Old May 12th, 2009, 06:11 PM   #1
motorcycle_munge
motorcycle_munge's Avatar
Motorcycle(s): Ninja 250R
gas mileage
What kind of gas milage is everyone getting on their bikes? I have an 09, I don't know what I am doing wrong, I am only getting about 40 mpg, sometimes less.
motorcycle_munge is offline   Reply With Quote
Old May 12th, 2009, 06:14 PM   #2
http://www.ninjette.org/forums/showthread.php?t=13536
Old May 12th, 2009, 06:27 PM   #3
Viper-Byte
Viper-Byte's Avatar
Motorcycle(s): 08 Ninja 250R in Green! (Sold) Now 2011 Triumph Daytona 675 SE
See the massive thread above. I am getting 48MPG (I was in the 61-70 bracket when I voted before all my mods) with heavy mods and a heavy wrist
2008 GREEN Kawasaki Ninja 250R.
AreaP Quiet Core Carbon Fibre : 8000k HIDs : Dynojet Jet kit : Double Bubble Windscreen
Viper-Byte is offline   Reply With Quote
Old May 12th, 2009, 06:28 PM   #4
plus, how are you calculating your MPG?
Old May 12th, 2009, 06:31 PM   #5
motorcycle_munge
I am filling up. Resetting the trip odometer. Then when I fill up again, I divide the number of gallons by the number of miles on the trip odometer.
Old May 12th, 2009, 06:36 PM   #6
bob706
bob706's Avatar
55-60mpg on my 08. If your getting 40ish mpg you either have an insatiable need for speed or a fuel issue you need to get checked out, i.e. plugs fouled, carbs gunked up, etc.
Old May 12th, 2009, 06:36 PM   #7
Viper-Byte
Viper-Byte's Avatar
When I voted i calculated the L/100kms then I converted that by online converter to US MPG. I did this over 3 fills.
Now I have a Roadtrip application on my iPod where I enter the odo reading at fill, fuel amount in L and I can set it to show me the US MPG, UK MPG, L/100km etc etc. This so far is over 6 fills and has only varied between 47 and 48.9MPG with 47.95 being the average so far.
Old May 12th, 2009, 07:31 PM   #8
capt_bugaloo
motorcycle rider
capt_bugaloo's Avatar
My 2008 gets about 45-48 in the city stop-n-go traffic of my commute.
I get about 55-58 out on the open highway.
Yes, it is running fine and there are no fuel issues; the '08-09s just are not as miserly with fuel as the pre-08s.
Old May 12th, 2009, 10:07 PM   #9
That's an accurate way of calculating it. So, how do primarily use your bike? commuting, stop and go, cruising, highway, twisties?
any modifications done to your bike?
Old May 13th, 2009, 04:26 AM   #10
Snake
Snake's Avatar
I have a pre gen and I get around 55 to the gallon.
Old May 13th, 2009, 07:13 AM   #11
OldGuy
Live Life
OldGuy's Avatar
Motorcycle(s): 2009 Green SE Ninja 250
The first three tanks on my '09 have been in the low to mid 50's. 80% in town commuting the other 20% on the road at 55-65 mph.
- ATGATT -
Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots
OldGuy is offline   Reply With Quote
Old May 13th, 2009, 07:29 AM   #12
motorcycle_munge
There are no modifications to my bike. I mainly ride it on the highway and through some twisties.
Old May 13th, 2009, 09:32 AM   #13
beowuff
beowuff's Avatar
My '07 averages about 64 mpg commuting. Best ever was 74 on a long highway trip.
beowuff is offline   Reply With Quote
Old May 13th, 2009, 11:32 AM   #14
wow... 40 is sort of low for non aggressive riding. are you sure you are turning off the choke or that the choke is being turned off all the way when the lever is in the off position?
other than the low MPG, how does the bike run?
Old May 13th, 2009, 02:16 PM   #15
Bill N
Motorcycle(s): 250 Ninja
For my 2008 I log my mileage at most fillups. There are 15 in my log and I'm averaging about 62 MPG in stop and go riding commuting to and from work with top speeds about 60 MPH.
Bill
Bill N is offline   Reply With Quote
Old May 13th, 2009, 02:23 PM   #16
motorcycle_munge
I hardly ever have to use my choke. So it pretty much stays off. Other than the low MPG, the bike runs great. It only has a little over 1000 miles on it. Hopefully the more I ride it, the better MPG I will get.
Old May 13th, 2009, 02:33 PM   #17
check to see if the choke is adjusted correctly and that is indeed all the way off when the lever is in the closed position. the procedure is in the owner's manual.
Old May 13th, 2009, 06:34 PM   #18
DirtyBoy
DirtyBoy's Avatar
I average 45mpg with a 49 tooth rear sprocket and a very aggressive throttle hand. I ride about 80% city and 20% hwy.
49T sprkt/ EK gold chain/ Galfer pads and SS lines/120 frt 150 rr Pilot Powers/ GSX-R can/Desnorkled/ Raised needles/ Slider spools/ Cowl/ LED rear signals/ Fender eliminator/ Tinted lights / Emu seat
DirtyBoy is offline   Reply With Quote
Old May 14th, 2009, 07:19 PM   #19
dmonaco05
Motorcycle(s): 2009 ninja 250r
do u get ur gas at the same place all the time? r they known for crap gas? all the fastracs around here have 10% ethanol or something in them and it makes for crappy gas
dmonaco05 is offline   Reply With Quote
Old May 14th, 2009, 07:30 PM   #20
beowuff
beowuff's Avatar
I ALWAYS get my gas at either Shell or Cheveron. Usually Shell. I've never had a problem. Same for in the cage.
Old May 15th, 2009, 08:44 PM   #21
IlBLisSlI
i'm a cow killer
IlBLisSlI's Avatar
Motorcycle(s): 2006 250r
on average i get 65-72 mpg (this is on my 2006)
i'm 200lbs and i do mostly highway driving. i try to never go over 8k rpm
currently on stock sprokets
Last futzed with by IlBLisSlI; May 16th, 2009 at 02:32 PM.
IlBLisSlI is offline   Reply With Quote
Old May 16th, 2009, 12:01 AM   #22
CodE-E
Ninja Newbie
CodE-E's Avatar
Motorcycle(s): EX250K9
With what revs to do tend to ride? If you're always at over 8000 revs, that kind of gas mileage wouldn't surprise me. But if you drive normally at 3000-8000 mostly, then yeah, it seems a bit low.
CodE-E is offline   Reply With Quote
Old May 16th, 2009, 01:10 PM   #23
motorcycle_munge
I usually stay between 7000-8000, sometimes a little higher, but not very often.
Old May 16th, 2009, 01:54 PM   #24
Strider
Back on the Black!
Strider's Avatar
Motorcycle(s): 2006 Kawasaki Ninja EX250 (Black)
I average about 55-60 on my '06 , but I'm a heavy fella
Strider is offline   Reply With Quote
Low Gas Mileage, why? Dhillon92 2008 - 2012 Ninja 250R Tech Talk 32 July 27th, 2013 04:51 PM
Poor Gas Mileage? Bones85 2008 - 2012 Ninja 250R Tech Talk 47 April 29th, 2013 01:54 AM
Gas Mileage: New vs Old Gen SmithSwede General Motorcycling Discussion 9 June 12th, 2012 01:07 PM
Impressive gas mileage A7xschecter6661 General Motorcycling Discussion 12 October 10th, 2011 01:57 PM
Why the sucky gas mileage? Gbug General Motorcycling Discussion 10 March 17th, 2009 06:05 PM
