Old August 29th, 2011, 08:47 PM   #1
ninja_sleeper
ninja_sleeper's Avatar
Motorcycle(s): Red 2009 Kawasaki Ninja 250R
Idle - too high
Is sounding funny. Idles at 3k rpms. I feel like this is more than it needs to be. It's sounding like she is over doing herself. In neutral it's at 3k rpm. When I first turn it on it's at 2k, then after I go she idles at 3k. Sooooo I am not sure whether I just noticed this or if it's a little off.
ninja_sleeper is offline   Reply With Quote
Old August 29th, 2011, 08:52 PM   #2
blink
Always.
blink's Avatar
Motorcycle(s): '08 Ninja 250, '05 GSX-R600
LOL is your choke on?
blink-182
blink is offline   Reply With Quote
Old August 29th, 2011, 08:53 PM   #3
eds2fitty
eds2fitty's Avatar
Motorcycle(s): 2011 250R SE
had the same problem when i first got the bike... there's a knob on the left side fairing that you could turn to adjust the idle...
eds2fitty is offline   Reply With Quote
Old August 29th, 2011, 08:54 PM   #4
blink
Always.
blink's Avatar
yea..i just asked if her choke's on.
blink-182
Old August 29th, 2011, 08:55 PM   #5
blink
Always.
blink's Avatar
that knob tho it's technically a choke. just in a different area for permanent idling solutions
blink-182
Old August 29th, 2011, 08:56 PM   #6
ninja_sleeper
Dude.... Guys..... THE KNOB ON THE LEFT IS NOT ON. Choke was the first thing I checked. ****.
Old August 29th, 2011, 09:00 PM   #7
eds2fitty
eds2fitty's Avatar
its not the choke on the handlebar... theres a knob on the left side of the bike on the body where u can adjust the idle, kkim had a thread about it but now the pics are gone...
Old August 29th, 2011, 09:01 PM   #8
First - this needs to be in the tech section. Next - have you read your owners manual? The knob they are talking about isn't the choke lever on the handlebar. If the choke is off, then adjust the idle knob once the bike is warmed up (after a 20+ min ride or so), so the idle is steady at 1500. The idle knob is down by your left knee, peeking out of the bodywork.
It's the black knob directly to the left of the end of the electrical connector I added below:
Old August 29th, 2011, 09:01 PM   #9
eds2fitty
eds2fitty's Avatar
i see...
Old August 29th, 2011, 09:10 PM   #10
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
Yeah they don't mean the choke they mean the idle knob. Alex is on target as always.
Trailerboy531 is offline   Reply With Quote
Old August 29th, 2011, 09:11 PM   #11
ninja_sleeper
I haven't touched it why did it change???
Old August 29th, 2011, 09:12 PM   #12
Trailerboy531
You may have knocked it without knowing, it could have vibrated just from you tearing up Oregon. Stuff happens!
Old August 29th, 2011, 09:16 PM   #13
For it to move a ton instantly, the most likely cause is the choke. Make sure that the choke lever on the handlebar is fully off, but while you are doing that pull it on and off to make sure that it's moving in the right direction. Pushing it away from you should shut the choke all the way off, pulling it towards you will raise the idle and make starts easier. Make sure that the choke is working either way, and it's not just sticking on for some reason.
But, if you've confirmed that the choke is functioning, and it's off, and the idle is still a little high, then the next step is the idle knob as listed above. It drifts over time as the bike breaks in and continues to wear.
Old August 29th, 2011, 11:32 PM   #14
setasai
setasai's Avatar
+1 on what alex said but just for the sake of thinking outside the box... if a mouse or something got stuck in your airbox and impeded flow of air it'd cause "choke" like symptoms.
Old August 29th, 2011, 11:46 PM   #15
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
i see...
please dont believe that.... Take apart your bike if you want to see how that little knob effects things, its in no way shape or form a second choke, the choke opens up bigger jets in the carbs, the knob doesnt let the throttle cable contract all the way (or let it contract more if you turn it the other way)... It was on a DIY here, but all the pics are gone
----> My Youtube! <----
Old August 29th, 2011, 11:55 PM   #16
setasai
setasai's Avatar
True, they're not technically the same but they both cause similar results... basically an increase in idle rpms. I dont think blink intended on confusing anybody, it's more of a simplification.
Old August 30th, 2011, 12:03 AM   #17
squaregamer476
learning stages
squaregamer476's Avatar
Motorcycle(s): black 09 kawasaki ninja 250
hmm, i don't remember seeing that knob. I have my battery charger plug-in around that area. maybe i missed it...
squaregamer476 is offline   Reply With Quote
Old August 30th, 2011, 12:04 AM   #18
squaregamer476
learning stages
found it. i didn't know it had any purpose. =P
Old August 30th, 2011, 01:52 AM   #19
Cuongism
Cuongism's Avatar
Ehh, by the way he's phrasing it though (ie by saying technically), it makes it sound like he thinks it's a choke which it's not at all. The choke isn't just affecting your idle rpms which is why it's a bad idea to ride for an extended period of time with the choke on. It affects the fuel/air ratio so it can foul up your plugs pretty quickly since you're running rich (so remember to turn it off after the engine is warm).
The idle knob on the other hand just prevents the throttle from fully closing. It doesn't affect your fuel/air ratio, but wastes gas at idle if set high.
Old August 30th, 2011, 09:12 AM   #20
setasai
setasai's Avatar
Yes yes. I'm just giving him the benefit of the doubt since writing can be misinterpreted and I think accusing him of intentionally misleading the OP is just a hair offensive. Thanks for explaining it more clearly. No argument/disagreement intended.
Old August 30th, 2011, 09:19 AM   #21
ninja_sleeper
Turned it on this morning and it wasn't as high as yesterday. I did mess with the idle a bit when I got to work and brought it down to 1500. If was not the choke, that was the first thing I checked for.
Thanks alex for your knowledge. I am glad it was a simple fix.
Oh and my bike didn't come with an owners manual If it did, I would read it.
Old August 30th, 2011, 09:29 AM   #22
Kawi posts 'em up for free on their site.
Here's a link to the 2009 owners manual:
http://www.kawasaki-techinfo.net/sho...9&lang_code=EN
Old August 30th, 2011, 10:05 AM   #23
blink
Always.
blink's Avatar
Relax.
blink-182
Old August 30th, 2011, 10:10 AM   #24
blink
Always.
blink's Avatar
Okay so you just rephrased what I said making it true...concept wise
the more your throttle is open the more air goes through your **** right?
so therefore when you open your side knob it varies RPM's because of the quantity of air and fuel ratio.
blink-182
Old August 30th, 2011, 10:11 AM   #25
blink
Always.
blink's Avatar
Just like in a car when you rev in neutral you allow the throttle bodies to open,
when you pop your hood and rev it with the throttle body control its the same concept
blink-182
Old August 30th, 2011, 10:13 AM   #26
Indetrucks
CVMA #69
Indetrucks's Avatar
Motorcycle(s): 1st Gen SV650 Race Bikes, Ninja 250R Race bike, 05 YZ125, 73 CB350 Cafe Racer
LOL @ "tearing up" Oregon.
These Ninja 250's are MONSTERS!
~Christian
CVMA #69
Indetrucks is offline   Reply With Quote
Old August 30th, 2011, 06:11 PM   #27
Cuongism
Cuongism's Avatar
Not sure if you're understanding the difference between the choke and idle knob. Choke adds more fuel through the enrichener circuit and not air, so you will be running rich (more fuel/same air).
Idle knob just prevents your idle from closing, but your fuel/air ratio remains the same.
Strange high idle issue. Terraninja 1986 - 2007 Ninja 250R Tech Talk 40 April 8th, 2015 06:30 PM
High idle when turning to lock ktp1598 1986 - 2007 Ninja 250R Tech Talk 3 March 20th, 2014 08:21 PM
High Idle RPM (during/after riding) Maielstrom 2008 - 2012 Ninja 250R Tech Talk 6 October 23rd, 2013 07:05 PM
Throttle cable - high idle? austexjg 2008 - 2012 Ninja 250R Tech Talk 3 November 30th, 2010 09:41 AM
High Idle RPM... wayanlam 2008 - 2012 Ninja 250R Tech Talk 4 July 20th, 2010 09:59 PM
