Old September 3rd, 2021, 02:55 PM   #1
The Toe Cutter
Motorcycle(s): 99 zrx1100, 03 Zx6r, 14 Ex300
2014 Clutch Issue
replaced the clutch and fibers and plates, followed service manual in putting back together. I also installed a oem cable. Clutch perch is good as well. I have been playing with the adjusters and still have a lot of slack. When I put the bike in gear the bike wants to take off even when the clutch lever is pulled. Any ideas what it is and how to resolve, have a track day coming up that I want to go to. TIA
The Toe Cutter is offline   Reply With Quote
Old September 3rd, 2021, 08:56 PM   #2
There are adjusters at both ends if cable.
Do you have them both adjusted for max tightness?
Post photos of each.
Old September 4th, 2021, 03:30 AM   #3
Ghostt
Ghostt's Avatar
Here is a great link, your welcome
https://faq.ninja250.org/wiki/Adjust...e_clutch_cable
violente et ignorantia
ZX-2R BLOG
Old September 4th, 2021, 06:54 AM   #4
pb3
Motorcycle(s): 09 n250, 14 n300, 22 n400
what began your clutch work- what was it doing? miles?
i'm searching for clutch issues too since my '14 w/ 7k miles began slipping recently for no obvious reason.
pb3 is offline   Reply With Quote
Old September 4th, 2021, 08:05 AM   #5
Ghostt
Ghostt's Avatar
Stupid question, what kind of oil did you put in last oil change?
ZX-2R BLOG
Old September 4th, 2021, 08:38 AM   #6
pb3
o/c april '21, m14t, half 10w40, 20w50. slip noticed 500 miles later.
during hard, wot, high rpm acceleration. slip occurred above 10k in 3rd 4th gear. was using clutch for upshifts.
oil mix not unusual. ran mcv 20w50 amsoil for an interval without noticing clutch difference.
after 2nd occurrence i have adjusted the shift lever, haven't had issue since but also haven't gone flat out again.
Old September 4th, 2021, 10:58 AM   #7
note he doesn't have issue with clutch slipping. It's not fully disengaging when lever is squeezed.
Originally Posted by The Toe Cutter View Post
Trying to figure out why the bike wants to go when I put in gear. Replaced oem cable, steels and fibers. adjusters have a ton of slack. any ideas?
If adjusters have slack, cable is way too loose and lever's not pulling cable enough. I usually have lower adjuster at maximum and fine-tune with lever adjuster. Usually want just 1-2mm free-play movement at lever itself.
Last futzed with by DannoXYZ; September 4th, 2021 at 12:49 PM.
Old September 4th, 2021, 03:25 PM   #8
Ghostt
Ghostt's Avatar
I have used Shell Rotella T6 in all bikes for many, many years now, and no issues whatsoever.
Or you might want to look at your clutch, steel plates, and friction plates, maybe the steel plates are glazed, and that's an easy and cheap fix.
ZX-2R BLOG
Old September 4th, 2021, 03:47 PM   #9
pb3's issue may be opposite of OP's, cable's too tight. Or clutch is just worn-out. Replace and use stiffer springs. No slippage issues with upgraded power or using "fuel-efficient" oils with friction-modifiers.
Old September 4th, 2021, 05:10 PM   #10
The Toe Cutter
Got it I think
So I figured it out. I went back into the clutch pack and noticed that the FACTORY SERVICE manual picture and written description was a bit misleading. In the attached pix, you think the arrow pointed towards "g" is towards the motor? Nope, they are on the end that the plate with springs goes to. So when you do your clutch replacement be mindful. Take the two fiber plate and metal plate that fits the plate that the springs go onto and they go on last.
Hope that is helpful, cant try the clutch at the moment due to this is a track bike conversion and the sun is set. Hopefully, tomorrow.
I just want to say thank for all the responses, you all are more helpful/responsive than some FB groups.
[motorcycle.com] - 2014 Ducati 1199 Superleggera Recalled for Clutch Issue Ninjette Newsbot Motorcycling News 0 June 20th, 2016 12:00 PM
Clutch Issue Help Please! R6 RandomPhantom General Motorcycling Discussion 13 March 21st, 2015 05:53 PM
Clutch issue ZX-Dominance 1986 - 2007 Ninja 250R Tech Talk 8 July 2nd, 2013 10:23 PM
Clutch issue? SON1C 1986 - 2007 Ninja 250R Tech Talk 9 May 9th, 2013 07:32 AM
Clutch Issue Shaol1n Monk 2008 - 2012 Ninja 250R Tech Talk 3 November 25th, 2011 09:22 PM
