Old October 21st, 2011, 10:45 AM   #1
str8t six
never enough
str8t six's Avatar
Motorcycle(s): Blue 2010 ninja 250R
how to remove adhesive from ninja decal?
I took off my ninja decals from my bike, but i cannot get the leftover adhesive off!! ive used goo gone and rubbing alcohol, nothing is working!! HELP!!
custom graphics, zero gravity DB
str8t six is offline   Reply With Quote
Old October 21st, 2011, 12:43 PM   #2
the big mike
the big mike's Avatar
Motorcycle(s): 2008 Ninja 250r, Fazer8
I believe there was already a thread about this, but I can't seem to find it. I use my chain cleaner. That stuff is powerfull enough to remove anything without harming your paint. Worked like a charm on mine
I can not be a true player by playing around.
the big mike is offline   Reply With Quote
Old October 21st, 2011, 01:01 PM   #3
2000 grit sand paper then buff to a shine?
Old October 21st, 2011, 01:31 PM   #4
str8t six
never enough
str8t six's Avatar
what chain cleaner you use?
do you think wd 40 would work without messing up the paint?
Old October 21st, 2011, 01:33 PM   #5
GateKeeper
GateKeeper's Avatar
Motorcycle(s): 250 Ninja - Soon
^^^^^^ Ohhhh ya that will do it ...... LOL
GateKeeper is offline   Reply With Quote
Old October 21st, 2011, 01:52 PM   #6
str8t six
never enough
str8t six's Avatar
i dont know if you are being sarcastic or not, but alex is correct, sandpaper will get it off if i wet sand the area. i have a buffer to do this, but i only want to do that as a last resort.
Old October 21st, 2011, 02:03 PM   #7
GateKeeper
GateKeeper's Avatar
I was being a little sarcastic.....and your right use that option as a last resort, as it will take a lot more work to get it all back nice and shiny.....
I would look at a chemical solution first, but make sure it will not eat away at paint
brake cleaner might do it, or WD40 even might get rid of the goo
Any chemical you might want to try, first try it in a hidden spot, just in case.............bottom side of the tank possibly....first
Old October 21st, 2011, 03:28 PM   #8
just about any "chemical solution" will attack the paint. wet sanding with 2000 grit will not scuff the clear much when there is gunk on top. sand just enough to get the gunk off and it will only be slightly cloudy... buff the cloudiness away... would take 10 minutes and wont screw up your paint like chemicals will.
Old October 21st, 2011, 03:54 PM   #9
GateKeeper
GateKeeper's Avatar
ok
Old October 21st, 2011, 03:54 PM   #10
Clearlynotstefan
Clearlynotstefan's Avatar
Motorcycle(s): 2000 Ninja 250, Totally black. Gsxr 600 Red.
a very small amount of acetone on a paper towel, do it quick, then wash the acetone off. wont leave a mark.
Clearlynotstefan is offline   Reply With Quote
Old October 21st, 2011, 04:12 PM   #11
Boom King
So, where's the reverse?
Boom King's Avatar
WD40 would work, I've used it to get off the gunk left from heavy duty 3M adhesive. It was on a non-painted car part though so not sure how it would affect the paint. I've heard that olive oil or vegetable oil might work as well.
I use Bounce/dryer sheets to remove stuck on bug guts and tree sap and they basically slide off the paint with no ill effects. Perhaps give this a try on the adhesive. Put one or two sheets in a spray bottle and soak that area. Wipe it off with a cloth. Once you're finished, wash that area and wax. Alternatively, you can wet the sheet like a sponge and dab the area and wipe.
Acetone is also used as a paint thinner. A small amount may not immediately damage the paint but is probably enough to start eating away at the clear coat.
Last futzed with by Boom King; October 21st, 2011 at 06:36 PM.
Old October 22nd, 2011, 03:49 AM   #12
kevheads
kevheads's Avatar
Motorcycle(s): 2011 Green 250R
Try a "Magic Eraser" found with kitchen cleaners at Walmart. They things remove anything.
kevheads is offline   Reply With Quote
Old October 22nd, 2011, 05:46 AM   #13
the big mike
I don't know about wd40, but I've used 2 different chain cleaners already without any problems for my paint: first was muc-off chain cleaner, second is motul chain cleaner.
Muc-off was very good
motul does the job, but leaves a greasy layer which you'll have to clean afterwards as well
Old October 22nd, 2011, 08:41 AM   #14
Boom King
Boom King's Avatar
Just be careful if you go this route. The main active chemical in these pads is Melamine foam, an abrasive cleaner. It is safe for hard surfaces like floor tile, sink basins, and glass shower doors but it may make the clear coat on paint look "cloudy" or dull. For instance, the Mr. Clean Magic Eraser mop is not recommended for finished wood floors.
How to remove a decal ? bikermunda 2008 - 2012 Ninja 250R Farkles 23 March 26th, 2013 05:43 AM
Adhesive for turn signals Maelstrom 2008 - 2012 Ninja 250R Tech Talk 9 July 27th, 2012 07:59 AM
07 ninja 250 flame decal remove?!? holliealisha 1986 - 2007 Ninja 250R Farkles 6 February 27th, 2012 04:39 PM
What is the easiest method to remove the special edition decal design off my bike? NinjaFLYBY General Motorcycling Discussion 7 March 23rd, 2011 04:12 PM
Need adhesive/glue for tank pad davidgz General Motorcycling Discussion 3 September 7th, 2010 05:55 PM
