Old February 20th, 2020, 09:05 PM   #1
woodchipliz
woodchipliz's Avatar
Motorcycle(s): 93 ex250
engine teardown - need advice.
So i got this bike for 400$, Once i got it started i noticed it burned antifreeze. I am hoping its just a head gasket. I took the motor out and removed the head. Is there a way to tell if the head gasket looks like it has been leaking?
Also 2 of the head bolts have some green discoloring.
woodchipliz is offline   Reply With Quote
Old February 20th, 2020, 09:48 PM   #2
cuong-nutz
cuong-nutz's Avatar
That middle bolt looks suspicious.
What reasoning made you think it was burning coolant? sweet smell and disappearing coolant?
Did you see any coolant building up anywhere when you were disassembling?
HalfFast Racing Team
Old February 21st, 2020, 08:59 AM   #3
woodchipliz
the exhaust was white and the coolant was very low
Old February 21st, 2020, 09:49 AM   #4
While steaming coolant out exhaust is typically sweet-smelling, burning coolant in combustion-chambers is extremely caustic and burns eyes.
Was there any coolant in either combustion-chamber sitting on top of pistons when you disassembled?
Did you do compression-test on engine before taking apart?
Old February 21st, 2020, 12:45 PM   #5
woodchipliz
it was sweet smelling, no antifreeze found anywhere. I dont have the tools for a compression test
i ordered a gasket for 35$ CAD it should arrive next week.
Old March 5th, 2020, 09:57 PM   #6
woodchipliz
So i replaced the cylinder base and head gaskets. That solved the issue.
Engine Teardown and Rebuild Rustitution 1986 - 2007 Ninja 250R Tech Talk 77 February 27th, 2017 09:17 PM
[topix.net] - Hitler's personal plane was powered by this US-designed engine [Engine Ninjette Newsbot Motorcycling News 0 June 14th, 2011 03:10 PM
[kropotkin thinks...] - Engine List From Sepang 2010 - Engine Penalties Loom Ninjette Newsbot Motorcycling News 0 October 13th, 2010 04:00 PM
