Old June 22nd, 2014, 11:40 AM   #1
avp957
Motorcycle(s): ninja 250r
Ninja 250 bogging/stalling issue
Hi, i am recently new to the forum as i am 16 yrs of age and own a ninja 250r 2009, the only mod done to the bike was a new slip on danmoto gp. the problem with the bike is that it seems to stall or bog whenever i leave it out in the sun and heat for any period of time longer than 30 min. the bike used to do this to me with the stock muffler last summer before i installed the danmoto slip on, any ideas on what the problem could be? ( it idles fine until you drive it for a min or two then go to stop at a light or stop sign.
avp957 is offline   Reply With Quote
Old June 22nd, 2014, 12:04 PM   #2
Welcome to Ninjette.org, Domenic !!!
It could be related to the fuel feeding system.
The tank must be ventilated through the cap, which get clogged as years go by.
Then, you have interior mesh filters inside tank and another by the end of the fuel hose.
The petcock is vacuum activated; some leaks in the vacuum hose and no fuel flows down.
There are two float valves inside the carbs that should keep certain level of fuel inside the bowls, but again, those tend to go bad with the years, either leaking or getting stuck in the closed position.
Old June 22nd, 2014, 12:10 PM   #3
DaBlue1
DaBlue1's Avatar
Heat and humidity can ruin small amounts of fuel. Stop leaving the bike out in the rain and direct sunlight if possible. Use Star Tron to help combat ethanol related issues in your gas.
You may also want to shim the needles with the Dan Moto exhaust (highly recommended).
Old June 22nd, 2014, 12:25 PM   #4
avp957
thank you very much for the options on what it could be, i think it may be the venting because it makes a high pitch whistle when the gas cap is on
Old June 22nd, 2014, 12:36 PM   #5
DaBlue1
DaBlue1's Avatar
Originally Posted by avp957 View Post
.... i think it may be the venting because it makes a high pitch whistle when the gas cap is on
That's normal, it's suppose to do that. It is expanding gas vapors slowly leaving the tank.
Old June 22nd, 2014, 12:42 PM   #6
avp957
so the venting wouldn't be the issue? the bike is fine after it bogs and stalls i usually wait a minute and it starts right back up with no issues and runs fine until i leave it sitting in the heat again, i cant really avoid leaving it out, i use the bike as a daily commuter to school and for general transportation everywhere until winter.
Old June 22nd, 2014, 01:02 PM   #7
DaBlue1
DaBlue1's Avatar
Just make sure you open the gas cap before you start the bike up, after it's been sitting in direct sunlight all day in the heat. Shade helps a lot.
Old June 22nd, 2014, 01:10 PM   #8
avp957
okay thank you i will test this today, also should i get a stage 2 jet kit? will this help with fuel reaching the engine easier and with power?
and is this worth a try? http://www.kawiforums.com/ninja-250r...-pictures.html
Old June 22nd, 2014, 01:38 PM   #9
DaBlue1
DaBlue1's Avatar
..should i get a stage 2 jet kit? will this help with fuel reaching the engine easier and with power?
A jet kit will provide a small boost in power and eliminate any flat spots along the throttle range. Works better with an aftermarket drop in filter.
The gas cap mod works for some and for some it does not. Having it make noise should not be seen as a problem, but an indicator the your system is working properly. When it stops making noise is a sign the tank may not venting.
Old June 23rd, 2014, 10:13 AM   #10
avp957
thanks for the advice! no problems with starting today!! but the rpm's were dipping when i was stopped at a light after letting off on the throttle and i would have to blip it so it wouldnt cough
Old June 23rd, 2014, 10:27 AM   #11
Flying
Motorcycle(s): 2010 Ninja 250
Despite the slip-on I think your fuel mixture is running a little rich.
Check your air filter before spending any money.
Old June 23rd, 2014, 11:45 AM   #12
CajunNinjaR
ninjette coonass
Motorcycle(s): 08 ninja 250, 06 wr450f, x15 110, tiny 50
+1 on sounding a little rich, I concur. Check to see if the air mixture screws on the bottom of the carbs have been uncapped and the mixture richened up.
Posted via Mobile Device
CajunNinjaR is offline   Reply With Quote
Kawasaki Faces N.H.T.S.A. Inquiry Over Possible Stalling Issue - ECU Recall Somchai 2013 - 2017 Ninja 300 Tech Talk 88 September 27th, 2013 10:18 PM
[nytimes.com] - Kawasaki Faces N.H.T.S.A. Inquiry Over Possible Stalling Issue Ninjette Newsbot Motorcycling News 0 July 19th, 2013 02:10 PM
Ninja 250 stalling on hard breaking waffles666 General Motorcycling Discussion 13 August 16th, 2012 04:44 AM
Ninja 250 stalling Image5050 2008 - 2012 Ninja 250R Tech Talk 11 July 16th, 2012 04:12 PM
ninja 250 stalling at stop signs bikerchick Riding Skills 15 June 25th, 2012 09:52 AM
