Old April 22nd, 2012, 12:37 AM   #1
jschatte
jschatte's Avatar
Motorcycle(s): 1988 Ninja 250
Problems getting bike running
HI, I would like to say ninjette is a great resource, I have done quite a bit of work on my 87 ninja to help it get running again. It has sat for a while so i kind of assumed worst case scenario and went over everything.
So far I have:
-Changed Oil & filter
-Installed new spark plug wires and plugs
-Adjusted valves (intake 0.004" and exhaust 0.005")
-Cleaned Carb
-Relined gas tank (was very rusty)
-Rebuilt petcock
-Replaced all fuel and vacuum lines, and installed a new inline fuel filter.
So with high hopes me an another member who has been working on the bike with me @Csmith9, we turned over the bike and it did not start! However it did kick over when I sprayed carb cleaner into carb 2, but not when i sprayed it into carb one.
-I know i have spark, i pulled both plugs and checked for spark
-I know I have fuel, I pulled the fuel line and when turning over fuel pours out of the line (both in reserve and on)
-I know we have vacuum, and resultantly air, because the petcock works.
SO this is where I am confused. I am pretty sure the problem is with the carbs, so I took them off. Initially I noticed two things, the gas has a yellow tint to it from the gas tank lining. Also the floats were set at 15mm, so I moved them to 17mm. Other than that I feel the carbs are pretty good, I cleaned the jets and sprayed carb cleaner through all the passages. I did not "wire out the passages" on the carb itself, perhaps this is also a problem?
Anyway this is my problem, I am pretty sure its something that can be figured out, so I am looking for help! any advice would be appreciated!
jschatte is offline   Reply With Quote
Old April 22nd, 2012, 07:12 AM   #2
"A"
vampire
Motorcycle(s): 2 many 2 list
The the kill switch on?
"A" is offline   Reply With Quote
Old April 22nd, 2012, 07:55 AM   #3
mrcrunch
Motorcycle(s): 2007 250r
I always remember from my dirt bikes as a kid:
If you have spark and you have fuel, it's the timing.
We used to use a straw to drop fuel directly in the cylinder (after pulling the plugs to verify spark). If it fired for a moment, then you had a fuel delivery problem. If not, you had a timing problem.
Those were two-stroke motors, not sure if that matters. We were ignorant to compression issues back then, too.
mrcrunch is offline   Reply With Quote
Old April 22nd, 2012, 12:00 PM   #4
jschatte
jschatte's Avatar
no, if the kill switch was on it wouldnt even turn over!
Hmm yes It could be the timing, Ill give that a check too. The basic tests dont really vary much from 2 to 4 strokes i would assume.
Old April 22nd, 2012, 12:31 PM   #5
"A"
vampire
My 04 Ninja 250's starter/engine cranks with the kill switch on, so does my 01 Super Sherpa 250... some times people miss the most obvious, just trying to help.
Old April 22nd, 2012, 12:34 PM   #6
jschatte
jschatte's Avatar
No I do appreciate the help. However I checked the spark and I had spark, which is a very good indication the kill switch is not on.
New bike with new problems. manorat 1986 - 2007 Ninja 250R Tech Talk 20 March 23rd, 2022 03:31 PM
Problems Starting running a bike danius 2008 - 2012 Ninja 250R Tech Talk 0 October 28th, 2010 05:39 AM
Having power problems while running track speeds... NorCal_250R Ninjettes At Speed 13 July 20th, 2010 11:53 AM
Bike has problems running.. hieuster 2008 - 2012 Ninja 250R Tech Talk 3 June 19th, 2010 06:19 PM
Problems running, seems very rich? maxedpenny 2008 - 2012 Ninja 250R Tech Talk 7 June 30th, 2009 08:51 PM
