Old July 30th, 2014, 04:06 PM   #1
archaeofreak
archaeofreak's Avatar
Motorcycle(s): 2007 Ninja 250R
Just bought a 2007 Ninja 250 R with 15k miles...1 issue perhaps!
Hi! I just bought a ninja as stated in the title. I dont even have a license to ride yet, but I was just sitting on it familiarizing myself with the controls and I noticed that when I have it started (on the kickstand and in neutral), if I rev the engine with the throttle just a little bit, and sharply, the bike will die! It seems to bog a little bit too. If I give it a decent amount of throttle, it seems to run OK. It also idles OK-I had it running for about 5 minutes, and the first couple it was at 700 RPMs, and over 5 minutes went to about 1200 RPMs.
The fact that it dies when I give it just a little bit of throttle makes me worried it might need some maintenance like carb cleaning/rebuild or even valve adjustment before I start riding it (planning on the MSF course in a few weeks). I have no idea what the maintenance has been in the past. The owner I bought it from said they only had it for 1 month, and they bought it from the first owner, a female who used it to commute to work.
Does anyone have any insight on what could be causing the engine to die with just a little bit of throttle sharply applied at idle, but not when the throttle is turned more aggressively?
Thanks!!
archaeofreak is offline   Reply With Quote
Old July 30th, 2014, 04:18 PM   #2
Congratulations, Justin !!!
Please read these:
http://faq.ninja250.org/wiki/New_Riders
http://faq.ninja250.org/wiki/What_is..._at_startup%3F
http://faq.ninja250.org/wiki/Troubleshooting
Old July 30th, 2014, 05:30 PM   #3
Finesse
ran when parked
Finesse's Avatar
Motorcycle(s): Freeride 250R, KLX250SF, mopeds
MOTM - Sep '17, Dec '14
When your bike dies at idle when you give it throttle, is it warmed up yet? Mine used to sputter and die if I revved it at idle when it wasn't warm, but it ran fine otherwise. It didn't need a carb clean, just needed to be allowed to warm up.
Finesse is offline   Reply With Quote
Old July 30th, 2014, 05:44 PM   #4
M42
Wrench wench
M42's Avatar
Motorcycle(s): TWO HUNDRED FORTY EIGHT CUBIC CENTIMETERS (R.I.P.), SIX HUNDRED FORTY FIVE CUBIC CENTIMETERS
Are you using any choke?
M42 is offline   Reply With Quote
Old July 30th, 2014, 05:49 PM   #5
archaeofreak
I didnt use any choke because it started right up and ran when I pushed the engine start button. I let it idle and revved the engine occasionally but not past 5000k RPMs for about 5 minutes. The temperature gauge did not change though, but I assumed that was long enough to warm it up. Thanks for all the replies and help, and I am reading through the faq now as well!
Old August 10th, 2014, 06:29 PM   #6
archaeofreak
Another issue I noticed recently...a small oil leak from either he oil drain cap or filter bolt! I put it on the center stand overnight and no drips...put it on the kickstand and get 1 drip every couple hours or less...any ideas? bought used no idea of maintainable history! Just a bad washer/gasket or could this be worse-getting my license this weekend so may take to shop for once over afterwards...
Old August 10th, 2014, 07:37 PM   #7
ninjakuma
Stunts Extraodinar
ninjakuma's Avatar
Motorcycle(s): 1999 Ninja 250
Your engine is about to explode and you are going to have to get a new one. Most shops won't do it because labor is 500 hours and engines are rare.
Will backflip for tips
ninjakuma is offline   Reply With Quote
Old August 10th, 2014, 07:47 PM   #8
archaeofreak
OMG engines are rare! I knew it! I'll never find a replacement! ****! Lol
So, paranoid? Maybe the previous owner sucked at oil changes?
Old August 10th, 2014, 07:54 PM   #9
ninjakuma
Stunts Extraodinar
ninjakuma's Avatar
That could very well be. One of the first things to do when buying a used bike is to change the oil and filter. While you're waiting to take the course that's a good way to get acquainted with the ninjette! You can also see if there are any leaks, cracks or warpage on the parts.
Take off the seat and get to know the inside of the bike too, maybe check the air filter while you're at it. You are going to have to do all this stuff eventually
For what it's worth, my bike drips condensation from the exhaust occasionally and I tendto over lube my chain a bit and some grease also drips down.
The first time I did maintenance was a little clutch, but every time after that it is much fun to work on bikes.
buying 2007 ninja 250 with 600 miles james250ninja General Motorcycling Discussion 11 November 1st, 2017 04:50 PM
Just bought a 2007 ninja 250 dago 1986 - 2007 Ninja 250R Tech Talk 12 March 12th, 2012 06:35 PM
just bought a 2009 ninja 250r with 500 miles *Concerns venmichaels 2008 - 2012 Ninja 250R Tech Talk 15 August 19th, 2011 07:37 AM
2007 Ninja 500 (482 miles) Rochester New York pantera Motorcycle-related 1 February 22nd, 2010 12:43 PM
