Old May 10th, 2017, 03:27 AM   #1
matt021126
Motorcycle(s): 250
Trouble starting
So i took my 09 ninja out of storage to start and ran into a little trouble. Put the battery in and went to start it. First attempt turned over but didnt start. As i went to push the starter button a second time, i heard a click from behind the seat and all the dash lights went off and nothing happened. After about 5 seconds all the lights came back but as soon as i hit the starter the same thing happens. Any ideas as to what it could be or what to check? I did look at all the fuses and none looked burned out.
matt021126 is offline   Reply With Quote
Old May 10th, 2017, 05:43 AM   #2
taz
taz's Avatar
MOTM - May '17
Battery is bad/dead, charge it or get new one.
Old May 10th, 2017, 06:48 AM   #3
Battery sounds like the problem, but if you didn't add stabilizer to the gas and/or drain the carbs before storing that may not be the end of it.
Hopefully you did.
Old May 10th, 2017, 07:28 AM   #4
matt021126
Motorcycle(s): 250
Thanks. I will be checking the battery tonight. There was gas stabelizer in her so i should be fine on that front. The battery tested at 12.61v when not hooked up but i didnt get a chance to test it while in the bike
Old May 10th, 2017, 08:20 AM   #5
If that was right off the charger, it's a bit low. It should be over 13V initially, then drop to 12.7V (100% charged) and stay there.
The real test though is the voltage during cranking (under load). That should be over 10V and closer to 11. Chances are it will drop way off during cranking.
Most likely you will need a new battery, Charge it for a few hours at an appropriate rate before installing.
Old May 10th, 2017, 08:49 AM   #6
A sudden failure of power may mean a loose and/or corroded battery connection.
Old May 12th, 2017, 05:26 AM   #7
matt021126
Motorcycle(s): 250
Thanks guys. New battery, started right up
Trouble starting Wrestler174 1986 - 2007 Ninja 250R Tech Talk 1 June 14th, 2015 06:02 PM
Bike has trouble starting capriccio 2008 - 2012 Ninja 250R Tech Talk 7 July 19th, 2012 10:37 AM
Trouble with starting speed vmlp 1986 - 2007 Ninja 250R Tech Talk 13 May 26th, 2012 09:12 PM
Trouble Starting dlebe250 1986 - 2007 Ninja 250R Tech Talk 7 January 12th, 2011 07:47 AM
trouble starting... n4v1n 2008 - 2012 Ninja 250R Tech Talk 4 August 9th, 2009 03:18 PM
