Old October 19th, 2013, 01:21 PM   #1
Maielstrom
Ghost Rider
Maielstrom's Avatar
High Idle RPM (during/after riding)
Hey everyone,
I noticed in the past 2 months (approximate), that my Ninja will idle correctly at start up, but after riding around and coming to a stop (stoplight or done riding), the idle RPM will be a good amount higher. The starting RPM is around 1300 as per the manual, and it is averaging around 2000 at stop lights, but fluctuates up to a peak of 2500. Does anyone happen to have any idea what I could look into about this or why this is happening?
Thanks!
Maielstrom is offline   Reply With Quote
Old October 19th, 2013, 03:01 PM   #2
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
I'm assuming you set the idle while the bike was already warmed up with the idle knob?
If so and it's still doing that, is your throttle sticking? Like when it's at 2500 rpm and you manually push the throttle closed more?
Old October 19th, 2013, 03:11 PM   #3
Maielstrom
Ghost Rider
Maielstrom's Avatar
Thanks for the reply.
I've had the bike for a year (it's a 2012), and never adjusted the idle from when I obtained it, as I never had this issue before, even last Winter. Possibly I should let it idle for a while and see if it happens without riding? Recalling from memory (bit of a fuzzy memory), I believe I've allowed it to idle for 10 minutes before going out, and it still starts off idling at ~1300, then increases after I've ridden.
I considered it could be the throttle sticking, but it appears to be fine, and that it returns to the normal position when I'm off the throttle. Perhaps I can see about adjusting it too.
Old October 19th, 2013, 04:39 PM   #4
DaBlue1
DaBlue1's Avatar
Your engine idle speed should be 1350 +/- 50 rpms. The engine should be completely warmed when it is adjusted.
2000-3000 rpms is a common idle speed range for when the choke is on. They key is reducing the amount of choke (small increments) during the warm up until the bike can maintain a steady set idle speed on it's own. It is also acceptable to ride off with the choke on a short distance until the bike is warmed.
It is also common for the idle speed to change due to varying season (cold-hot) changes, so small idle adjustments may be necessary.
Old October 19th, 2013, 05:58 PM   #5
Maielstrom
Ghost Rider
Maielstrom's Avatar
Thanks for the info and tips on idling! I was thinking the temperature could have an effect on it (North East, we're getting cold up here) Next time I go out, I'll look into it and see about the adjustment.
I appreciate all the help!
Old October 19th, 2013, 06:01 PM   #6
Originally Posted by Maielstrom View Post
Hey everyone,
Thanks!
As noted, the full-hot idle speed should be 1300. The cold speed is determined by the amount of choke.
After riding for 30 minutes or so, set the idle to 1300.
Before doing that, you could try turning the throttle backward firmly to see if it will drop the RPMs, which would tell you something is hanging-up and not allowing the butterflies to close properly.
A couple other things that could effect idle speed is idle mixture and carb sync. A vacuum leak will also cause the RPMs to rise and "hang" when you close the throttle.
I wouldn't let it idle for 10 minutes to warm up. 3 or 4 minutes is enough to start riding if you set the RPMs around 2000 and back the choke off as soon as possible. It will warm-up a lot faster when riding normally than it will idling.
Old October 23rd, 2013, 07:05 PM   #7
JAG
Motorcycle(s): 2010 Kawasaki Ninja 250
2010 Ninja has same problem
After long ride on freeway idle goes high at stop light. I may have narrowed the problem to my
Clogged air filter not sure. The throttle has two cables one may be loose etc. Although it might be the throttle is adjusted higher than normal. It's better than it was. It usually does when very hot outside. I keep some throttle when cold instead of adjusting idle. I did add water to the antifreeze to level the coolant maybe changed the operating temp. Hope you solve your idle problem.
JAG is offline   Reply With Quote
2006 Ninja 250 High Idle RPM GunnaBoyEB 1986 - 2007 Ninja 250R Tech Talk 4 September 4th, 2014 10:30 AM
Just cleaned carbs - now stuttering at low RPM, fine at high RPM Ohio 2008 - 2012 Ninja 250R Tech Talk 20 August 5th, 2014 10:30 PM
High handle bar vibration, hard to get into high RPM, is this normal? jackliu239 1986 - 2007 Ninja 250R Tech Talk 24 September 19th, 2013 09:04 PM
Idle jumps to 9000 rpm on choke then wont stay idle after off Shawn250 2008 - 2012 Ninja 250R Tech Talk 1 June 19th, 2012 06:45 AM
High Idle RPM... wayanlam 2008 - 2012 Ninja 250R Tech Talk 4 July 20th, 2010 09:59 PM
