Go Back   ninjette.org > 2018+ Ninja 400 > 2018+ Ninja 400 Tech Talk
Old May 13th, 2019, 01:15 PM   #1
Ninja 400 dyno - Kawasaki lied !!!
Here's dyno chart of Ninja 400 vs 300.
Note: power measured at rear wheel
Source: https://www.cycleworld.com/how-much-...ninja-400-make
So crank power is closer to 50bhp, not the 45 that Kawi claimed!!! Cheaterz!!!
Last futzed with by DannoXYZ; May 13th, 2019 at 04:27 PM.
Old May 13th, 2019, 03:51 PM   #2
Nice curves, thanks. Dynamometers are notoriously inaccurate though, with calibrations varying wildly. Unless someone who really knew what he was doing recently calibrated it, it could easily be off by that 10 percent.
It's the comparison between the 300 and the 400 done on the same machine at nearly the same time that's most interesting. I rode a 300 a few days ago on the Dragon. Based on your curves I bet a 400 would be a different animal altogether.
Old May 13th, 2019, 04:13 PM   #3
DynoJets have built-in weather stations that measure ambient temperature, humidity and altitude to make proper SAE corrections. But the nature of inertia dynos do tend to not be as accurate as steady-state eddy-current dyno.
The 300 graph does look slightly higher than others I've seen. Most significant though is with improvements in torque. HP's up +25%, however, torque is up +40% (which is really what accelerates)!
Old May 13th, 2019, 05:55 PM   #4
AwDang
Motorcycle(s): 286, 296, 599, 799
The 300 chart looks like my 8k mile street 300 on a Factory Pro dyno.
AwDang is offline   Reply With Quote
Old May 13th, 2019, 06:28 PM   #5
Ah, good to know we've got accurate 300 dyno chart as control. Thx!
Old May 16th, 2019, 06:00 PM   #6
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
I completely believe this. The EX500 was listed as 59hp, with numbers at the wheel in the low to mid 50s. The 400 feels only a bit slower to me (mostly in having more trouble trying to accelerate while in too high a gear). I'm sure the weight difference helps a bit too.
There are also apparently a number of tunes/setups used on the 400 for different countries' licensing regulations. I've seen something listing it as 48hp even.
Just for comparison, here's the 500. As others have stated, it's not a 100% accurate comparison because it wasn't done on the same dyno at the same time, but it gives a point of reference.
I'm still very happy with my purchase as a sidegrade from my 500. I'll occasionally feel like it doesn't have quite as much oomph (like I said, usually when I'm in the wrong gear - an easily remedied situation), but most of the time I'm thinking about how it's just as good as, or even better than, my modded 500. I can't wait to get some springs to match my weight (though they're much closer to correct than the 500's stock springs were).
Old May 16th, 2019, 08:14 PM   #7
Originally Posted by InvisiBill View Post
I'll occasionally feel like it doesn't have quite as much oomphl...
Oomph is overrated. Handling is what's important.
Old May 17th, 2019, 12:52 PM   #8
gantt
gantt's Avatar
Motorcycle(s): 2019 Ninja 400, Sold 2012 Ninja 650, Sold 2009 Ninja 250r, Sold 2007 DRZ400s
definitely.. my 650 never gave much confidence in the twisties. it had the power, but felt every bit as heavy as it was
gantt is offline   Reply With Quote
Old November 26th, 2019, 05:10 PM   #9
BretSV
Motorcycle(s): Shopping
Fast
BretSV is offline   Reply With Quote
[motorcycle.com] - 2018 Kawasaki Ninja 400: Exclusive Dyno Run and Measured Weight! Ninjette Newsbot 2018+ Ninja 400 General Discussion 44 February 23rd, 2018 02:52 PM
[visordown.com] - Kawasaki Ninja 400 debuts Ninjette Newsbot 2018+ Ninja 400 General Discussion 0 October 24th, 2017 09:10 PM
[visordown.com] - Kawasaki Ninja 400 – or is it a 420? Ninjette Newsbot 2018+ Ninja 400 General Discussion 0 July 28th, 2017 09:11 AM
[motorcyclistonline] - 2015 Yamaha YZF-R1 Dyno Run Video and Power Comparison | DYNO Ninjette Newsbot Motorcycling News 0 April 8th, 2015 03:00 PM
[motorcyclistonline] - 2015 Yamaha R3 Dyno Run Video and Power Comparison | DYNO TEST Ninjette Newsbot Motorcycling News 0 March 26th, 2015 12:40 PM
