shock, and have the advantage of re-buildability and further adjustability, why not? I may never actually see the benefits of the additional goodies. But before I go and spend my $50 on a new shock I just want to try to find the best of the options. With the air-adjustable dampening on the zx6r or gsxr shocks I could ride with a relatively low spring rate when one up and not much air pressure then when ridding double up I could bump the dampening by putting in 5-10psi. Maybe this isn't necessary... but then again, thats why I'm asking! Thanks for the input so far guys! After I get something done with the rear I'm going to install ex500 springs in the front... I can't stand the nose dive every time I stop!! |
November 15th, 2009, 07:37 PM | #8 |
Join Date: Jun 2009 Motorcycle(s): Ninja 250 x2, Ninja 650R Posts: 165
I'm using an '08 'J' shock on my '05 250. The pre-load is nice to adjust between 2-3 depending on the amount of gear I'm carrying. I previously have a re-built Fox twin clicker with remote reservoir. I decided it was overkill for me, as I'm only doing about one track day a year right now. Plus, the $$$ selling it bought me some Givi luggage...
November 24th, 2009, 12:58 PM | #9 |
Join Date: Nov 2009 Motorcycle(s): 2006 Ninja 250R Posts: 2
EX500 Shock
Part of the issue with shock changes is what do you want from your ride. My 2006 has a 2004 EX500 shock which give me an almost perfect highway ride and works well in the twisties. (No canyons in E. Nebr.) You should also ask yourself what you plan to do with the front end. I found that I needed to change out fork springs after the mod. I'm using .70kg Sonic Springs. I little more firm than I would like but the EX500 springs would have been too soft.
November 24th, 2009, 02:08 PM | #10 |
The ice cream man
Join Date: Nov 2009 Motorcycle(s): 07 Aprilia RSV 1000R, 07 suzuki GSX-R600, 06 Kawasaki Ninja 250R Posts: 6
I changed the rear shock to a 07 GSX-R600, it was pretty simple to do especially if you have a file and a drill. I also changed the front spring with racetec .80 springs and emulators, that took care of the nose dives when stopping and more manageable on the track
November 24th, 2009, 02:50 PM | #11 |
I'm planing on using the 500 springs in the front and perhaps emulators as well... I haven't decided whether or not the emulators are going to be worth the $.
Since I'm such a lightweight I don't think I really need a much stiffer spring in the rear, as long as I can adjust the preload for when riding 2-up and get better damping. I wouldn't mind a little stiffer spring, but most of what I'm seeing as far as spring rates is in the 500+ range (stock 250 is 440lbs from what I understand). Maybe a 500lb spring wouldn't be that bad, but I don't want it to be too bouncy given some of the roads I have to ride.
Nate '90 Ninja 250, 12k miles |
November 24th, 2009, 03:04 PM | #12 |
up the front fork spring rate with a couple of steel washers to preload the stock springs. cheap and effective.
on my dirt bikes, I've been pouring in an additional 1oz of one step heavier fork oil and preloading the springs with steel washers from Home Depot. I think 1 1/8" washers will work in our ninja forks. If not, the 1", for sure. |
January 17th, 2010, 11:24 AM | #13 | ||
Da Duckman
Join Date: Nov 2008 Motorcycle(s): '08 250R, '06 Chopper, '80 Puch Magnum II, '01 SV650, '99 CR250/CR500AF Sportbike. '02 CRF450/CR500AF Dirt Posts: 480
http://www.ninjette.org/forums/showthread.php?t=36055 Its a relatively cheap configuration but takes some work to install: The shock was a parts bin special.. something I already had, I think I put about $15 into new bolts washers and spacers. |
January 17th, 2010, 11:58 AM | #14 |
I've got one in the garage now, its actually from an 09 R6 that had 2k miles on it.
picked it up on e-bay for around $30. I'm considering putting the stock spring on it since according to the calculators its about right for my weight, and then using the pre-load adjustment for when riding 2-up. Most of the time me and my riding partners weight is around 250lbs combined... were small people The little bike definitely likes small folks... a friend of mine w/ a 250 honda and I were riding and I flew past him @ 70mph... he weighs quite a bit more than I do, and it makes all the difference!
January 17th, 2010, 03:55 PM | #15 |
Da Duckman
January 17th, 2010, 10:11 PM | #16 |
From what I've read online its 295mm... but i haven't measured it myself yet. I'll do a detailed writeup w/ pics etc. once i get it done, hopefully in the next week or two. If 295mm is too short (Stock is 320 I believe, so that puts it at 25mm shorter than stock) I'll have to look into other options.
This is the shock I have: As you can see the reservoir sits lower than on most, and I'm hoping this will make installation a little easier. We'll see, but thats one of the main reasons I picked this shock to try!
January 18th, 2010, 02:57 PM | #17 | |
Da Duckman
The R6 always had a short shock, I didn't realise the new R6ers had a forked bottom though. While that shock may be a little short, you might be able to redrill those shorter links that came with it and use them to raise up the rear of the 250 after the R6 shock has dropped it. Give it a shot! |
January 26th, 2010, 03:33 PM | #18 |
R&T Suspension
Join Date: Jun 2009 Motorcycle(s): Too many to list Posts: 175
You need at least the same length of shock, preferably 5-10mm or more length. Adjustable ride height would be best. for racing
January 26th, 2010, 09:09 PM | #19 | |
Join Date: May 2009 Motorcycle(s): '98 EX250, '02 EX250, '08 250r, '03 SV650, '98 GSXR750 '03 Hayabusa, '87 YSR50, '84 ZX900, +MORE Posts: A lot.
I run +9mm of ride height in my bikes. My Penske shock is ride height adjustable. My old Fox shocks don't have the height adjustment so I shorten the dogbones. The new gen shock is a good cheap replacement on the old bikes because it is 5mm longer and gets you close to the proper height. I've heard that with a little grinding a shock from a 1979 Gold Wing will fit, you could give that a try.
CraigHarris.org Pacific Track Time CraigsWeb See you at 2014 MotoGP Laguna Seca! We'll be camping on Fox Hill. AFM #278 |
February 19th, 2010, 11:46 PM | #20 |
Join Date: Feb 2009 Motorcycle(s): '91 Honda CBR600 F2 Posts: A lot.
Has anybody besides me heard anything about the SV650 shock on a pregen?
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail. |
February 23rd, 2010, 01:50 PM | #21 |
Livin' the Minimoto Life
Join Date: Mar 2009 Motorcycle(s): 2022 Honda Navi, 2018 Z-125 Pro Posts: A lot.
I have seen it done before. I just cannot remember where I saw it.
--- My IG Page --- My FB page! --- 2022 Honda Navi && 2018 Z-125 Pro |
February 23rd, 2010, 11:41 PM | #22 |
Do you remember if it required modification to the shock itself? I'm looking for something that is a direct, bolt-on replacement that might be easier to find than a newgen shock.
February 24th, 2010, 12:49 AM | #23 |
Join Date: Sep 2009 Motorcycle(s): Ninja 250 F17 Posts: 73
There was a write up on ninja250.org that got taken down. If I remember right, it was a hack and slash on the plastics and some removing some material on either the clevis or ball joint.
'03 w/ full muzzy exhaust - Racetech .80 springs/emulators - Galfer SS Lines - EBC HH pads - Uni 6" Dual Stage Pods - 110 Dynojet jets - Uni crankcase breather - EX500 adjustable levers |
March 3rd, 2010, 03:45 AM | #24 |
Join Date: Feb 2010 Motorcycle(s): 2009 Ninja 250 2016 Ninja 300 1994 KTM 300 EXC Posts: 123
I have done a lot of reading on the sv650 the 2nd gen 2003+ will fit better then the 1st gen. From what I read the 2nd gen you don't have to do any grinding or anything. You do have to drill out the race bushing area at the top to put the old one back in. For the bottom part you have to drill the hole a little bigger since they are so close in size you can't just drill a new hole up farther. As for the rear suspension I would also get new front springs to get rid of the dive when putting on the front breaks quickly when needed. I can dig up some links if you want them.
Rear shock set to high (rear wheel slipping)? | passive101 | 2008 - 2012 Ninja 250R Tech Talk | 6 | August 10th, 2014 08:45 PM |
Help me pick my next rear tire. | kyrider | 1986 - 2007 Ninja 250R Tech Talk | 17 | March 5th, 2012 09:05 AM |
For sale: 2003 ninja 250 rear brake pedal and rear shock | ReDnEcK | Motorcycle-related | 0 | October 6th, 2010 12:02 PM |
Replacing my rear shock with a newgen rear shock... | ReDnEcK | 2008 - 2012 Ninja 250R Tech Talk | 4 | September 10th, 2010 12:38 PM |
Pick my rear sets for me | ztrack157 | 2008 - 2012 Ninja 250R Farkles | 24 | November 20th, 2009 09:10 PM |
