March 13th, 2013, 09:33 PM | #1 |
Join Date: Jan 2013 Motorcycle(s): 2009 Kawasaki Ninja 250R Posts: 166
KX250 shift shaft replacement
I know this is not a ninja, but the bike is still a kawi, and a 250 cc engine!
The splines on the shift shaft are stripped to the point that the shift lever can no longer grip and turn the shaft, and thus, no longer shift the transmission. Does anyone know of a good how to video/step by step guide on replacing the shift shaft on this bike or similar? It's something I'd like to try myself but want to know what I'm getting myself into. |
March 13th, 2013, 09:36 PM | #2 |
If I couldn't get the piece to fit on the splined shaft of the motor, I would either find a second one of those little brackets and weld it on, or grind the piece down square and make a new bracket. Or, maybe cut a keyway into the shaft and put a key in the bracket.
Another guy on this forum had a bike that had a rounded shaft and the shifter just would not grip it. He ended up just welding it.
Motorcycle noob, feel free to ignore me. |
March 13th, 2013, 09:37 PM | #3 |
you are talking about the external shift shaft and links. you take off the clutch cover and clutch and the rod slides out the right side. but you shouldn't really need to replace it. just repair the end. its not exactly high precision
March 13th, 2013, 09:39 PM | #4 |
So how would you repair the end? Trace the splines with a little cutoff wheel on a Dremel tool?
March 13th, 2013, 10:06 PM | #5 | |
Not sure how I would go about welding it, I did at one point attempt to do a half assed job with some JB weld which simply did not hold at all. Drilling straight through the shaft and lever and just bolting the two together could work. The bike is old and beat up anyway, doesn't have to be a clean job. |
March 14th, 2013, 06:00 AM | #6 | |
March 17th, 2013, 10:55 AM | #7 |
Join Date: Nov 2012 Motorcycle(s): Ninja 300, KTM EXC610SMR Posts: 913
I raced a full season + on a 88 CR125 with a steel shifter welded to the stripped shaft. It was a $5 weld at a local shop. Clean it up free of oil, grease, paint & dirt. Should take all of 10 seconds to weld it on. If it has to come apart, you grind off the weld, the shaft is shot anyway. We took it off and welded it back on to swap a leaky seal. No big deal.
shift shaft seal | BukkShot | Items Wanted | 4 | March 21st, 2015 10:35 PM |
Transmission output shaft replacement | Mulholland | 1986 - 2007 Ninja 250R Tech Talk | 10 | April 12th, 2013 08:21 AM |
Is this shift shaft damaged? | indr | 2008 - 2012 Ninja 250R Tech Talk | 4 | January 5th, 2013 05:49 AM |
shift shaft oil seal replacement | lolibater | 1986 - 2007 Ninja 250R Tech Talk | 20 | October 10th, 2012 04:22 PM |
Anyone replace a shift shaft seal. | zzrguy | General Motorcycling Discussion | 3 | March 18th, 2012 09:32 AM |
