Old June 15th, 2009, 10:50 PM   #1
headshrink
headshrink's Avatar
Slipping shift pedal tie-rod
I just changed my shift pedal (old one was bent from the kickstand incident), got it all adjusted, went for a ride, and right when I went to turn around.... I couldn't shift. I had to fix it in a parking lot (at 10pm)... sucks. As the title indicates, the nuts that hold the tie-rod in place had vibrated loose. I fixed it and headed home, only to have it happen again before getting all the way down the street. FRUSTRATING!!! I got it in my garage and tightened them down as good as I could, but am worried they might vibrate loose again tomorrow on my way to work. The service manual really doesn't address this. What can be done?
Old June 15th, 2009, 10:52 PM   #2
um... some loctite?
I've never had a problem with those nuts coming loose on my shift linkage, even after I've played with adjustments. Maybe you're not tightening them enough?
Old June 15th, 2009, 11:11 PM   #3
komohana
komohana's Avatar
Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock
when making the change to gp shifting and back, i made sure i tightened them things good and got me some torque stripe to put on the nut and rod to let me know if they were vibrating loose.
Remember when sex was safe
and motorcycles were dangerous?
komohana is offline   Reply With Quote
Old June 16th, 2009, 01:28 AM   #4
headshrink
headshrink's Avatar
yeah, i thought about getting some loctite, but $10 is breaking the bank right now.
*sigh* I guess if I can't get to work, it will only get worse... so I guess I'll charge it if I have to. I was worried I'd start burning the clutch since I had to start out in 3rd to get it home. Ninjette not happy.
I was tightening them BTW, as much as I could with the tools I had anyways. They are just into this vibrating loose thing right now.
What exactly is "torque stripe"?
Old June 16th, 2009, 01:59 AM   #5
miks
I'm lovin' it.
miks's Avatar
Motorcycle(s): '09 Black 250R
Looks like someone needs to do some dumbbell curls!
Son: When I grow up I want to ride a motorbike.
Father: You can't do both son.
miks is offline   Reply With Quote
Old June 16th, 2009, 04:38 AM   #6
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
in a pinch back the screw part out, slip a short length of fishing line in the threaded hole, then tighten it back up. snip off any excess line and you have a cheap nylock nut.
Old June 16th, 2009, 05:04 AM   #7
HKr1
IC2(SW)
HKr1's Avatar
Old June 16th, 2009, 06:41 AM   #8
RSPILOT
RSPILOT's Avatar
Motorcycle(s): Too many. Some are in the house.
??? ---- "Pliers"
RSPILOT is offline   Reply With Quote
Old June 16th, 2009, 06:42 AM   #9
Duvivr6
Motorcycle(s): 09 Ninja 250R Special Ed
This happen to me to, So I took the bike from the dealer home on friday. Rode the weekend all good, got on my bike monday to go to work and the shifter fell of I'm like WTF
so I had to wait till tuesday for the shop to open and they gave me a new bolt put on some blue locktite on it and has been good eve since!
Duvivr6 is offline   Reply With Quote
Old June 16th, 2009, 10:46 AM   #10
lavid2002
lavid2002's Avatar
Motorcycle(s): None yet
Torque stripe is an adhesive that you apply to screws nuts bolts etc....It goes on in a line connecting the bolt and the nut for example. If the nut begins to move it becomes blatantly apparent because the line of "Torque stripe" will be broken, and it will not match up. Here
http://www.americanprecisionassembly..._resize200.JPG
Note the red line across the bolts. If the bolt begins to vibrate loose, the line of red adhesive will break and you can see its loosening.
-Dave
lavid2002 is offline   Reply With Quote
Shift Pedal Question Apex123 2008 - 2012 Ninja 250R Tech Talk 1 March 27th, 2015 03:44 PM
Short shift lever tie-rod? Yakaru 2013 - 2017 Ninja 300 Tech Talk 15 March 16th, 2014 01:14 PM
WTB Tie Rod for Shift Assembly TooNasty Items Wanted 0 May 15th, 2013 01:32 PM
Tie rod keeps coming off Xz1atl 2008 - 2012 Ninja 250R Tech Talk 7 January 10th, 2012 06:01 PM
Rubber piece on shift pedal CZroe 2008 - 2012 Ninja 250R Tech Talk 16 October 23rd, 2011 07:21 PM
