Old December 18th, 2012, 05:35 PM   #1
Jordan91
Motorcycle(s): None yet
danmoto digital gauges
What parts would I need to convert my gauges to this :http://www.dan-moto.com/DM_US/danmot...95pbdqodqpqos5 on an 08
Jordan91 is offline   Reply With Quote
Old December 29th, 2012, 04:15 PM   #2
Free bump
Old December 29th, 2012, 05:54 PM   #3
rawbert625
rawbert625's Avatar
Motorcycle(s): the cool ones
http://www.mickeywebpages.com/users/...e_Dia_v1.1.gif
For most of them you can simply just connect the wires with wire taps. For example you can tap the LG/BK wire with that of the gauge (corresponding to whatever the manual says). If you want you can go all out and make a harness on the guage that just directly connect to the stock one.
As far as I know the 2008 doesn't have a Coolant/Oil temp that sends a signal for display. You may have to buy an oil/coolant sensor. Maybe the manufacturer sells some.
Nice guage though. Wish I would've seen it when I bought mine.
rawbert625 is offline   Reply With Quote
Old December 29th, 2012, 08:35 PM   #4
skilletmo
InfoWhore
skilletmo's Avatar
Motorcycle(s): 2008 Ninja 250 StreetFighter ~~~~ 2005 KTM 450 EXC
you dont really need any parts, unless you want it to be clean wires and not one big clusterf*ck then you will need to buy an 9 male pin connector, 3 male pin connector, and male pins. It would be alot more convenient to do that then soldering the wires just in case you want to move back to your old gauge or a newer one. You will also need to connect the right wires which should be easy with this guide:
Oil: Blue/red (my Speedo had everything but the oil pressure... So that was empty on my connector)
High beam:red/black (in other 3 pin connector with the right turn signal)
N:light green
Speed: On cable for front wheel
water temp:red/yellow
fuel:light green/black
left turn:green
right turn:grey(on different connector with the High beam (3pin) )
back light multiple colors but in my case i didn't need that because mine ran on one led circuit.
power -:AKA ground wire black/yellow
power+:brown or red/blue (you can use either one) In my case i only needed one power + not many becuase mine was led and didnt need all those back light wires my original speedo had. Just one led light altogether on one wire.
rpm:black
spare power(power that is always connected to battery): You need to make your own, its very simple. Grab a wire long enough to go from your speedo to your battery and on one side put a connector for the harness and another a connector for the battery.
Everyone, go buy a dirtbike hurry
skilletmo is offline   Reply With Quote
Old December 29th, 2012, 08:37 PM   #5
skilletmo
InfoWhore
skilletmo's Avatar
the oil sensor and water will be connected but im not sure they will light up like said in post #3.
Danmoto Exhaust CoinSlot 2008 - 2012 Ninja 250R Tech Talk 308 April 23rd, 2014 09:43 PM
Danmoto digital gauge? peterpayne 1986 - 2007 Ninja 250R Tech Talk 7 January 25th, 2014 08:00 PM
DanMoto Xsavior 2008 - 2012 Ninja 250R Tech Talk 7 November 25th, 2012 09:39 AM
Pre group buy for digital gauges jonnyc 2008 - 2012 Ninja 250R Farkles 212 May 30th, 2012 07:44 PM
DanMoto Owners! aznboi250r 2008 - 2012 Ninja 250R Farkles 10 August 12th, 2011 07:59 AM
