November 15th, 2012, 07:52 PM | #1 |
Nerd
Join Date: Mar 2012 Motorcycle(s): Ducati Hyperstrada Posts: 672
Dirtbike fell over, won't start now.
So i recently bought an 80cc two stroke dirtbike for cheaps.
I test rode it and it worked fine. 2 weeks later I go to use it in the desert, and it works fine. Hauls ass too. But then i do something dumb and fall over on it. After that, the darned thing will not start. I can kick it all day and it wont start, also bump starting does not work either. I checked the spark plug and put in a new one and saw it sparking. But will not start. Also there IS gas in tank, Fuel line flows freely when petcock is open. WTF is there to check? Help!!!!
It doesn't LOOK that steep. But you can go first... |
November 15th, 2012, 08:22 PM | #2 | |
For how long was the bike on its side? Nose down? Could something have moved, blocking the air intake?
November 17th, 2012, 06:18 PM | #3 |
Need more info
plug picture? wet or dry? If you have fire it would have to be fuel, Too much or too little. Assuming you have fire at the right time and compression. Thats it on a smoker. I have a 2 stroke LT 80 driving me nuts. I think it may be the petcock is bad and the needle valve seat is not sufficient to keep gas from filling the crank chamber up. The muffler had gas in it. Seen it happen before. That is my next plan on the LT anyway. |
November 17th, 2012, 08:49 PM | #4 |
#squid
Join Date: Jul 2011 Motorcycle(s): Track dedicated 2008 ZX6R Posts: A lot.
MOTM - Jul '16
How long was it on its side...?
Bike fell over (again lmao) and won't turn over | BoKing | 1986 - 2007 Ninja 250R Tech Talk | 5 | January 19th, 2015 05:27 AM |
Parked bike fell in mud and now idles low/won't start. | BoKing | 1986 - 2007 Ninja 250R Tech Talk | 9 | December 15th, 2014 03:28 PM |
Won't start | Espinoza07 | 1986 - 2007 Ninja 250R Tech Talk | 6 | September 14th, 2014 08:07 PM |
Good idea to start on a dirtbike? | IdRatherDrum | General Motorcycling Discussion | 45 | October 24th, 2012 09:52 PM |
Won't start | Momaru | 2008 - 2012 Ninja 250R Tech Talk | 15 | August 9th, 2009 09:48 PM |
