Old May 26th, 2015, 02:12 PM   #121
micoulisninja
modaholic junkie
Originally Posted by bruce71198 View Post
Glad you didn't disappear with this project.
I'm eager to see what went wrong with your big bore kit.
I acquired one to do some work with and after machining and modifying the piston decided to avoid the obvious impending failure and not assemble it.
Now I'm researching piston availability from another source to see if I can make this happen.
is yours a 66mm bore ?
cause if it is, the 98-99 zx6 pistons will work fine, I have built a 250 with those ones and has over 10k miles already...piston pins are identical to 250's....
Old May 26th, 2015, 03:56 PM   #122
bruce71198
bruce71198's Avatar
I have a 67mm bore. Is 66mm the stock or overbore size?
Old May 26th, 2015, 04:56 PM   #123
micoulisninja
modaholic junkie
66mm is stock for 98-99 zx-6r
68mm is stock for 03-06 zx-6r (636)
67mm is stock 07-08
and FORGED oem 09-12 (which I intend to use myself) and on
pins change a bit but not the OD, just the width... will give more data as long as i have them at hand...
Old May 26th, 2015, 06:18 PM   #124
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Hey Nick,
that's nice to see you're back again, I'm very curious about your results
Old June 9th, 2015, 03:24 AM   #125
redkid
Motorcycle(s): ninja 250r
67mm is stock 07-08
so for conclusion, which pin works best with our standard piston?
redkid is offline   Reply With Quote
Old June 9th, 2015, 04:16 AM   #126
micoulisninja
modaholic junkie
I do not recall mentioning any advice of mine switching piston pins if using stock pistons... you MUST use stock pins with stock pistons...
pin choice is a matter of piston choice, not the opposite...
the info I post is reference only and a writing of my engine build. It does not apply to stock engines... even if using aftermarket pistons (JE, Wiseco etc) they either come with a pin especially designed for them or they recommend use of the stock pin...
all of the pistons mentioned above are ZX-6R pistons, not 250's... but they COULD be used in overbore projects IF someone makes extravagant choices for his own engine and has knowledge of the modifications and measurements that will be necessary to make them work...
@bruce 71198 all YOU need to make it operate reliably are the 300's shorter stock rods and some well measured clearances...
Old June 9th, 2015, 04:55 AM   #127
red26
Motorcycle(s): Ninja 250R, GSXR600 K4, KX250F,NSR150SP, Yamaha TZM150
My wiseco were a bit thicker than what you got, so i thought of using a lighter one from another bike. Or maybe skimmed one so it can match the size of stock pin thickness. Is that possible?
red26 is offline   Reply With Quote
Old June 9th, 2015, 03:21 PM   #128
micoulisninja
modaholic junkie
like I said, piston weight, design and rest of characteristics decide piston pin thickness, size and weight... you can try using another pin BUT keep a few things in mind...
the pin must not have play within the piston "casing" horizontally... I do not know how wide the wiseco pin is, if the stock pin fits properly and is lighter you could use that... earlier ZX-6R generations use same pin as 250... the 300 pin is lighter but also narrower, so you cannot use that if your pins almost as wide as stock...
one thing you could do to lighten wiseco pins (if possible and of totally cylindrical shape with same I.D. from one end to the other) is to imitate the stock 250 pins' chamfering, taking off a few grams from each one but be careful not to overdo it... I would not recommend lightening stock 250
pins though... they are shaped and lightened from factory to a spec that would not be safe playing with... if you gave me precise dimensions along with some pics I believe I could give you more detailed advice...
Old June 9th, 2015, 07:02 PM   #129
redkid
Thanks, i have been considering chamfering the pin by looking at your mods. Last night i measured both pins last night and this was my finding.
Wiseco 47g each
2013 stock Ninja 250 FI 35g each
I am definitely going to use the stock pin
Old June 10th, 2015, 01:51 AM   #130
micoulisninja
modaholic junkie
Wiseco 47g each
12g more for Wiseco ??
well switching to stock pin will help it rev more freely and stretch rods less, so go ahead if they are same size !
Old June 16th, 2015, 04:07 AM   #131
redkid
the stock pin is from 2014 Ninja 250, the one with the same looks as Ninja 300. I know Ninja300 have revised piston and pins, so it may not be the same like our 2011 Fi models
i have another question, yesterday as i clean up my cylinder head its hard to turn the camshaft even no chain connected and bucket & shims removed. When i remove the dowel pins for the camshaft cover, it spins easier.i can even spin it using finger.
Can i just remove the dowel, and just install the camshaft cover? this lighten up the camshaft assy
Old June 16th, 2015, 02:18 PM   #132
cuong-nutz
cuong-nutz's Avatar
Yeah, the Wiseco pins are heavy. I am not sure what the thought process was behind it. You need those dowels in place.
HalfFast Racing Team
Old June 16th, 2015, 04:37 PM   #133
micoulisninja
modaholic junkie
Old June 17th, 2015, 03:40 PM   #134
Riverdale
Motorcycle(s): 2009 250r. 1983 BMW r100rt
X2
Riverdale is offline   Reply With Quote
Old November 24th, 2015, 02:55 AM   #135
Somchai
Freedom for Germany
Hi Nick,
long time's gone so let me please ask for some news?
Old December 7th, 2015, 01:55 AM   #136
micoulisninja
modaholic junkie
Originally Posted by Somchai View Post
Hi Nick,
ready for the final straight at last Roland !! will give you a little teaser...
2009 ZX-6R pistons, pins, conrods in place of the stock lineup... now checking out some details about the head and squish distance...
Old December 7th, 2015, 02:45 AM   #137
Somchai
Freedom for Germany
Wow Nick, this is a fantastic message.
I wish you great success
Old November 8th, 2016, 03:37 PM   #138
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
Excellent build, top banana, well done that man
I'm doing a 282cc version, using zx6r pistons as per one of your threads I was reading.
Too achieve the 66mm bore, I used a couple of ZZR600 (64mm bore) liners, that I had custum fitted to a spare 250 block. I will lighten the ZX pistons to the same weight as the 250 ones thus avoiding any balance or strain issues.
Just finishing up some other work first to get the bike through annual inspection. Then when the weather gets really crap I'll rebuild it in 282cc guise.
Last futzed with by Mohawk; November 20th, 2016 at 04:23 PM.
Old November 20th, 2016, 04:26 PM   #139
Mohawk
Mohawk's Avatar
So I've been working on ligthening a piston today, got it down from 141.8grams bare to 132.6grams which is still about 10 grams heavier than the stock 250 pistons. Not sure I can take much moer out of it. Problem with alloy is it takes up a lot of space for a gram or two
Last futzed with by Mohawk; November 21st, 2016 at 03:11 AM.
Old November 29th, 2016, 04:23 PM   #140
bruce71198
bruce71198's Avatar
Where do you get ZZR600 liners? Pictures?
Old November 30th, 2016, 01:27 AM   #141
Mohawk
Mohawk's Avatar
I just bought a second hand ZZR600 block. It had one damaged bore, so was scrap, so cost peanuts. Had 2 liners pressed out, then fitted to 250 block, then had the 64mm bore taken out to 66mm to suit the ZX6R pistons, that came with another secondhand block.
If you do this with a buddy you can share the parts ! Hardest part is getting a shop to machine the 250 block & fit the new liners. Having done this, I advise turning the bottom of the ZZR liner down to fit a stock base gasket. I need to open the liner holes just a little on mine.
You can buy a cometic head gasket for either old or new gen, with 64 or 66mm bore, but I'll just grind a stock one to size.
The stock bore has the valves slightly offset in the bore, thus intake and exhaust valves have a very close tolerance to the cylinder wall, effectively masking part of the valve. The big bore should flow better than stock due to unmasking these areas & inducing a larger pressure reduction induction pulse due to the increased displacement.
Looks like 130 grams will be as light as I can get the pistons, so may have to limit the maximum RPM a bit. Need to run some numbers to work out maximum load on the rods.
Old November 30th, 2016, 11:51 AM   #142
bruce71198
bruce71198's Avatar
We don't have a ZZR in the States, is this the equivalent of the ZX6? What year?
Old December 1st, 2016, 01:08 AM   #143
Mohawk
Mohawk's Avatar
Well you do have the ZZR600, but for some reason Kawasaki USA sold it as the ZX6 in the USA, where as the rest of the world had two bikes, the ZX6D or E, see here https://en.m.wikipedia.org/wiki/Kawasaki_ZZR600 1990-2008
Where as to everywhere else the ZX6R was introduced in 1995-to present, see here
https://en.m.wikipedia.org/wiki/Kawasaki_Ninja_ZX-6R
Old December 1st, 2016, 04:21 PM   #144
bruce71198
bruce71198's Avatar
I think I found the pieces I need. The ZX6 up to 2004 uses the press in liners like the 250, 2005 and up has the nikasil aluminum cylinder blocks.
Old December 6th, 2016, 05:37 AM   #145
Mohawk
Mohawk's Avatar
Hey Micoulisninja, how goes the bike a year down the line ?
Old May 25th, 2018, 03:29 PM   #146
Mohawk
Mohawk's Avatar
Well having done everything else to the bike I never got round to fitting the big bore. But I,m back on the wagon & just been finishing the pistons, now down to 130.3grams which is as light as they can be. I’ve reduced them to slipper pistons by cutting off & smoothing the the anti can’t extensions fore & aft. If anyone’s interested they weigh 2,5grams combined.
So I need to get round to stripping the engine next. Hope to get this done over the next few weeks.
More when I have it.
Holy Demo Day, Batman! Goom Ride Reports 9 March 18th, 2013 03:50 PM
Holy freakin' tach batman! smokinsingle Ninjettes At Speed 6 March 23rd, 2012 07:00 PM
Pazzo shorty's hulk style zartan 2008 - 2012 Ninja 250R Farkles 8 April 15th, 2010 08:03 AM
[topix.net] - Hulk Hogan learns not to stand between a woman and her motorcycle Ninjette Newsbot Motorcycling News 0 August 27th, 2009 06:30 AM
