Go Back   ninjette.org > General > !%@*#$%!)@#&!%@ I crashed!
Old March 14th, 2009, 01:58 PM   #1
NewNinja
Motorcycle(s): Kawasaki 250r (first bike)
Dropped Bike Need Help!
So I was going on a turn when suddenly the tire slipped on an oil puddle and I fell. Leaving the bike still in 1st gear. So I switched the kill switch and picked it back up. After that I couldn't start it unless I held on to the clutch. So I'm thinking its still on first gear. I try to switch it to neutral but it doesn't show up, it seems like no matter how I step on the clutch, I'm stuck on 1st gear. Any suggestions? Oh and I'm a newbie
NewNinja is offline   Reply With Quote
Old March 14th, 2009, 02:04 PM   #2
Sloppy2nds
just a n00b
Sloppy2nds's Avatar
Motorcycle(s): '06 R6/'08 250R
try clicking the shifter up with your hand with the bike off. may just be hitting it too hard and going in to another gear. Neutral doesnt take much its basically half a click up. Try this first.
Sloppy2nds is offline   Reply With Quote
Old March 14th, 2009, 02:28 PM   #3
NewNinja
Yeah, Thanks that really helped! I still have one problem though. When after I start it on neutral when I click the shifter down the neutral light goes away, but I'm still not on first. Until I click the shifter down again, is when I can actually let go of the clutch and feel the bike moving. So is it possible that I maybe skipped 1st gear and jumped to 2nd gear after neutral?
Old March 14th, 2009, 02:34 PM   #4
Sloppy2nds
just a n00b
Sloppy2nds's Avatar
the reason i actually had you try doing that with your hand was to show you how little it takes to get to neutral. The "N Light" is exactly that, just a light. After you click down from a red light slowly let go of the clutch and you should feel it click right into gear. I dont want to say youre not clicking into first hard enough but that maybe the case. Dont slam on it too hard though.....I dont think this is a cause from you dropping the bike, its actually a normal occurance especially on a newer bike. It will get better the more you ride. Hope this help and you understand as this is the best i can describe things.
Old March 14th, 2009, 02:35 PM   #5
NewNinja
Oh I see. Okay! That helped a lot. Thanks I really appreciate it :]
Old March 14th, 2009, 02:37 PM   #6
Sloppy2nds
just a n00b
Sloppy2nds's Avatar
no prob man.....ride safe
Old March 14th, 2009, 08:45 PM   #7
ajaygraci
Motorcycle(s): 2009 ninja 250r, black, carbon fiber full exhaust...2000 toyota 4runner
that sucks, did you do any fairing damage to your bike Danny?
ajaygraci is offline   Reply With Quote
Old March 16th, 2009, 07:50 AM   #8
BlueTyke
So slow I'm first!
BlueTyke's Avatar
Motorcycle(s): 06 Kawasaki Ninja EX250
Wow Danny. Glad your okay. Even if it was just dropped bad things can happen. Good luck! and welcome!
Learn from the mistakes of others, you cannot make them all yourself. Save yourself the trouble and Learn.
BlueTyke is offline   Reply With Quote
Dropped my bike... nvxdiz !%@*#$%!)@#&!%@ I crashed! 23 August 22nd, 2012 10:54 AM
Dropped Bike Raider24 !%@*#$%!)@#&!%@ I crashed! 7 June 19th, 2012 07:24 PM
Just dropped my bike hybridkid !%@*#$%!)@#&!%@ I crashed! 11 February 27th, 2012 05:23 PM
Dropped my bike... Cedilla !%@*#$%!)@#&!%@ I crashed! 21 July 3rd, 2010 05:05 AM
I dropped my bike! motorcycle_munge !%@*#$%!)@#&!%@ I crashed! 16 April 29th, 2009 06:21 AM
