Old April 19th, 2012, 12:50 PM   #1
ProdigyRacingLA
ProdigyRacingLA's Avatar
Motorcycle(s): 2008 Ninja 250r Red
oil change question
So I changed my oil 2 days ago!
Used the correct oil and all of that, it runs like a dream and much better response when I open it up.
But I'm Not seeing the oil level on the engine gauge filling up.
It stills says there is the minimum amount of oil in there. I used 1.7 qts. And put in a new filter.
How long does it take for that guage to become accurate and show there is the right amount of oil in the engine?
Thnx in advance !
-P.R LA
ProdigyRacingLA is offline   Reply With Quote
Old April 19th, 2012, 12:54 PM   #2
gilmorec61
gilmorec61's Avatar
The bike should be off and level when you check it.
gilmorec61 is offline   Reply With Quote
Old April 19th, 2012, 12:57 PM   #3
Boom King
So, where's the reverse?
Boom King's Avatar
^^ Follow this. Also give it a bit of time for the oil to settle. After that, if it's still a little low, add a very small amount until it moves up the sight glass. Don't overfill! 1.7 qts is the stated amount as per the manual but I know it can slightly differ from bike to bike. Mine always takes slightly more.
Old April 19th, 2012, 01:03 PM   #4
Whiskey
I assume you mean the sight glass not the temp guage (which may or may not be on US models)
The bike should be left off for about 15 mins & be fully upright when you check the oil level, it takes time for the oil to drain back down into the sump after it's been running and the sight glass is only accurate when the bike is level.
AFAIK there's a kill switch that kicks in if there's too little oil (but the sensor threshold is very low)
Old April 19th, 2012, 01:55 PM   #5
ProdigyRacingLA
Thanks for the reply guys, and it is the sight glass. That's the correcy term I was looking for. I didn't know how else to call it besides a guage.haha
Well its been two days, and I did add a little extra oil over the 1.7. But ill level the bike and check again. Just thought it was odd.
Old April 19th, 2012, 05:54 PM   #6
Jono
Jono's Avatar
I didn't know they newgens require a different amount of oil than the pregen. On the pregen it is 1.6qt if you don't replace the filter and 2.0qt if you replace the filter. Soooo, you probably just need to add a little oil. Just add a bit, look in the site glass, and repeat until it is at the proper level.
Old April 19th, 2012, 06:36 PM   #7
capriccio
capriccio's Avatar
Did you check the oil level right after you turn off the engine or on kick stand ?
capriccio is offline   Reply With Quote
Old April 19th, 2012, 06:39 PM   #8
Ninja1
Ninja1's Avatar
According to the manuals the amounts of oil are:
1.3 L if you keep the filter
1.6 L if you change the filter
1.7 L if the engine is completely dry (not sure what it takes to completely dry the engine but that's what it says)
I changed the oil last Saturday and when I put the bike on rear stands the oil level was ok. I went for a spin and checked the oil again by "holding" the bike and it was not reliable because tilting 1-2 inches each way can change the oil level substantially.
Ninja1 is offline   Reply With Quote
Old April 19th, 2012, 06:46 PM   #9
capriccio
capriccio's Avatar
If you went out for a spin, the oil was in the engine. You will have to wait until it cool down and check again. But if you put 1.7 qt, I don't see a problem. As long as no leak !
Oil change question Mbomb 2008 - 2012 Ninja 250R Tech Talk 5 September 8th, 2012 12:08 AM
oil change - question! vmlp 1986 - 2007 Ninja 250R Tech Talk 5 June 5th, 2012 08:04 PM
Oil change question. Will this work? kaiserz 2008 - 2012 Ninja 250R Tech Talk 3 May 2nd, 2011 06:45 PM
I did my 1st oil change question! Duvivr6 2008 - 2012 Ninja 250R Tech Talk 19 July 7th, 2009 08:19 AM
Oil change question JCCJMM_ 1986 - 2007 Ninja 250R Tech Talk 4 December 4th, 2008 05:38 PM
