Old June 19th, 2010, 05:44 PM   #1
hieuster
hieuster's Avatar
Motorcycle(s): 2009 Kawasaki Ninja 250r
Bike has problems running..
It's has been months since I've ridden the bike and today I started it up, it will stop running without the prime. Even with the prime on, if I give it gas it will die. Also, while it is on prime, the rpms goes up and down from 1k-3k. Do you think it's a gas problem or carb problem? I also checked the shimmed needle and it has this light green residue on it... is it normal?
hieuster is offline   Reply With Quote
Old June 19th, 2010, 05:45 PM   #2
huh? you mean on the needle itself? got a pic?
it does sounds like a fuel/carb problem, though.
Old June 19th, 2010, 05:56 PM   #3
hieuster
hieuster's Avatar
Yes, on the needle itself. Unfortunately, I don't have a pic of it. I was trying to open up the otherside to take a pic of it, but kind of stripped the screw. I think I might as well take the entire carb out and clean it, hopefully it will fix the problem.
Old June 19th, 2010, 06:19 PM   #4
well, green on the needle is not normal.
sounds like your pilot circuit is gummed up from gas in the carb bowls from sitting. I would recommend, draining all gas out of your gas tank, drain the gas out of your carb bowls, fill the tank with a gallon of fresh gas and healthy dose of seafoam (3-4 ounces). If you're lucky and the gas hasn't gone so bad that it's hardened and blocked the pilot jets, you may be able to soften up the gummed up crap in the carb bowls with the gas/seafoam mixture which would eliminate the need to remove the carbs.
New bike with new problems. manorat 1986 - 2007 Ninja 250R Tech Talk 20 March 23rd, 2022 03:31 PM
Problems getting bike running jschatte 1986 - 2007 Ninja 250R Tech Talk 5 April 22nd, 2012 12:34 PM
Problems Starting running a bike danius 2008 - 2012 Ninja 250R Tech Talk 0 October 28th, 2010 05:39 AM
Having power problems while running track speeds... NorCal_250R Ninjettes At Speed 13 July 20th, 2010 11:53 AM
Problems running, seems very rich? maxedpenny 2008 - 2012 Ninja 250R Tech Talk 7 June 30th, 2009 08:51 PM
