Old January 13th, 2013, 07:12 PM   #1
justin_ninja
Motorcycle(s): 90 ninja 250
carb issue.
so i have cleaned the carbs the jets, and triple checked it all. my problem is that it will only idle about 3200 rpms and if i hit the gas too fast it will die or bog down. i just did valve adjustment on it and still same thing, also replaced the float needles and adjusted them to 17mm. i have the stock air box on it and stock exhaust and also new battery. i have messed with the air/fuel mixture and it is set at 2.5 turns. any ideas.................
justin_ninja is offline   Reply With Quote
Old January 13th, 2013, 07:26 PM   #2
Are you sure that your diaphragms are undamaged and are responsive to changes of engine vacuum?
Old January 13th, 2013, 07:33 PM   #3
justin_ninja
The slide move and when I hit the gas they open. Or are u talking about the one on the side of the carb with the vacuum lines to it?
Old January 13th, 2013, 07:50 PM   #4
Check this thread discussing a similar problem:
http://www.ninjette.org/forums/showthread.php?t=121809
Old January 13th, 2013, 10:59 PM   #5
justin_ninja
looked it over and the only thing i can think of the air/fuel screws are not adjusted right. so tomorrow i will be looking over them and adjusting them to see if i can get it to run any better,
anyone know if in out out to have more fuel ?
i have to use choke to get it to start when its warm.
Old January 16th, 2013, 08:54 PM   #6
justin_ninja
ok so i have dipped the carbs and it runs great above 3k but when it goes down to idle just dies, i have messed with the a/f now out 3 1/4 turns and it kind of wants to idle about 2k if i hold the throttle. if i give it any gas it will jump to 4k and then stay there for a min then drop down little at a time to quiting... unless i blip the throttle then it will go up to 4k and back down slow and stall if i dont give it more gas. im going to say that the jets are clean and can see threw them. the ports are clean from what i can tell, i can blow air threw them and when i dripped water in there the jet goes it comes out where it should in the carb im at a loss for whats going on.. help...............
Old January 17th, 2013, 06:39 AM   #7
Check that enough fuel is reaching the carbs.
It would be good to check the level inside the bowls.
Old January 19th, 2013, 06:09 PM   #8
justin_ninja
ok good news............ so after checking the valves yesterday and doing a little adjusting and today i put the tank back on and started it, after a few mins it settled down to 2k good sign, so i messed with the sync and air/fuel screws and it settled down to 1500...so it is idling ok if u ask me for now, i put all the parts i have back on and took around the block and i was surprised at how quick and fun this bike is, lags tell just after 5k then takes off like crazy. im so happy, and my job interview i had today went well...
Old January 19th, 2013, 07:16 PM   #9
Two good news about transportation and income.
Yet another Carb issue Foxrider64 2008 - 2012 Ninja 250R Tech Talk 7 October 2nd, 2013 09:38 AM
Strange Carb issue n4mwd 1986 - 2007 Ninja 250R Tech Talk 42 August 26th, 2013 06:05 AM
Carb issue zach 2008 - 2012 Ninja 250R Tech Talk 4 May 24th, 2013 10:54 AM
Possible Valve or Carb Issue? schmdty420 1986 - 2007 Ninja 250R Tech Talk 25 June 20th, 2012 09:12 AM
throttle or carb issue!!!!! danjaho 2008 - 2012 Ninja 250R Tech Talk 4 March 23rd, 2011 07:33 PM
