Old August 7th, 2023, 10:39 AM   #1
Amasomeday91
Motorcycle(s): 2004 EX250F Track Bike 2004 Ducati 749s Soon to be track bike
Airbox ducts
Mechanically inclined friends. Got the boots that go from the airbox to the carburetor and can't get them seated in the airbox for the life of me. They are "OEM" as in not actually OEM but theoretically the same size as the original equipment. Any tip/trick I'm missing? Maybe they're just the wrong size? Maybe wrong material and not stiff enough? Everytime I get 40-50% seated correctly and try to force the rest it all just shoves through into the airbox. 🧐
Amasomeday91 is offline   Reply With Quote
Old August 7th, 2023, 10:58 AM   #2
I did the airbox separation mod, so I can put the boots on, clamp them in place, then move the airbox forward and connect it.
https://faq.ninja250.org/wiki/Batter...r_carb_removal
Old August 11th, 2023, 10:16 AM   #3
Don't force things, make sure everything is lined up optimally at each and every step.
Clamp carbs-to-head rubber manifolds 1st so carbs don't move.
Then gently shove airbox towards carbs.
Reach in with long screwdriver and slide around rim of rubber boot to make sure it's overlapping on outside of carb all way around. If rim of boot is butted up to edge of carb, it won't go on and gets pushed into airbox.
Once boots confirmed overlapping carbs only on outside, then shove rest way on. Done!
Wouldn't hurt to lube outside of carbs with light layer of rubber grease.
Old October 11th, 2023, 05:11 AM   #4
eltel
Motorcycle(s): 2004 E250
I just did mine with genuine Kawasaki parts. It is a bit tricky alright but I just covered the groove in a diluted washing up liquid and worked it in. Getting your fingers inside helps to smooth it internally. I did remove the airbox to do it though which made it easier. (carbs were being rebuilt so the entire rear mudguard was off, battery off etc).
eltel is offline   Reply With Quote
take out airbox? Japowger 2008 - 2012 Ninja 250R Tech Talk 8 October 15th, 2018 04:50 AM
[roadracingworld.com] - Friday Product Feature: SharkSkinz Replacement Ram Air Ducts Ninjette Newsbot Motorcycling News 0 June 1st, 2018 12:19 AM
Airbox ducts to carbs tiggen 1986 - 2007 Ninja 250R Tech Talk 9 April 2nd, 2014 06:42 AM
