Old March 27th, 2011, 10:17 PM   #1
Yasko
Texas Newbie
Yasko's Avatar
Motorcycle(s): 07 Ninja EX250, 07 FZ6
Adjustable and Folding Levers for pre gens
The levers for the EX500 will fit my pre gen correct??? If so, I think I'll get a set from the2wheels... Anyone have these on their pre gen???
http://cgi.ebay.com/ebaymotors/Foldi...item43a454cd26
File Type: jpg Adjustable and Folding Levers for ninja 250r.JPG (59.6 KB, 17 views)
Yasko is offline   Reply With Quote
Old March 27th, 2011, 10:42 PM   #2
where did you get that info?
Old March 27th, 2011, 11:03 PM   #3
Yasko
Texas Newbie
Yasko's Avatar
I found it here at 250.org wiki
http://faq.ninja250.org/wiki/I_want_...6_brake_levers
Old March 27th, 2011, 11:08 PM   #4
If you can't find a good hand position via the clutch cable adjusters, then you can replace the perch and lever with an adjustable model. The easiest way is to stay with Kawasaki parts. You can install one from an EX500.
do you already have a clutch perch from an ex500?
Old March 27th, 2011, 11:10 PM   #5
Cuongism
Cuongism's Avatar
Not fully positive, but won't you still need a ex500 perch? The2wheels only sells the levers without the perch.
Edit: haha Kelly, you type too fast!
Old March 27th, 2011, 11:15 PM   #6
Yasko
Texas Newbie
Yasko's Avatar
I hope someone will tell me what I need to make this work... Anyone have them on their pre gen???
Old March 27th, 2011, 11:21 PM   #7
you would need a clutch perch from an ex500 to make these levers work on your ninja 250.
Old March 28th, 2011, 01:36 AM   #8
vince_2149
vince_2149's Avatar
Motorcycle(s): 2012 Ninja 250
I did the ex500 swap on my 250 and it was cake! I think I had a total of $80 into it including levers and the perch.
The brake lever swaps right over. And the perches are easy enough to swap. There's a bushing the original ex500 clutch lever comes with that you will need to put into the new clutch lever. You'll probably have to break off the old perch if you don't want to take off the bar ends/controls. Then the new one just bolts right into place. Here's what everything looked like:
Last futzed with by vince_2149; March 28th, 2011 at 02:49 PM.
vince_2149 is offline   Reply With Quote
Old March 28th, 2011, 09:05 AM   #9
Yasko
Texas Newbie
Yasko's Avatar
That looks very good... Where did you get the levers???
Old March 28th, 2011, 09:53 AM   #10
DaBlue1
DaBlue1's Avatar
The easiest way to make sure is to check cheap cycle parts (they cross reference their parts) and also email the2wheel. Someone else asked about new levers fitting on the New gens.
From what I can tell the levers offered by the2wheel that would fit the 2007 EX250 also fit; 87-91 EX500, 89-95 ZXR750, & 85-90 ZX600
Old March 28th, 2011, 02:47 PM   #11
vince_2149
vince_2149's Avatar
Thanks. I picked mine up from Auctmarts on ebay. They had the best deal ($60 shipped) at the time.
And I was wrong in my original post, the bushing you need to swap over is from the original ex500 clutch lever to the new clutch lever. That's why I bought the whole clip-on with everything on it.
Old March 28th, 2011, 07:08 PM   #12
Yasko
Texas Newbie
Yasko's Avatar
Fit without the EX500 perch???
Old March 28th, 2011, 07:19 PM   #13
DaBlue1
DaBlue1's Avatar
Yes. According to Cheap Cycle Parts, it's the same lever.
http://www.cheapcycleparts.com/produ...er-grip-clutch
http://www.cheapcycleparts.com/produ...ip-front-brake
Old March 28th, 2011, 07:34 PM   #14
Yasko
Texas Newbie
Yasko's Avatar
Thanks... I hope they work, I'll send an email to the2wheel to confirm...
Old March 29th, 2011, 09:26 AM   #15
Yasko
Texas Newbie
Yasko's Avatar
I got a reply from the2wheel...
"I'm sorry, the levers for your bike is not available right now."
I wanted those because they were extendable...
Old March 29th, 2011, 10:38 AM   #16
Jinx250
Smoker
Motorcycle(s): Guess....
The easiest way to do this (and the ONLY way for the clutch side) is buy the clutch perch for an EX500 (more recent the better, like 98 - 08). The brake lever fits fine. And don't get caught up in the model number game. The 06-08 Ninja 650 uses the same levers as the 98-08 500, so yo ucan also buy the clutch perch from an 06-08 650. So if the seller says the levers will fit an 06-08 (NOT 09-11) 650 then you're golden.
Jinx250 is offline   Reply With Quote
Old March 29th, 2011, 01:41 PM   #17
Yasko
Texas Newbie
Yasko's Avatar
Thanks...
Old March 30th, 2011, 09:28 PM   #18
Yasko
Texas Newbie
Yasko's Avatar
Will this work on my 07 ninja???
http://www.gdlcycles.com/asp1/modeta...temID=194-5273
If yes, what do I ask the2wheel for to fit after I get the new perch??? A setup for the ex500???
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
No mod needed for the brake side???
Thank you...
Old March 30th, 2011, 09:34 PM   #19
vince_2149
vince_2149's Avatar
You'll need the bushing that's in the original ex500 clutch lever. Otherwise the clutch lever will be extremely loose. It's loose as it is. That's why it's best to just buy the whole ex500 clutch setup as a unit so you save money. Not sure if the ex250 clutch bushing will work, didn't chance it when I did the conversion.
The brake just fits right on.
Old March 30th, 2011, 09:44 PM   #20
Yasko
Texas Newbie
Yasko's Avatar
When you say the whole setup??? This???
http://cgi.ebay.com/ebaymotors/2003-...item1c19aea108
Old March 31st, 2011, 12:32 AM   #21
vince_2149
vince_2149's Avatar
Precisely. Or something like what I was able to pick up for $20 that included the useless left clip-on, haha. Just whatever comes w/ the perch and lever and you can get the cheapest.
Old March 31st, 2011, 01:43 AM   #22
Yasko
Texas Newbie
Yasko's Avatar
Ok, I think I have all the info I need to get this done... You guys are a big help, I'll keep you posted...
I have to get my new tires mounted before I order the levers...
Old March 31st, 2011, 12:46 PM   #23
vince_2149
vince_2149's Avatar
If you run into any specific issues, just send me a pm and I'll try to help.
Old March 31st, 2011, 09:52 PM   #24
Yasko
Texas Newbie
Yasko's Avatar
Big 10-4 on that... Thanks
Old April 15th, 2011, 01:12 PM   #25
20ninja03
Motorcycle(s): 2003 Ninja 250
Those blue ones look sharp. May have to do this.
20ninja03 is offline   Reply With Quote
Old September 14th, 2011, 11:03 AM   #26
devmasa
devmasa's Avatar
Motorcycle(s): 2006 Yamaha R6, 2007 Ninja 250
vince..get you get the adjustable levers for the ex500 ?
Are these the ones you ordered :
http://cgi.ebay.com/ebaymotors/Clutc...item415b2be702
Please let me know
http://www.fuelly.com/sig-us/53284.png
devmasa is offline   Reply With Quote
Old September 15th, 2011, 12:05 AM   #27
vince_2149
vince_2149's Avatar
Please let me know
replied to your PM.
Old March 31st, 2012, 08:23 PM   #28
espacef1fan
Motorcycle(s): Suzuki TL1000R
So Ninja 650R Brake levers fit the 250 pregen master cylinder ?
Seems like that might be an easy find...
espacef1fan is offline   Reply With Quote
Old March 31st, 2012, 11:22 PM   #29
Vincent helped me make sure I get the right thing. You'll need an ex500 clutch perch, and then get levers for an ex500.
If you look at the parts diagrams, ninja 500's, concourses, and some ninja 600's use the same lever as the 250 on the brake side. Since those are for sure the same part, it makes more sense to buy levers that work with an ex500.
I bought an ex500 perch and some ex500 shorty levers from the2wheels. I'll post up some pictures once they're installed
Old April 1st, 2012, 09:12 AM   #30
espacef1fan
This is why I was asking about the Ninja 650 stuff. Plus it has more modern looking shiny levers instead of boring black levers...
Old April 1st, 2012, 09:17 AM   #31
plenty of options for shiny levers for the ninja 500R as well
Old April 1st, 2012, 12:08 PM   #32
espacef1fan
Not as cheap or as common as used 650 parts.. So I guess I'm back to where I started...
Old April 1st, 2012, 12:51 PM   #33
Very cheap. Very common. Check ebay. My perch was off an '08 and was $20 shipped. Even if you buy the perch new, it's only $40.
besides, there's more ex500's in existence than 650's. Therefore, more common and more available. Just check ebay. You'll find plenty of parts from both bikes for cheap. but it is KNOWN that the 500R brake lever works on the ex250, so that's why I suggested it.
Old April 1st, 2012, 04:04 PM   #34
espacef1fan
Just borrowed my buddies 650R for the afternoon....
I then borrowed his levers and stuff after that.
Guess what fits
so its confirmed...06-08 650R levers and perches fit!
Old April 1st, 2012, 08:12 PM   #35
Cool discovery!
Hows the clutch lever fit?
Old April 1st, 2012, 08:33 PM   #36
espacef1fan
You need the clutch lever perch just like with the EX500 stuff.
Old April 11th, 2012, 08:38 AM   #37
Jinx250
Smoker
Guess what fits
Actually, it was confirmed when I said it the first time, but I won't split hairs.
Old April 11th, 2012, 09:07 AM   #38
espacef1fan
I tried double confirming but I guess you arent on much( not that anything is wrong with that!!!!)
So I'll correct it...
it is DOUBLE confirmed that Ninja 650 levers fit(and look better that ex500 junk)
Old April 11th, 2012, 01:36 PM   #39
just wait till my shorties come in
Old May 12th, 2012, 10:15 PM   #40
Yasko
Texas Newbie
Yasko's Avatar
Photos please...
Adjustable and Folding Levers? lux 2008 - 2012 Ninja 250R Tech Talk 2 September 21st, 2010 08:58 AM
16 teeth front sprocket - fits pre-gens and new-gens Rayme Motorcycle-related 2 August 2nd, 2009 10:18 AM
