Old May 4th, 2010, 05:36 AM   #1
schneider_11
schneider_11's Avatar
Motorcycle(s): Ninja 250 SE 2009
Slip-on: when to change
Hy guys.
I tried to search these topics but couldn't find anything, sorry if it's allready been posted before.
I want to install the MGP Growler slip-on on my bike, just have 2 quick questions:
1- I only have 1000 miles on my bike. Is it ok to install the slip-on now or sould I put on some more miles ?
2- My bike is the FI model. Does it need any modifications/tuning after the install ? (like the rejet/jet kit on the carb. models ?)
Thanks.
schneider_11 is offline   Reply With Quote
Old May 4th, 2010, 08:32 AM   #2
sofo
sofo's Avatar
Hi Joćo,
To answer your first question, you can put the slip-on on your bike anytime. Some bikes come from the dealer with a slip-on, so there is no problem putting it on before you are through the break-in period.
Alas I am not sure enough to answer your second question.
sofo is offline   Reply With Quote
Old May 6th, 2010, 04:46 AM   #3
schneider_11
Thanks Andrew
Old May 6th, 2010, 06:28 AM   #4
tabogon
Motorcycle(s): 2010 Ninja 250R (Metallic Island Blue)
You should be ok without any modifications if the 250's ecu works identical to a car ecu (not sure, mine's carb'd). If it does work like that, the ecu will take up the slack and even out the air/fuel mixture.
However, you won't get as much, if any, performance gains from it because the ecu is going to adjust itself to as close to the factory perameters as it can. It should be perfectly fine running the bike this way, but for best performance you should look into modding the ecu (if you even can) or read up on adjusting the air/fuel mixture for best performance.
Last ditch effort, take it to a dealership to dyno tune.
tabogon is offline   Reply With Quote
Old May 8th, 2010, 06:52 PM   #5
All cars have closed-loop FI that work exactly as stated here, many bikes do not and can only run open-loop. I don't know if the FI ninjette has an O2 sensor or related sensors to compensate for changes to the can. It may, but it may not. I do know that folks have put on PowerCommanders to modify the mapping.
Old May 10th, 2010, 01:39 AM   #6
karlosdajackal
karlosdajackal's Avatar
Motorcycle(s): Ninja 250R Fuel Injected Model 2009
I "believe" there is a sensor of some kind in the exhaust just before the end of the header pipe, I've seen it on mine, but I can't get a pic of it for at least a couple of days. You can see it if you look in the front fairing and follow the exhaust back. I don't know if this is a temperature thing or an O2 sensor. Do the Carb bikes have this same wire going into the exhaust? If not I'd say its probably the FI sensor.
The FI bikes have an extra light on the dash that lights up when the FI detects an issue so it can definitely sense something. I know Leo Vince do a slip-on and full system for the FI model and they have a fast fuel module. According to this link for their slip-on no fueling adjustments are needed, so I'm guessing that must be an O2 sensor in the stock header pipe.
http://www.superbike.co.uk/products/...ws_266854.html
The power commander and fast fuel module are more about adjusting the powerband and getting rid of flat spots, mostly caused by manufacture tuning to pass emissions tests, a lot of bikes have a flat spot around the point where the emissions are measured. I think for these systems you would need to disconnect and bypass that sensor so that the onboard FI didn't override what the power commander was trying to do
(PC adds more fuel, FI sensor detects a rich condition, FI cuts fuel)
I think you'll be fine with any slip-on.
While my post is made up mostly of guess work, I still hope it helped
My vlogs on Youtube are here
karlosdajackal is offline   Reply With Quote
First Oil Change Ravenger 2013 - 2017 Ninja 300 Tech Talk 7 November 7th, 2012 07:47 PM
Sprocket Change W.Roworth General Motorcycling Discussion 10 November 5th, 2012 08:03 PM
sprocket change sacreyc Help 3 July 12th, 2011 05:11 PM
how do you know when to change your tires? maxwellca21 General Motorcycling Discussion 14 February 17th, 2011 02:47 PM
