Old April 1st, 2019, 11:26 PM   #1
lavarsios
Motorcycle(s): Ninja250r
250sl hugger for 250r?
Hello team,
I was wondering if anyone has tried ninja's 250sl hugger (pn:36014-0562) fitting it in the r version.I guess it won't be plug and play but if it is easily modded i guess i should give it a try.Cost is around 30euro.Also my rear is 150/60/17 will it fit?
lavarsios is offline   Reply With Quote
Old April 2nd, 2019, 05:11 PM   #2
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
Just looking at the parts diagram, it looks like it uses the same mounting points on the left side. You could probably drill and tap a hole in the crossbrace for that one. It looks like there's a couple extra tabs on the right side for it to mount to. You may be able to rig something up - I believe people were using zipties on the right side with the Byson hugger.
The 300's mini-hugger chainguard mounts on the 250 swingarm with just a couple extra holes. This one might not be too different either.
The Z250SL's trellis frame is obviously quite different, but the swingarm looks pretty similar (along with a number of other parts). If you wanted to go that far, you might be able to swap the whole swingarm in to get all the correct mounting points.
Old April 5th, 2019, 07:53 AM   #3
akima
Nooblet
akima's Avatar
MOTM - Oct '13
I don't know about that hugger, but a bunch of people on this forum have successfully fitted a Honda CBR250R hugger to the Ninja 250R (2008+). It's cheap and looks great. You just have to cut a small bit of plastic off of it and use strong zip ties to hold it on the bike. Here's one of the threads on it:
https://www.ninjette.org/forums/showthread.php?p=967120
[visordown.com] - Kawasaki Ninja 250SL and Z250SL unveiled Ninjette Newsbot Motorcycling News 0 November 4th, 2014 03:00 AM
