May 4th, 2011, 07:36 AM | #1 |
Join Date: Apr 2011 Motorcycle(s): 2010 Ninja 250 Posts: 38
Felt like a pop
Ok so I was on my way home from work last night on the Suncoast Parkway doing 70MPH when I feel something that felt like a pop. Then the bike feels like I'm getting a flat tire so I pull over but no flat?? So I start heading home again and the bike now feels very loose and wobbly, almost like riding a bicycle that almost has a flat tire. I made it home doing 15MPH (that sucked).
My T-Rex stands are going to be here this Friday anyone have suggestions where I should start looking or what it could be? |
May 4th, 2011, 07:52 AM | #2 |
MOTM - Mar '13, Jun '14
If your tires are still up to pressure start looking at your suspension. Was the "pop" a bolt braking on your shock? Did the rear axle loosen and move out of alignment?
May 4th, 2011, 07:53 AM | #3 |
Check your tire pressure first. If they are over inflated, there could be damage to the tire but still holding air. Check the rear axle bolt also to make sure it is torqued to spec. May want to check the front tire too just for good measures. If it is still under warranty, you may want to consider having the dealer look over it. Good luck!
May 4th, 2011, 08:54 AM | #4 | ||
The suspension was the first thing I was going to check when my stands show up. I was also thinking that the pop might have been a bolt breaking when the tires looked fine. Once my stands arrive I can check to make sure there’s no tire damage that I can’t see but the bike only has 1200 miles on it. It is definitely still under warranty so I guess if something does not jump out at me I will take it to the dealership. It’s just weird that when stopped and I’m pulling and pushing on things nothing seems loose but that all changes when you start riding. Last futzed with by bp328i; May 4th, 2011 at 12:36 PM. |
May 4th, 2011, 09:51 AM | #5 |
Could have been road debris too. You just want to check over the bike prior to riding just to be sure things are cool.
May 4th, 2011, 11:27 AM | #6 |
Wartown, USA
Join Date: Nov 2009 Motorcycle(s): 2009 Ninja 250R SE, 2007 Ninja 650R, and assorted other bikes Posts: A lot.
Are you running radials? Could be one of the radial bands snapped in the tire....which would also explain the funky wobble.
May 4th, 2011, 11:47 AM | #7 |
May 4th, 2011, 12:17 PM | #8 |
Join Date: Aug 2010 Motorcycle(s): 2007 ninja ex500, 2010 Ninja 250r, 2004 zzr600, 2003 CBR600rr, 2013 Ninja 300...in that order :D Posts: 266
May 4th, 2011, 12:32 PM | #9 | |
The road I was on is pretty new and in good shape. It's the newest part of the Suncoast Parkway heading up to Hudson/Spring Hill area. |
May 4th, 2011, 12:38 PM | #10 |
what's your tire pressures?
May 4th, 2011, 12:43 PM | #11 |
May 4th, 2011, 12:48 PM | #12 |
I'd check them first before looking for any other problems.
it may not be the problem, this time, but you do realize you should be checking them before every ride, correct? |
May 4th, 2011, 01:09 PM | #13 |
Join Date: Nov 2010 Motorcycle(s): GreenSE 09 250R Posts: 247
I also had a pop sound pulling into a 7eleven about 2 months ago. Mine ended up being a busted fork seal I started to have a small amount of oil run down the fork. Made the front end kinda squishy.
May 4th, 2011, 01:22 PM | #14 | |
If I check them before I leave my house in the morning they are 28/32 and after sitting in sun all day at work before heading home they will be 30/34. |
May 4th, 2011, 01:24 PM | #15 |
I will be looking at this first thing when I get home as I can check this before my stands get here...Thanks!
May 4th, 2011, 01:26 PM | #16 |
Did you hit a cat and it popped and now cat guts are all over your tires making them squirm and feel mushy?
May 4th, 2011, 01:33 PM | #17 |
May 4th, 2011, 02:23 PM | #18 |
Ms. Personality
Would you do the same if CC stepped out in front of you?
May 4th, 2011, 02:32 PM | #19 |
Who is cc?
May 4th, 2011, 02:32 PM | #20 |
Ms. Personality
CC Cowboy
May 4th, 2011, 02:36 PM | #21 |
Sure, if they were carrying an animal.
May 4th, 2011, 02:41 PM | #22 |
Ms. Personality
haha... nice... Let us know what the issue is. I'm quite curious as to what happened. Good luck!
May 4th, 2011, 03:22 PM | #23 |
Does the bike feel stable when you sit on it or is it squishy even then? There really is only so many things that affect the "feel" of the bike. Tires + suspension and all the bolts that go with it. My guess is if the tires are good then it's the fork seals. When you felt the pop, did you run over a pothole or anything?
May 4th, 2011, 04:59 PM | #24 | |
As for the pothole, nope the road is great and there was no one in front of me. |
May 4th, 2011, 05:11 PM | #25 |
Wierd, check the preload and see if that changes the feeling. If the suspension gave out, if you bounce on it, you should be able to feel/hear a difference. I noticed a difference when I set the preload so if the suspension is dead, i would think you can tell. Tires are an easy check, I'm assuming you had the chance to check the pressures already?
May 4th, 2011, 05:18 PM | #26 |
Yep, all good on the pressure. I can't wait till Friday when my stands get here I can pull it apart.
May 4th, 2011, 05:20 PM | #27 |
May 4th, 2011, 05:25 PM | #28 |
May 4th, 2011, 05:26 PM | #29 |
how much chain slack to you have?
May 4th, 2011, 05:35 PM | #30 |
Just at 1 inch, I measured it right in the middle on the bottom.
May 4th, 2011, 05:39 PM | #31 |
that sounds about right... did you check that slack amount at several different places on the chain?
May 4th, 2011, 05:45 PM | #32 |
Yes and it seems consistent. I did just take a picture of something that does not look right. Give me one minute and I will post it.
May 4th, 2011, 06:03 PM | #33 |
Does this space look right?
May 4th, 2011, 06:16 PM | #34 |
looks right to me...
May 4th, 2011, 06:19 PM | #35 |
Thanks, guess I will just have to wait till Friday when I can get it up in the air. If nothing jumps out at me when it's apart off to the dealership we go.
May 10th, 2011, 08:11 PM | #36 |
Thank you everyone for the help. It turned out to be a broken spring perch. When I would sit on the bike and bounced up and down it felt fine but when there was any side to side stress the spring would move which in turn made the suspension give more than it should giving me the sloppy feeling.
The dealership said they have never seen one break before...just my luck... |
May 10th, 2011, 08:29 PM | #37 |
covered under warranty, I hope?
May 10th, 2011, 08:32 PM | #38 |
100%
May 11th, 2011, 09:02 PM | #39 |
The last time I had a pop and I nearly flew off the bike I pulled over to check the tires, nothing wrong. I then noticed the cap at end of swingarm had turned 90 degrees and that's what slammed into the bolt/nut of my rear sprocket. Apparently after having the tires put on at the dealership they didn't tighten the bolts good.
Checking your torques are just as important as the tire pressures |
May 14th, 2011, 08:57 PM | #40 | |
[motogp.com] - Crutchlow: “I felt confident riding” | Ninjette Newsbot | Motorcycling News | 0 | March 14th, 2015 03:30 PM |
Maaaaan... I felt sooo cool the other day.. | corksil | General Motorcycling Discussion | 93 | May 6th, 2014 10:50 PM |
Felt a Little Squidly | 1994juggernaut | Ride Reports | 1 | May 31st, 2012 06:03 PM |
Felt naked today... | DownByFive | General Motorcycling Discussion | 5 | March 9th, 2012 08:42 PM |
Hohoho felt soooo good. | blink | General Motorcycling Discussion | 1 | January 31st, 2012 07:03 PM |
