Old June 13th, 2012, 06:21 PM   #1
tubarney
Dyno-tuning Results Two Brothers Exhaust
Hello everyone,
Since buying my ninja about a year ago. I have found it hard to find accurate and independent results for the expected Hp gains from adding a full exhaust. So heres my results for anyone considering this upgrade.
First off my bike is a 2010 Special Edition Ninja 250r.
Mods include - Woodcraft Clip-ons, Pazzo levers, Renthal grips, Full 2-1 Two Brothers exhaust, Integrated tail light and fender eliminator.
The other day I installed a Two Brothers Black Series Carbon Fibre Complete 2-1 system, headers pipes are stainless steel. Yesterday I took it for Dyno tuning at S&R Pro in Penrith, Sydney Australia. The first Dyno run is with the full Two Brothers already installed, thats why the original Hp is a bit high at 29 Hp. The second is after the rejet of the carbies - The writing says 33.2 Hp, but he either read it wrong or tried to fool me, Its 32.2 Hp!!. The snorkel has NOT been removed!. The lower third line is the air/fuel ratio not torque.
Also, the Two Brothers P1 adapter/silcencer was installed for all Dyno runs and tuning. The guy at S&R originally tried to do it without the P1 but the Air-Fuel measuring thing keep falling out of the exhaust. Before we installed the P1, the Hp went from 26 to 32, only thing was on half the runs the reading would go back down because the sensor would fall out. Another reason why the Hp is high before tuning was due to the engines greater efficiency when hot. It had a chance to heat up when he was originally trying it without the P1
This ninja is tuned on 95 octane, think thats 89 or 91 in the states (one below the most expensive premium). Despite what most people will tell you; YOU WILL NOT get more Hp from a higher octane fuel. The lower octane you can run without the engine pinging/knocking the more Hp your engine will make. Its all about compression ratios. Kawa says the lowest you can use is 91 is Aus or 87 in USA(i think), so that octane rating will give you the most Hp.
Feel free to ask me any questions.
Old June 13th, 2012, 08:20 PM   #2
fleemos
fleemos's Avatar
Motorcycle(s): 2012 Yamaha FZ6R, 2014 Suzuki GSX-R600
I'm new to the bike world but those look like decent gains to me. Thanks for posting this.
fleemos is offline   Reply With Quote
Old June 13th, 2012, 08:42 PM   #3
cory jordan
Motorcycle(s): 2012 kawi 250r
When you say dyno tuned, what are you tuning, the jet/needle ... seems like It needs some ignition tuning
Originally Posted by Peanut_EOD View Post
I didn't say throw it on the ground. I said drop it. I suggested neglect not abuse!
cory jordan is offline   Reply With Quote
Old June 13th, 2012, 09:31 PM   #4
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
Was the dyno on crack?
----> My Youtube! <----
Old June 13th, 2012, 09:36 PM   #5
cory jordan
Stock timing , full exhaust /jet kit with stock air box doesn't make 32 whp. What was the correction factor/smoothing on the dyno
Old June 13th, 2012, 09:54 PM   #6
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
Australia... FI bike?
Trailerboy531 is offline   Reply With Quote
Old June 13th, 2012, 10:28 PM   #7
cory jordan
LOL whoops
Old June 14th, 2012, 12:31 AM   #8
Cam0
Cam0's Avatar
Aus bikes are not FI models... but you'll get different results here is Aus than you would In the states.
Cam0 is offline   Reply With Quote
Old June 14th, 2012, 02:52 AM   #9
ninja250r81
ninja250r81's Avatar
Motorcycle(s): 2012 ninja 250r se
my post
http://www.ninjette.org/forums/showthread.php?t=99720
14.9% increase, sweet
now what did you say about dynos
DynoJet dynos (inertia) vs. loading dynos (such as Mustang and Dyno Dynamics
This discussion revolves around chassis dynamometer's and is intended to be informative and thought provoking. There are two types of chassis dynamometers on the market, inertia and loading. An inertia dynamometer (such as DynoJet) does not measure torque, but measures acceleration. A loading dynamometer applies resistance that is measured (using some type of strain gauge.)
The most often heard discussion is that what factor can be applied to rear wheel horsepower to reflect crankshaft horsepower. This is where we need to understand how the rear wheel horsepower number was derived. Since the DynoJet seems to be widely used and numbers quoted are those from a DynoJet, we are going to use them as our inertia dynamometer example.
First it is important to have an understanding of how DynoJet gets their horsepower numbers. Power in mechanical terms is the ability to accomplish a specified amount of work in a given amount of time. By definition, one horsepower is equal to applying a 550 pound force through a distance of 1 foot in one second. In real terms, it would take 1 HP to raise a 550 pound weight up 1 foot in 1 second. So to measure horsepower, we need to know force (in pounds) and velocity (in feet per second). Dynojet's inertial dynamometer measures power according to the terms just described. It measures velocity directly by measuring the time it takes to rotate two heavy steel drums one turn. It measures force at the surface of the drum by indirectly measuring it's acceleration. Acceleration is simply the difference in velocity at the surface of the drums from one revolution to the next. The force applied to the drums is calculated from acceleration using Newton's 2nd law, Force = Mass * Acceleration. Since the mass of the drums is know and acceleration has been measured, Power (horsepower) can now be calculated. Torque is then calculated using the horsepower number: Torque = Horsepower * 5252 / RPM.
Once they have these numbers a series of correction factors are applied, some made public, some hidden as proprietary secrets. The public correction factor is the SAE correction factor. This formula assumes a mechanical efficiency of 85%. The formula used is: Where: CF= 1.18 * (29.22/Bdo) * ((Square Root(To+460)/537)) – 0.18. To = Intake air temperature in degrees F, Bdo = Dry ambient absolute barometric pressure. This correction factor is meant to predict output in varying atmospheric conditions and is a +/- 7%. The proprietary correction factor is supposed to reflect the loss of power from the crankshaft to the rear wheels.
A Loading Dynamometer applies resistance to the dyne's roller(s) , typically using either a water brake or a current eddy brake. In either case, the amount of force is measure using a strain gauge. The measured force is torque which is a real, indisputable measurement of the actual output at the wheel. Horsepower than can be calculated: Hp = Trq * 5252 / RPM.
A Dynamometer can only measure actual power at the output location. Actual power produced AND delivered by an engine will be highest if measured at the crankshaft, lower at the transmission output shaft and even lower, but more meaningful, still, at the rear wheels. The power that you use is the power at the rear wheels. Some Dynamometer companies add to measured rear wheel power readings a factor that is based on ESTIMATED rear wheel power losses (under what power conditions? 3.0 ltr.? 5.0 ltr.? Under coasting conditions? with a 185/70/15 radial tire? a 335/35/18 radial tire? New heavy radial tire vs. worn old, light, racing tire? Who knows?) In short, there is NO meaningful "average" tire to get a correct rear tire power transmission loss measurement for all cars - so obviously, unless they actually measure the power lost in the rear tires, under driven load conditions, NO dyno company should BE ADDING incorrect power figures into the measured power. It's simply wrong. The fact that they add varying amounts of power to the actual, "true" amount of power delivered and measured to the surface of the drive roller creates a situation that makes it an onerous task to compare power figures from different brands of dynamometer systems. On simple inertial dynamometers, some (most) companies use an average for the inertial mass value of the engine, transmission, driveshaft, axles and rear wheels. This is saying that a 4 cylinder, 2.0 ltr. Porsche 914 has the same rotating mass and same rear wheels as a 8 cylinder, 5.0 ltr. Porsche 928 S+4. This simply is not so and wrong.
It's expensive to measure frictional losses in the engine and drivetrain, requiring the dyno to be able to drive the vehicle with engine off. Add the cost of a 50+hp electric motor, controlled power supply, etc. It's just not likely that $20,000 dyno will be equipped with that equipment. It is also common for dynamometer companies to add to the power readings by adding transmission and driveshaft losses back into the measured power readings. Some companies make a concerted effort try to measure frictional losses and, optionally, add the power to the measured readings. Other companies - some that would surprise you - say that it's not important and give a blanket, single factor for frictional losses in every engine. Some simply say that there is a meaningful "average" for every car,( 4 stroke/ 4 cylinder/ 4 speed transmission, 4 stroke/ 8 cylinder/ automatic transmission) and apply it to every car and that it is not a significant difference. Blanket estimates of "average" losses and corrections are, quite simply, incorrect. At the upper levels of the industry, (we are talking about $150,000 - $500,000 AC or DC 4 quadrant dynamometers) it is not tolerated - shouldn't be - and needn't be. There is a dyno company that actually has different versions of software that displays their own identical data files as different amounts of power depending on whether you use the DOS version or the Windows version of their software!!
True, rear wheel horsepower is the standard of measuring the power that is actually delivered to the rear wheels. It is honest, true, fair and duplicable. It is the ONLY standard that can be duplicated by the entire industry - regardless of the dyno manufacturer. From my experience and that of many others, when comparing True, rear wheel horsepower to DJHP you must apply a factor. It appears that this is a sliding scale based on horsepower but the best estimate is 1.05 to 1.21 (maybe higher). What this means is that for those of you trying to calculate what your crankshaft horsepower is based on DJHP, and are adding 15%, the most common number I hear, you are actually doubling (at least) the factor. Why? Because DJHP already has a puff number added into their DJHP. Lets say DJHP shows 200 hp and you add 15%, you get 230 hp crankshaft horsepower. In reality DJ has already added in 15 or 20% to their 200 DJHP number. How does this help us.? It does not, and is fact harmful to the many dynamometer test facilities that report only what the dyno actually measured. I can not tell you of the many discussions that we have had as to why the horsepower numbers we recorded lower than that of DJ. For those manufacturers that use DJHP as proof of their claims, can you imagine the shock your customers get when the horsepower number of a vehicle tested on a load bearing dyno do not come close to their claim.
Proper tuning, especially on highly modified engines greatly affect the power difference. Due to the fact that the DJ dyno's sweep so quickly on sweep hp tests, there is no way to properly tune a fuel map. What you get is the acceleration and full throttle maps both triggered during the test, ending up over-rich, affecting the horsepower. The other factor that needs to be taken into account is that DJ dynos assume that every vehicle has the same rotating mass - they don't - and that disregard is another reason why the hp conversion figures are different. The most accurate measurement of rear wheel horsepower is in Steady State Mode (inertia is not a factor in power equation.) The inertial mass changes on each car affects the DJ power, but not the true, rear wheel horsepower. There's another message in the above example, besides the average true, rear wheel horsepower to DJHP conversion factor - It's up to the more experienced reader to figure it out.
Chassis dyne HP, What is it? What to call it? DynoJet = "DJHP". It's not really proper to call "DJHP" "rwhp", as neither the Mustang, DynoJet, Fuchs, Superflow or Land and Sea will necessarily produce the same numbers as a DJ dyno, except by luck - and the whole idea of true, rear wheel horsepower is that EVERY dyno manufacturer HAS the capability to provide those numbers! The Superflow chassis dynes, the Mustang, Land and Sea are all capable of measuring power in steady state mode and producing the same numbers - they all measure torque. Torque x rpm / 5252 = horsepower. We've not diddled with physics! The only factor that is added to the measured reading, in true, rear wheel horsepower, is the additional energy (dyne parasitics) required to spin the dyno(s) roller to whatever speed the roller is turning at - logical, proper and required for any measuring instrument, torque x rpm / 5252 = horsepower + parasitic power = true, rear wheel horsepower.
Chassis dyne HP, What can inflate HP readings on a dyno, but not really make more engine power in the real world? A few things can affect HP when using inertia dynos (not a dyne in Steady State Mode) to measure power (what else would you do??:-): Changing to light, worn race rear tires will improve power output on an inertia dyno, but, not improve real world top speed. A heavier (brand new street) tire that replaced the above, light, worn tire, will decrease measured power on an inertia dyno, but not decrease real world top speed. Lighter wheels are a good thing! Better acceleration in lower gears, especially 1st and 2nd (accelerating less inertial mass!). Better handling is possible, too! Driving hard on worn, light tires is foolish and is not being recommended.
Problems with Inertia dyno test procedure and fuel injected vehicles: A Sweep Test (hold throttle wide open and sweep from low rpm to high rpm) will often trigger the Acceleration Fuel Map, along with the Main Fuel Map, causing the fuel mixture readings to indicate dyno operator that the motor is overly rich. This would cause the tuner to lean out the main fuel map. Of course, in the real world, upper gears, the acceleration rate of the engine is much slower than what they tested, doesn't trigger the Acceleration Fuel Map, and the engine ends up a lot leaner in reality in top gear. It's not that common of a problem, since most people never drive that fast for that long to cause engine damage. Work around: Tune full throttle fueling in real world usage at dragstrip (to best trap speed) or in Steady State Mode on different dyno.
You can optimize tuning for a DJ dyno and make big numbers - and you can tune the engine to make the best power under load on a load bearing dyno and blow off the big DJ dyno numbers. Can a tuner cheat and make a load bearing dyno read higher? The only way that could happen is in a Sweep Test - Sweep Tests are the least reliable of all tests, period. There is NO question about that. Since the Rotating Mass is a variable in a Sweep Test (NOT a Steady State Test!), the actual inertia factor entered affects the final HP figure - Tell the software that the vehicle has a lot of rotating mass to accelerate, and the HP number increases. (torque, rpm, acceleration rate and mass are the factors) - just like DJ dyno ignoring the difference in mass of all cars - So - true HP, again - Steady State Test - No acceleration, mass makes no difference, anymore. Torque, RPM and dyne parasitics. Period. True. Can you make a Steady State Test read higher? Really hard to do - The software will NOT take data unless speed and load are completely stable - eliminating cheating. As far as atmospheric conditions making a +/- 10% difference? Unless you REALLY mess with the barometric pressure (and you can look at every atmospheric factor on the test report sheet - it's hard coded to display - and not an option), it is simply, absolutely impossible to do without obvious evidence. Are final tuning optimal dyno settings different on an Inertia dyno vs. a load bearing dyno? For many reasons, final tune settings are different - and, since most load bearing dyno's will do both , there is a choice of tests - from a DJ style Sweep Test to Steady State. Having a choice of those types of tests to do and seeing what the results on the track are, most tuners will choose the Steady State Test over a Sweep Test. Without a doubt - the Steady State test Mode is the most consistently superior method of tuning - anybody who has the capability to do it will echo that sentiment - it's only an arguable point with those who can't do it properly. One of the reasons why the load bearing dyno will provide settings that work better in the real world is that combustion chamber temperatures are more in line with the actual operating temperatures that the engine.
Does altitude make any difference at all in horsepower? The engine couldn't give 2 hoots at what altitude it is tested at - it only cares what the air pressure, temperature and humidity is. Sea level at 28.02 inches baro is exactly the same as 4000 ft at 28.02 inches, as far as the engine is concerned. When tested at 5000 ft, we get virtually exactly the same power (corrected to atmospheric conditions, of course) as we do at sea level - It's just about 24%-25% less on the track! I am confused why some dyno operators insist on putting altitude on their charts and swear that it's a factor.
Crankshaft horsepower vs. true rear wheel horsepower. That's a tough one. As each vehicle is different, the best way is to dyno the engine and then dyno the vehicle to see exactly what the loss is. The best estimate I can give you based on experience and research is take crankshaft horsepower, subtract 14.5% ( search SAE ), take that, and subtract around 10% to 15% and you'll get about true horsepower at the rear wheels. The actual formula contains a curve for power loss through gears and there's another curve for power lost in a tire. Remember, too - that unless you dyno your engine you are only likely to get a crankshaft number from the manufacturer and that's probably a "good" one that the marketing department is providing.
ninja250r81 is offline   Reply With Quote
Old June 19th, 2012, 07:10 AM   #10
tubarney
ninja250r81
Are you trying to suggest that the engine was removed from the bike, placed in a controlled laboratory with a controlled environment and the Horsepower measured at the crankshaft. The engine was never removed from the bike and the rear wheel outputted the force.
Without getting complicated, Horsepower is a measure of power which is a measure of work. Work=Force*distance/time
The force in my situation was applied by the rear wheel on the dyno wheel.The 32.2Hp is rear wheel horsepower.
and for your post. Race fuel seriously wtf.
Old June 20th, 2012, 03:11 AM   #11
ninja250r81
"Are you trying to suggest that the engine was removed from the bike, placed in a controlled laboratory with a controlled environment and the Horsepower measured at the crankshaft. The engine was never removed from the bike and the rear wheel outputted the force."
nope
"Without getting complicated, Horsepower is a measure of power which is a measure of work. Work=Force*distance/time
The force in my situation was applied by the rear wheel on the dyno wheel.The 32.2Hp is rear wheel horsepower"
yes you are right.
if you dyno your bike where i live it would be 31.14hp
watch topgear uk bolivia special might explain what altitude does to a motor
"race fuel" jog my memory
Old June 21st, 2012, 07:23 PM   #12
RaceBikeRentals
Pimpin
RaceBikeRentals's Avatar
Motorcycle(s): Bunch of em
I've tried telling many racers this, but they always look at me like I'm nuts. Its definitely unconventional wisdom.
-Richard
MotoList.com <<<List your stuff!
RaceBikeRentals is offline   Reply With Quote
300 two brothers dyno ichw 2013 - 2017 Ninja 300 Tech Talk 1 May 3rd, 2014 04:54 PM
Ninja 300 Dyno Exhaust Test Results skagit Ninjettes At Speed 5 July 12th, 2013 01:01 PM
Jetting, Dyno Tuning, AFRs??? Help A Jiglet Out Jiggles 2008 - 2012 Ninja 250R Tech Talk 134 November 3rd, 2012 10:10 PM
Dyno Charts with jetting and stock exhaust? KURT 2008 - 2012 Ninja 250R Tech Talk 5 February 27th, 2011 10:03 AM
Dyno (re)Tuning Mods (with problems) vs Stock - Video and Graphs TheDuck 2008 - 2012 Ninja 250R Tech Talk 5 May 9th, 2010 02:27 PM
