Old July 20th, 2010, 07:19 PM   #1
wayanlam
wayanlam's Avatar
Motorcycle(s): 2014 Z250
High Idle RPM...
hmm... i have a new issue with my bike, as of yesterday afternoon.
i drove back to work from lunch without any issues yesterday, but then when i started her up after work the bike's idle jumped up to 3k rpm. i tried loosening up the idle screw completely, and it only dropped down to 2.5k, but then it goes back up, and drops down between 2.5~3k rpm.
even letting the clutch go and holding in the breaks to try and slow the engine down manually did nothing, as soon as i went back to neutral, or pulled in the clutch the idle just rose back up to 3k rpm.
i was too tired to take the bike apart last night, but i might do it tonight. first and simplest test i will do is to put in the original CDI and see if that solves the issue. if not, then im gonna dig deeper into the bike and see if something is messing the carbs up. it could be that i don't have enough slack on the throttle cable, which would be a nice easy fix
has anyone else had to tackle this issue?
cheers,
W.
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer
Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield
wayanlam is offline   Reply With Quote
Old July 20th, 2010, 07:37 PM   #2
Cuongism
Cuongism's Avatar
Choke on?
Posted via Mobile Device
Old July 20th, 2010, 07:41 PM   #3
wayanlam
wayanlam's Avatar
Originally Posted by Cuongism View Post
Choke on?
lol, that would be funny if it was the case, i never use the choke, the bike always starts up perfectly, so i didn't even look at that! maybe some a$$ could have thought it would be funny to choke the bike
ill definitely check that before doing anything else when i get home haha!
thnx for pointing out the obvious
Old July 20th, 2010, 08:57 PM   #4
check for the required free play on the throttle cables and also the choke cable.
Old July 20th, 2010, 09:59 PM   #5
wayanlam
wayanlam's Avatar
D-Ohh...
i should have connected the dots, but i didn't cos i was exhausted yesterday, but a friend came my my workplace, and the smart-ass put on the choke, LOL
i guess it goes to show just how often i dont use the choke, hehe...
thanks again for pointing out the obvious!... and there i was stressing out thinking something i did when i rejetted the bike last month broke something
peace out~
W.
2006 Ninja 250 High Idle RPM GunnaBoyEB 1986 - 2007 Ninja 250R Tech Talk 4 September 4th, 2014 10:30 AM
Just cleaned carbs - now stuttering at low RPM, fine at high RPM Ohio 2008 - 2012 Ninja 250R Tech Talk 20 August 5th, 2014 10:30 PM
High Idle RPM (during/after riding) Maielstrom 2008 - 2012 Ninja 250R Tech Talk 6 October 23rd, 2013 07:05 PM
High handle bar vibration, hard to get into high RPM, is this normal? jackliu239 1986 - 2007 Ninja 250R Tech Talk 24 September 19th, 2013 09:04 PM
Idle jumps to 9000 rpm on choke then wont stay idle after off Shawn250 2008 - 2012 Ninja 250R Tech Talk 1 June 19th, 2012 06:45 AM
