Old April 13th, 2009, 02:22 PM   #161
Originally Posted by Viper-Byte View Post
My stock 10A fuse would blow when ever I switched to high beam regardless of how long the bike had been running on low beam only... 15A fixed that.
is yours a 35 or 55W HID kit?
Old April 13th, 2009, 02:24 PM   #162
Viper-Byte
Viper-Byte's Avatar
Motorcycle(s): 08 Ninja 250R in Green! (Sold) Now 2011 Triumph Daytona 675 SE
Mine is a 55w kit.
2008 GREEN Kawasaki Ninja 250R.
AreaP Quiet Core Carbon Fibre : 8000k HIDs : Dynojet Jet kit : Double Bubble Windscreen
Viper-Byte is offline   Reply With Quote
Old April 13th, 2009, 02:27 PM   #163
that could be the reason there. most kits are 35W.
Old April 13th, 2009, 02:31 PM   #164
Viper-Byte
Viper-Byte's Avatar
Ah, I got the 55w kit cause that is what the stock bulbs were. I assume you got the 35w kit?
Old April 13th, 2009, 02:40 PM   #165
yes. most HID kits are 35W. it's not been till recently/later that they have offered the 55W kits.
Old April 13th, 2009, 03:06 PM   #166
g21-30
g21-30's Avatar
David, I never realized you received a 55w kit. In fact, I didn't know it was available. That explains a lot!
Old April 13th, 2009, 03:12 PM   #167
Viper-Byte
Viper-Byte's Avatar
Yeah, I saw that there were 35w and 55w kits available, I thought I would get the 55w as I guess it would be brighter?
Old April 13th, 2009, 03:32 PM   #168
ahskeetz
ahskeetz's Avatar
Motorcycle(s): 2008 250r
i actually have a 35w kit and i still had to upgrade to a 15a fuse. i turned on the high beams before the low beam was finished warming up and the fuse popped, i just got a 15a and it works fine.
2008 250r: AP CF full exhaust, raised needles, 6000k HIDs, flush mounts turn signals, custom fender chop
ahskeetz is offline   Reply With Quote
Old April 15th, 2009, 12:17 PM   #169
Cochese
The Grand Royal
Cochese's Avatar
Going on this week!
Cochese is offline   Reply With Quote
Old April 18th, 2009, 07:20 PM   #170
Sound Wave
Ramen Rider
Sound Wave's Avatar
thanks for this DIY. i got my HIDs hooked up. found two broken fairing rubber nut thingys. those things are junk. still running the stock fuse and it seems to be ok. gotta remember to go and get another spare fuse. wouldn't want to blow the fuse at night.
QUESTION:
so i marked on the wall the height at which my stock light was... both for low and high beam. after my install, i checked the level again. i can't get both to be in their original levels at the same time. for now, i got the low beams set correctly. the high beam is higher than before. i figure that i won't be riding with the high beams on if there is oncoming traffic or someone ahead of me anyways.
so my question is, is there a way to adjust the level so that both are correct? from what i can tell, there is only one vertical knob that adjusts both of the beams. thanks in advance.
Old April 18th, 2009, 07:27 PM   #171
there is no way to independently adjust the low and high beams. adjust the low beam for proper height and you're done. The high beam height really doesn't matter as you said, you won't be using them during oncoming traffic anyway.
You might want to check if the bulbs are seated firmly/squarely in the socket. Just being skewed off a little can affect the pointing direction of the reflector and ultimately the beam.
Old April 18th, 2009, 07:32 PM   #172
Sound Wave
Ramen Rider
Sound Wave's Avatar
thanks for the quick reply. yeah, i guess i can try wiggling the high beam side a bit. i did check it when i initially put it in and it seemed really snug. won't hurt to look again.
side note: for those planning on doing this, i am not sure if it is already mentioned, but i would say not to take off both retaining clips for the bulbs at the same time. do one side first, finish it, then go to the other. that way, you can use the other side as a reference as to how to put the clip back on.
Old April 18th, 2009, 07:35 PM   #173
check both bulbs. it could be the low beam bulb not being seated properly that is throwing off the difference in the light pattern on the wall.
like I said, though. it really doesn't matter as long as you can adjust the low beam to the proper height.
Old April 18th, 2009, 07:41 PM   #174
Sound Wave
Ramen Rider
Sound Wave's Avatar
yeah, thanks. i was just thinking about that after i sent the message.
if the weather holds up, gonna try them out tonight.
Old April 18th, 2009, 07:43 PM   #175
paterick4o8
paterick4o8's Avatar
Motorcycle(s): '08 blue 250R [sold]. '09 lime ZX-6R [stolen :( ]. '06 blue 636.
FIY, there are actually 2 spare fuses already in the fuse box.. noticed this AFTER I went out and bought spares
paterick4o8 is offline   Reply With Quote
Old April 18th, 2009, 07:44 PM   #176
Sound Wave
Ramen Rider
Sound Wave's Avatar
oh cool! thanks. you saved me a trip. i guess it would help if i actually popped that fuse box cover open, huh?
Old April 19th, 2009, 10:05 AM   #177
paterick4o8
haha no worries Gary. time for some ninja night riding tho yeah?
Old April 19th, 2009, 11:53 PM   #178
Sound Wave
Ramen Rider
Sound Wave's Avatar
question: i have my headlights aimed at the same level that they were before. (i had the bike approximately 25 feet away from the wall and put a piece of tape at the top of the light pattern to use as a guide) however, when i took it for a test ride, it seems like the pattern is actually higher than previously.
is it just that the light is stronger, so it seems to project farther? or should i point it down lower even if it is aimed at the same level as stock? thanks.
Old April 20th, 2009, 12:00 AM   #179
for me the real test is when you pull up behind a normal sized, non lowered sedan at a stop light. Your low light beam cutoff line should be just below the trunk line so your headlight does not shine into the interior of the car.
if you cannot see your cutoff line below their trunk line, lower it until you can. it may take a few times to get it right.
Old April 20th, 2009, 12:04 AM   #180
Sound Wave
Ramen Rider
Sound Wave's Avatar
that is the way my beam is. it doesn't go into the car. i can see the cut-off line a few inches below the top of the trunk. ok, i guess i am alright then. thanks!
Old April 20th, 2009, 12:09 AM   #181
that's how I've fine tuned mine and have had no problems with people flashing me at night. However, if you should make any changes to your suspension in the future, front and/or rear, remember to recheck your headlight aiming.
how's the HIDs?
Old April 20th, 2009, 12:12 AM   #182
Sound Wave
Ramen Rider
Sound Wave's Avatar
well, apart from me being afraid that a cop might pull me over, the other fear is that i am just waiting for my stock fuse to blow every time i turn my high beam on.
i guess it just takes some getting used to. but other than, i love them.
Old April 20th, 2009, 12:45 AM   #183
Sound Wave
Ramen Rider
Sound Wave's Avatar
took some pics for a forum member who wanted daylight pics, so i figure i would also post up two of them here. 6000k:
Old April 20th, 2009, 12:50 PM   #184
muffinman
muffinman's Avatar
Motorcycle(s): '08 250R (sold), '05 ZX6R / 636
Glad you got the HID kit to work
any tips on turning the vertical adjustment knob without taking the fairings off? it's awkward to reach and for some reason, does NOT want to turn.. my beams are aimed way too high
muffinman is offline   Reply With Quote
Old April 20th, 2009, 01:06 PM   #185
I can reach mine just fine by reaching up from underneath the front left side of the fairing. have you tried turning it both ways to see if you have affect on the beam pattern? if not, you may be turning the wrong thing.
if you can't turn it at all, maybe you are turning the wrong thing.
can you move the horizontal adjuster on the other side of the headlight assembly?
Old April 20th, 2009, 01:29 PM   #186
muffinman
muffinman's Avatar
Haha, haven't tried the horizontal adjuster yet.. but I looked in the manual and I'm pretty sure I'm trying to twist the correct knob... it's the one that has ridges and looks "gear-like", right?
Thanks
Old April 20th, 2009, 01:42 PM   #187
muffinman
muffinman's Avatar
Thanks
Oh and u just twist with your hands correct? There's no screw in the middle?
Posted via Mobile Device
Old April 20th, 2009, 01:47 PM   #188
g21-30
g21-30's Avatar
See attached
Old April 20th, 2009, 01:56 PM   #189
from this thread.
The next picture shows the back of the nose piece, which details the headlight lamp housing, after the low beam (left side) bulb was replaced and the rubber housing was modified. The blue and yellow arrows detail the adjusting screws for the light beams.
Old April 20th, 2009, 02:18 PM   #190
Sound Wave
Ramen Rider
Sound Wave's Avatar
thanks arthur. yeah you can reach it if you stick your hand up. if you look up from under the front tire you can see the headlight assembly. and yeah, you just twist it with your hand. if it doesn't turn, maybe try turning it the other way? i think it was left to lower although i don't know for sure.
Old April 20th, 2009, 03:25 PM   #191
g21-30
g21-30's Avatar
Wow, that's a nice picture. Wish I would have thought of it!
from this thread.
Old April 20th, 2009, 03:54 PM   #192
muffinman
muffinman's Avatar
Yup! That's the one.. I'm able to reach it and I've been trying to twist that sucker both ways all day.. my wrists have red marks all over them and my fingers are blistered.. no luck moving it though
Old April 20th, 2009, 04:04 PM   #193
paterick4o8
I know what you mean. If it's that tight, then you may need to remove the side fairings at the least to give you a better angle on twisting these suckers. I just took my front fairing all the way off and use a screw driver to adjust it since I was already working on the bike
Old April 27th, 2009, 07:15 AM   #194
sugizo_esp
just wondering
are the stock halogen bulbs both H7 ?
sugizo_esp is offline   Reply With Quote
Old April 27th, 2009, 07:44 AM   #195
camaroz1985
camaroz1985's Avatar
Motorcycle(s): 2008 WR250R, 2006 Ural Raven (Sold), 2009 Versys Green (Sold), 2008 Ninja 250R Green (Sold)
Yeap
camaroz1985 is offline   Reply With Quote
Old April 28th, 2009, 02:10 PM   #196
murc585
Motorcycle(s): Red 2008 Ninja 250R
are any of you having flickering issues? I find when the bike is being accelerated or decelerated, the lights will start to flicker and when I brake, the flickering get even worse as if I'm flashing my lights at people.
Anybody get this too?
murc585 is offline   Reply With Quote
Old April 28th, 2009, 02:22 PM   #197
Sound Wave
Ramen Rider
Sound Wave's Avatar
i wonder if your wiring is loose somewhere?
Old April 28th, 2009, 02:43 PM   #198
paterick4o8
I get this at idle on my high beams only when I turn it on my bike after letting the low beam warm up.. just before I leave my house. I now turn on high beam during acceleration, this stops the flickers from happening for the rest of my ride.
I know it's been talked about as bad, but I also changed to a 15 fuse as originally my 10 was blown from the HIDs at start up after installation
Old April 28th, 2009, 03:15 PM   #199
Viper-Byte
Viper-Byte's Avatar
I get this on both Hi and Low beams, it usually occurs when I am acellerating or decelerating. I suspect that it could be due to the quality of the bulbs. I know that mine are not of the best quality and I am trying to source a Hella HID Bulb and see what the difference is.
Old April 28th, 2009, 09:33 PM   #200
no flickering here.
HID headlight conversion. agentbad General Motorcycling Discussion 6 May 21st, 2014 07:13 PM
[webbikeworld.com] - Bikemaster HID Headlight Conversion Kit Review Ninjette Newsbot Motorcycling News 0 September 16th, 2012 09:10 AM
HID conversion b_eastep 1986 - 2007 Ninja 250R Farkles 84 August 4th, 2010 10:10 AM
Proper HID conversion? jonthechron 2008 - 2012 Ninja 250R Tech Talk 23 February 9th, 2010 02:09 PM
