Old July 29th, 2013, 06:53 PM   #1
jhap2009
Motorcycle(s): Ninja 250R
swing arm swap
Wondering if any body knows if the klx250s swing arm could swap onto our frame as being you can fit a 160-170 rear tire between it.
jhap2009 is offline   Reply With Quote
Old July 29th, 2013, 07:04 PM   #2
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
You won't get much help around here with wide tires, or extended swing arms... Those threads don't last long at all :/
Lemme know what ya figure out though.
Old July 29th, 2013, 07:23 PM   #3
Originally Posted by JohnnyBravo View Post
... wide tires, or extended swing arms...
Sometimes referred to as mods.
Old July 29th, 2013, 07:26 PM   #4
JohnnyBravo
Hahahaha I'd hate to hear that's how we ride in Florida again, that's always a mess. But idk where these folks live in fl... I see wide tire extended bikes daily!
Old July 30th, 2013, 12:25 AM   #5
jhap2009
I'm attempting a one off cafe racer with my bike I wanted to put a wider tire in the back to make it look a lot more aggressive, I'm sure that the klx250s swing arm will swap over I was just wondering if any body else attempted something similar to this.
Old July 30th, 2013, 08:33 AM   #6
JohnnyBravo
Sounds cool... Idk some folks around here built cafe's though.
Old July 30th, 2013, 08:43 AM   #7
jhap2009
I know I saw Ivanrules build thread and that bike looks effin amazing. That is kind the look I want to go with but with a wider rear tire and a completely custom exhaust. When I build the rear seat pan I will also be doing the tail light and turn signals differently.
Old July 30th, 2013, 10:02 AM   #8
chris21er
626ER
chris21er's Avatar
Motorcycle(s): 08 Ninja 250
Careful around here everyone will knock you down real quick instead of leading you in the right direction its your bike do what makes you happy but I have no info in swing arm
08 Kawasaki Ninjette 2fitty
chris21er is offline   Reply With Quote
Old July 30th, 2013, 10:47 AM   #9
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
Have you actually seen, or heard of this mod being done? I own a klx250sf and just took some rough measurements of its' swingarm compared to the one on my 300. They aren't even close, the klx swingarm is skinnier and shorter than the one on the 300 which is probably the opposite of what you are wanting. Ninja 300 and 250 share the same swingarm btw.
I have a 150 on the back of my klx and there isn't much room back there, I've seen some people squeeze a 160 on there, but I doubt you could get a 170 to fit.
Old July 30th, 2013, 11:34 AM   #10
jhap2009
Not necessarily the klx swing arm but I have heard of them swapping other swing arms for wider tires, I just figured being they were both kawa 250 they would be an easier swap. I thought the factory nobbys were a 150 to begin with making more than enough room for a 160 to fit.
Old July 30th, 2013, 11:59 AM   #11
ninjamunky85
Que Buenos Son!!!
MOTM - Nov '14
Dunno about knobbies, the klx250sf came with street tires, 130 in the rear. You can fit a 160 on there but it's a tight fit. You'd have a harder time getting the swingarm to fit correctly. The only swaps for the ninjette that I have heard of is from an Aprillia or the aftermarket.
Old July 31st, 2013, 07:18 PM   #12
Runeknight95
Motorcycle(s): 08 cbr1000rr, 2008 + 2012 ninja 250, 06 zx6r (636!) track only
I wouldn't touch an extended swing arm if it was free!!!!!!!
Runeknight95 is offline   Reply With Quote
Old August 7th, 2013, 07:05 PM   #13
cerberusrex25
Accesories Guru
cerberusrex25's Avatar
Motorcycle(s): '99 EX250(Cafe/fighter project)
08+ ninjette swing arm bolts right on and allows for a 150 rear tire( I know, I have one on right now).
cerberusrex25 is offline   Reply With Quote
Old August 8th, 2013, 12:17 AM   #14
jhap2009
I have an 09, I just wanted to put a 160-180 size to lookmore aggresive for a caferacer/street fighter.
Old August 8th, 2013, 04:49 AM   #15
DaBlue1
DaBlue1's Avatar
Get a bigger rim and put 160/60/17 tires on it. http://www.ninjette.org/forums/showp...&postcount=120
Old August 8th, 2013, 08:51 AM   #16
jhap2009
Holy cow that is some superbclose clearances, to close for comfort, but that is a solution so thank you.
Old August 8th, 2013, 09:29 AM   #17
DaBlue1
DaBlue1's Avatar
....Holy cow that is some superbclose clearances, to close for comfort...
Think that's close? Have you looked at the clearance on any supersport? Also either a smaller front or smaller rear sprockets slide the wheel back a little. You'll have plenty of room.
Old August 8th, 2013, 05:50 PM   #18
cerberusrex25
Accesories Guru
I guess you could put a 160 in it, maybe get the sportisi 4.5 rear wheel for it?
Old August 8th, 2013, 06:04 PM   #19
Uh, what?
Old August 9th, 2013, 04:14 AM   #20
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Maybe you take a look here http://motor-dan-sekuter.tokobagus.c...-17163845.html
If you're looking for any part the best step would be to look in Indonesia, there you find the biggest market for the 2-fiddy.
Old August 9th, 2013, 09:20 AM   #21
jhap2009
That looks pretty awesome, the swingarm looks a little short, now if I could some how get it translated into english.
Swing arm rodster 2008 - 2012 Ninja 250R Farkles 11 February 10th, 2015 03:50 PM
Custom swing arm Racer x 2008 - 2012 Ninja 250R Tech Talk 7 August 5th, 2010 08:58 AM
