Old January 23rd, 2024, 07:32 PM   #1
[ridermagazine.com] - 2024 Kawasaki Ninja 500, Z500, KLX230 S, and KLX230SM Review |
Kawasaki updates its 2024 lineup with a new Ninja 500 sportbike and Z500 naked bike using the 451cc parallel-Twin found in the sport-cruiser Kawasaki Eliminator. It has also updated the Kawasaki KLX230 S dual-sport and KLX230SM supermoto.  Related: 2024 Kawasaki Eliminator Review | First Ride  2024 Kawasaki Ninja 500 and Z500  Kawasaki adds to its […]
The post 2024 Kawasaki Ninja 500, Z500, KLX230 S, and KLX230SM Review | First Look* appeared first on Rider Magazine.
2024 Kawasaki Ninja 500 KRT Edition in Lime Green / Ebony
2024 Kawasaki Z500 ABS in Candy Lime Green / Metallic Flat Spark Black / Metallic Graphite Gray
Kawasaki adds to its Ninja family of motorcycles with the 2024 Kawasaki Ninja 500 and the Z500 naked version. These two new motorcycles come in standard as well as SE versions with special features, and they both include a 451cc parallel-Twin, new styling, a new LCD instrument panel, and a new seat shape.*
Engine | 2024 Kawasaki Ninja 500 and Z500
2024 Kawasaki Ninja 500 SE ABS in Passion Red / Metallic Flat Spark Black / Metallic Matte Dark Gray
The Ninja 500 and Z500 are powered by the liquid-cooled 451cc parallel-Twin found in the Kawasaki Eliminator sport-cruiser introduced last year. Adapted from the same engine found in the Ninja 400, this engine adds 52cc of displacement for better acceleration and performance at high rpm due to a lengthened stroke of 6.8mm. Also new to the 500s are a new crankshaft, connecting rods, and pistons suitable for the larger displacement. Additionally, the top ring land of the aluminum pistons now features a hard alumite treatment suitable for higher pressure.
The 451cc parallel-Twin powering the Ninja 500 and Z500 is adopted from the Kawasaki Eliminator sport-cruiser.
Chassis | 2024 Kawasaki Ninja 500 and Z500
The Ninja 500 and Z500 feature a trellis frame with the engine as a stressed member and with a supersport-style short-wheelbase/long-swingarm configuration. The wheelbase is 54.1 inches, and seat heigh is 30.9 inches. The Ninja 500 weighs 377 lb, while the Z500 with less bodywork comes in at 368 lb. Fuel capacity is 3.7 gallons.
2024 Kawasaki Ninja 500 in Metallic Spark Black / Metallic Flat Raw Graystone
Both bikes feature a nonadjustable 41mm telescopic front fork. In the rear is a bottom-link Uni-Trak suspension unit with five-step preload adjustability using an included tool kit. Braking power comes in the form of a single 310mm front disc gripped by a 2-piston caliper and a single 220mm rear disc with a 2-piston caliper. The star-pattern 5-spoke wheels help keep weight low.
2024 Kawasaki Z500 SE ABS in Candy Persimmon Red/Metallic Flat Spark Black / Metallic Matte Graphenesteel Gray
The Ninja 500 features an elevated position of its clip-on handlebars along with a slightly foot-forward footpeg placement for a relaxed rider triangle. The handlebar on the Z500 is taller and wider for a more upright riding position. Kawasaki claims the ergonomics on both bikes is intended to provide a balance between comfort and a sporty attitude to satisfy a wide range of rider needs.
Technology | 2024 Kawasaki Ninja 500 and Z500
Also new for the 500s is a high-contrast LCD instrument panel that displays odometer, gear position indicator, fuel gauge, dual trip meters, remaining range, current and average fuel consumption, coolant temperature, clock, connected device notification, service indicator, and the economical riding indicator. This last feature appears on the LCD screen to signal favorable fuel consumption conditions so that riders can optimize fuel efficiency.
Through Rideology the App, riders can access vehicle info, a riding log, smartphone notifications, a maintenance log, and the ability to share location and riding logs with other app users.
Styling | 2024 Kawasaki Ninja 500 and Z500
Styling is where the Ninja 500 and the Z500 diverge. The Ninja 500 features a redesigned front end and large-volume bodywork inherited from larger-displacement Ninjas, along with compact LED headlights, built-in front turnsignals, and an LED taillight with a new design.
2024 Kawasaki Ninja 500 SE 40th Anniversary Edition ABS in Lime Green / Pearl Crystal White / BlueThe Z500 features less bodywork, as well as a triple LED headlight configuration that acts as a styling focal point. The two upper headlights serve as low beams while the lower headlight acts as the high beam. The Z500 also features a new LED taillight.
The 2024 Kawasaki Z500 ABS features a triple LED headlight.
The SE versions of the Ninja 500 and Z500 add a variety of upgrades. The SE versions of both bikes feature a full color TFT display, a USB-C outlet, a radiator screen, frame sliders, a pillion seat cover, a tank pad, and knee-grip pads. Also included on the Ninja 500 SE is a large clear windscreen and Kawasaki’s Intelligent Proximity Activation Start System, which uses a key fob to allow riders to remotely release the bike’s steering lock and main switch. The Z500 SE comes with a smoke-colored meter cover.
Pricing | 2024 Kawasaki Ninja 500 and Z500
The 2024 Kawasaki Ninja 500 comes standard in Metallic Spark Black / Metallic Flat Raw Graystone for $5,299. The KRT Edition adds $200. The ABS version is available in Metallic Spark Black / Metallic Flat Raw Graystone, White Silver / Metallic Moondust Gray, or Passion Red / Metallic Flat Spark Black / Metallic Matte Dark Gray from $5,699-5,899. The SE ABS and KRT SE ABS versions come in Passion Red / Metallic Flat Spark Black / Metallic Matte Dark Gray for $6,399. The SE 40th Anniversary Edition ABS comes in Lime Green / Pearl Crystal White / Blue for $6,599.
2024 Kawasaki Ninja 500 ABS in White Silver / Metallic Moondust Gray
The 2024 Kawasaki Z500 ABS comes in Candy Lime Green / Metallic Flat Spark Black / Metallic Graphite Gray for $5,599, and the SE ABS version comes in Candy Persimmon Red / Metallic Flat Spark Black / Metallic Matte Graphenesteel Gray for $6,299.
All Kawasaki Ninja 500 and Z500 variations are available now. Visit the Kawasaki website for more information.
2024 Kawasaki KLX230 S and KLX230SM
2024 Kawasaki KLX230 S in Lime Green
The Kawasaki KLX230 S dual-sport and KLX230SM supermoto models, first introduced in 2020, also receive updates for 2024. The most notable updates for these two models are found in the chassis and the revised rear subframe, along with some other updates to the ABS system, styling, seat, and added smartphone connectivity.
Related: 2024 Kawasaki KLX300 and KLX300SM | First Look Review
Engine | 2024 Kawasaki KLX230 S and KLX230SM
The 2024 Kawasaki KLX230 S and KLX230SM are powered by an air-cooled 232cc Single.
Powering the KLX230 S and KLX230SM is an air-cooled 233cc Single with a bore and stroke of 67.0mm x 66.0mm. The long stroke offers good low-to-mid-range torque. The intake port is 4mm narrower for 2024 (now measuring 33mm) to help contribute to low-to-mid-range performance. These bikes use a 6-speed transmission with a 45/14 final gear ratio selected for a balance of road and trail riding.
Chassis | 2024 Kawasaki KLX230 S and KLX230SM
Both models ride on a high-tensile steel perimeter frame, and for 2024, the rear subframe has been redesigned to trace a lower line on the machine, allowing for longer wheel travel while maintaining good ground reach. Both bikes have a 53.7-inch wheelbase. Ground clearance on the KLX230 S is 9.5 inches, while on the KLX230SM it’s 8.7 inches.
2024 Kawasaki KLX230SM in Battle Gray
On the KLX230 S, a 37mm telescopic fork provides 7.9 inches of travel. A new Uni-Trak rear linkage shock allows 8.9 inches of travel and is preload adjustable. Additionally, a new aluminum swingarm is 2.6 lb lighter than the previous swingarm. The new chassis design has allowed for a lower seat height of 33.3 inches, and the sidestand has also been shortened to match the lower seat height.
2024 Kawasaki KLX230 S in Battle Gray
The KLX230 SM, designed more for on-road use than its KLX230 S brethren, uses a 37mm inverted fork up front with 7.4 inches of front wheel travel. Like the KLX230 S, the SM adds the Uni-Trak rear linkage shock with preload adjustability. For 2024, suspension settings were revised to create a more forward-leaning posture and increase rear wheel travel to 8.8 inches. To accommodate on-road riding, the SM comes with stiffer spring settings, and the off-road footpegs from the 230S are replaced with standard footpegs with rubber pads on the SM. The SM’s seat height is 33.1 inches.
The 2024 Kawasaki KLX230SM and KLX230 S feature a new compact LED headlight.
The 2024 Kawaski KLX230 S rides on aluminum wheels, measuring 21 inches in the front and 18 inches in the rear compared to the Kawasaki KLX230SM’s 17-inch front and rear wheels that are wider than the KLX230 S wheels. The dual-sport KLX230 S comes with a 240mm front petal disc gripped by a 2-piston caliper, while the supermoto KLX230SM uses a 300mm front petal disc and 2-piston caliper. Both bikes feature the same 220mm rear disc with single-piston caliper.
Technology | 2024 Kawasaki KLX230 S and KLX230SM
The KLX230 S dual-sport comes standard without ABS, and an ABS version is available, while the KLX230SM supermoto comes standard with ABS. The ABS unit has been updated for 2024 with a switch on the left side of the handlebar that can be used to disable both front and rear ABS. When the bike is turned off and back on, ABS returns to default.
Both bikes feature a new compact LED headlight and a redesigned two-toned seat with a flatter silhouette that allows more freedom of movement. Additionally, the bodywork has been smoothed over to eliminate some protruding parts. The 2-gallon fuel tank has also been redesigned.
The LCD display offers additional functionality through Rideology the App.
Also new for 2024 is smartphone connectivity through Rideology the App. The app gives riders access to vehicle information, a GPS-informed riding log, smartphone notifications on the LCD display screen, a maintenance log, and communication sharing with other app users.
Pricing | 2024 Kawasaki KLX230 S and KLX230SM
The 2024 Kawasaki KLX230 S comes in Lime Green / Battle Gray for $4,999 without ABS or $5,299 with ABS. The 2024 Kawasaki KLX230SM supermoto variant comes in Battle Gray for $5,599. Both bikes are available now.
Check out more new bikes in Rider’s 2024 Motorcycle Buyers Guide
[RideApart] - 2024 Kawasaki Ninja 500 And Z500 Bring A Little Boost To The Middleweig Ninjette Newsbot Motorcycling News 0 November 8th, 2023 11:51 AM
[cycleworld.com] - 2024 Kawasaki Z500 and Ninja 500 First Look Ninjette Newsbot Motorcycling News 0 November 7th, 2023 02:21 PM
[motorcycledaily.com] - Kawasaki Z500 and Ninja 500 Incoming (Bike Reports) (News) Ninjette Newsbot Motorcycling News 0 November 7th, 2023 12:30 PM
[ridermagazine.com] - 2024 Kawasaki Ninja ZX-6R Review*| First Ride Ninjette Newsbot Motorcycling News 0 October 4th, 2023 10:40 AM
[ridermagazine.com] - 2024 Kawasaki Ninja ZX-6R | First Look Review Ninjette Newsbot Motorcycling News 0 June 9th, 2023 02:51 PM
