Old September 22nd, 2012, 03:25 PM   #1
rabies
time is running out....
rabies's Avatar
Motorcycle(s): pregen ninjari
magnetic tank bag and electronic devices
im about to make a small magnetic tank bag from a camera case and hardrive magnets.
but..if i put my droid or iphone or gps near it will it get wiped out?
id rather not "try" it to see what would happen..
anyone?
The King
rabies is offline   Reply With Quote
Old September 22nd, 2012, 03:27 PM   #2
Whiskey
It shouldn't do anything to them, but don't put your wallet with ATM card in it, anything with a magnetic strip could be affected.
Old September 22nd, 2012, 03:29 PM   #3
xSean13
xSean13's Avatar
I've never had stuff right up next to the magnets, but I keep my wallet (with cards in it), cell phone, and ipod in the side pouches, never have any issues.
Old September 22nd, 2012, 03:31 PM   #4
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Try not to put any CRT monitors in your bag. Also keep HDD's away
AFM #676
Supersports are for n00bs
Old September 22nd, 2012, 03:43 PM   #5
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
+1 Shouldn't be a problem.
Old September 22nd, 2012, 03:49 PM   #6
rabies
rabies's Avatar
werd. thanx fellas
The King
Old September 24th, 2012, 08:41 AM   #7
broilmebk
broilmebk's Avatar
Motorcycle(s): '12 ninja 250r
They did this on mythbusters. IIRC you have to have one strong a$$ magnet to wipe it.
broilmebk is offline   Reply With Quote
Old September 24th, 2012, 08:52 AM   #8
rabies
rabies's Avatar
i had one of those small card holders that ladies get in purses. i keep my liscense/debit card/insurance/and 2 biz cards.
it had a magnet it in it. when i put a hotel card in it, it would wipe out.
so i cut it and ripped the magnets out. makes a nice small wallet
The King
Old September 24th, 2012, 10:21 AM   #9
bfpower
ninjette.org mafioso
bfpower's Avatar
When I used to work IT support, people would regularly put fridge magnets on their steel computer cases. In some cases it caused serious issues (random rebooting, system errors).
It's a basic fact of physics that magnets induce current in an electrical circuit when they are moved in its vicinity. In addition, current does not flow normally through a magnetic field. Therefore, although some people do not experience problems when putting a computer near a magnet, some devices absolutely will not work properly.
The myth is that your data will be wiped. This isn't the problem (it won't be wiped; that really is a myth, unless you're dealing with an MRI machine or other large electromagnet). The actual issue is that a magnet has the potential to seriously screw up a device, especially if it's moving near the circuit board. It can induce levels of current that could be damaging to the device.
Still, if it's a weak enough magnet, I wouldn't worry too much. The rare earth magnets from hard drives are fairly strong for their size, but I don't think they're be too big a problem. If you start having issues with electronic devices stored in the tank bag, you might want to try another solution.
bfpower is offline   Reply With Quote
Old September 24th, 2012, 12:28 PM   #10
Whiskey
Didn't see that, but my mam had a bank card fail after she put it into a bag with a magnetic latch at the top.
If it's moved through the magnetic field it's likely to fail faster than if it's left in place afaik.
Old September 29th, 2012, 09:27 AM   #11
Some phones have magnetic relay switches to detect when they are in car docks versus home docks and other accessories or for telling when they are opened/closed without a mechanical switch. Magnets can cause havoc. If you find your battery half-dead because it kicked on in car nav mode where it was expected to be on charge, don't blame us.
Magnetic Tank Bag for 250R! ScorpionNinja Cargo Space 29 November 2nd, 2015 05:29 AM
[motorcycle.com] - Rapid Transit Recon 19L Magnetic Tank Bag Review Ninjette Newsbot Motorcycling News 0 July 1st, 2014 06:40 PM
[visordown.com] - Used: B-Square magnetic tank bag Ninjette Newsbot Motorcycling News 0 October 18th, 2013 07:50 PM
Magnetic vs Suction cup mounts for tank bag setasai Cargo Space 25 January 10th, 2012 06:41 PM
