Old April 19th, 2012, 11:07 AM   #1
$5 custom earplugs
radians custom plugs on sale for $5 each. i got 3 pairs, screwed up the first pair but the second pair i did right... these things are amazing. you cant feel them when they are in but they work just as well as uncomfortable foam disposables. they feel more rubbery then foam like the cheap earplugs. if you get them, make sure you mix the stuff vigorously for a solid 2 minutes. dont under mix it or it wont cure right and it will be a waste. i mixed both plugs at once so i didnt screw up the ratios instead of breaking the 2 parts into halves and mixing seperately... just mixed it up, crammed them in my ears and went to sleep. woke up a few hours later with perfect earplugs
http://www.cabelas.com/product/Hunti...3Bcat104381280
Old April 19th, 2012, 11:08 AM   #2
I might try those out. Can I clean them or is warm water going to cause problems? I have a lot of ear-wax.
Old April 19th, 2012, 11:11 AM   #3
its silicone. you can clean them.
Old April 19th, 2012, 11:12 AM   #4
but at $5, you might as well just order some extra pairs and replace them every now and then... you know when they turn from blue to that nice yellow orange color of your ear wax.
Old April 19th, 2012, 11:16 AM   #5
haha yeah i might order a pair or 2. Hell, I think I'll just stop at a cabelas when I'm home.
until then, I'll continue using the ones I have now.
I pulled out the string and cut off the smallest lobe on the end because it poked too far into my ear and hurt. Now they're comfy as hell
Old April 19th, 2012, 11:26 AM   #6
jjb84
Motorcycle(s): 2009 Ninja 250
tempted to try these. are they really much more comfortable compared to regular earplugs?
jjb84 is offline   Reply With Quote
Old April 19th, 2012, 11:29 AM   #7
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Crap, wallet is all the way across the room, guess I won't be ordering these
AFM #676
Supersports are for n00bs
Old April 19th, 2012, 11:33 AM   #8
xSean13
xSean13's Avatar
Yeah, I got like 30 pairs of yellow foam earplugs on ebay for $3...just chuck them out when they get gross :P
Last futzed with by xSean13; April 19th, 2012 at 11:33 AM. Reason: price edit :P
Old April 19th, 2012, 12:46 PM   #9
Liist
Liist's Avatar
I used to use those custom-fit earplugs. They worked really well for shooting.
Now I use Surefire earplugs. Very comfortable and work even better than the custom molded ones.
Liist is offline   Reply With Quote
Old April 19th, 2012, 01:17 PM   #10
yes. if you do it right, you cant feel them in your ear
Old April 19th, 2012, 01:19 PM   #11
i used to use those. they were pretty good. not as good as the molded ones tho
What earplugs do you use? asdfman Motorcycle Gear 14 March 16th, 2015 05:20 AM
[visordown.com] - Used: Hearwave B2 custom earplugs review Ninjette Newsbot Motorcycling News 0 September 11th, 2013 02:30 PM
[visordown.com] - New: Hearwave B2 custom earplugs Ninjette Newsbot Motorcycling News 0 April 3rd, 2013 09:50 AM
custom earplugs??? alex.s Motorcycle Gear 12 February 15th, 2012 06:10 PM
FS: Used earplugs alex.s Gear-related 34 October 27th, 2011 09:33 PM
