Old May 10th, 2010, 05:59 PM   #1
WELLS
Motorcycle(s): 07 250R
carb sync
I went over other post and hope I'm not overlooking this. Is there any reason I can't use two vacuum gauges to sync my carbs?
Posted via Mobile Device
WELLS is offline   Reply With Quote
Old May 10th, 2010, 06:58 PM   #2
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
At a wild guess... because there's no guarantee the vacuum gauges are both calibrated in exactly the same way?
Ordinary manufacturing tolerances come into play here.
Simple physics will give greater precision, no?
Old May 11th, 2010, 04:56 AM   #3
VeX
That's me!
VeX's Avatar
Motorcycle(s): 2008 Ninja 250r (Tis blue), 2008 CBR600RR
Using vacuum gauges is a perfectly legitimate way of syncing carb's. Guys/girls with 4 cylinder bikes find that way especially easy and can sync their throttle bodies/carb's super quick.
VeX is offline   Reply With Quote
Old May 12th, 2010, 06:10 AM   #4
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Just verify the guages are equally calibrated
by switching the hoses and seeing if the readings follow the hoses or stay the same.
Old September 19th, 2013, 08:30 PM   #5
jmotocross1
Motorcycle(s): 07 R6, 08 ex250
Thanks
jmotocross1 is offline   Reply With Quote
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped menikmati Motorcycle-related 4 April 8th, 2020 12:39 AM
please help with carb sync gantt 2008 - 2012 Ninja 250R Tech Talk 30 August 23rd, 2017 09:31 PM
Valve adjustment, carb clean, carb sync? amad1972 1986 - 2007 Ninja 250R Tech Talk 2 July 29th, 2014 09:42 PM
Carb Sync Question cuz 2008 - 2012 Ninja 250R Tech Talk 2 October 28th, 2011 08:05 AM
Help please - carb sync? nixthewiz 2008 - 2012 Ninja 250R Tech Talk 4 September 7th, 2011 06:37 PM
