Old July 14th, 2010, 04:33 PM   #1
atl-ninja250
The Website Guy
atl-ninja250's Avatar
Motorcycle(s): 2009 Ninja 250R & 650R
Unhappy Shimmed the needles, running slower
Okay here's my situation. Brand new bikes, fully broken in...
Installed a roaring toyz (area p) exhaust and shimmed the needles.
Shimming washer used is 3mm and 1mm thick.
Now when I accelerate, its like I gotta give it full throttle for it to go anywhere! I'm all the way up to 5,000 rpms before i get moving fast enough...
what could be the problem guys??
atl-ninja250 is offline   Reply With Quote
Old July 14th, 2010, 04:48 PM   #2
how many washers did you use on each needle?
Old July 14th, 2010, 05:05 PM   #3
atl-ninja250
The Website Guy
just one washer on each... you think i need another?
Old July 14th, 2010, 05:09 PM   #4
http://www.ninjette.org/forums/showthread.php?t=9465
at least 2 or 3 with your present setup. I recommend pulling the snorkel out, too.
Old July 14th, 2010, 05:29 PM   #5
atl-ninja250
The Website Guy
okay, gonna add another to it. im not so sure about the snorkle mod... i think ill leave it in there.
but im definitely going to add another washer. if same problem after that, ill try another.
thanks for the info
Old July 14th, 2010, 05:32 PM   #6
let us know how it turns out... and be careful with those carb screws... they strip easily if you're not using a JIS screwdriver.
Old July 14th, 2010, 05:51 PM   #7
atl-ninja250
The Website Guy
haha i know! stripped em already and replaced em sons of beaches!
Old July 15th, 2010, 12:05 AM   #8
miks
I'm lovin' it.
miks's Avatar
Motorcycle(s): '09 Black 250R
Yank that damn snorkle out mate, its craaaaazy without it! Good luck buddy.
Son: When I grow up I want to ride a motorbike.
Father: You can't do both son.
miks is offline   Reply With Quote
Old July 17th, 2010, 08:00 AM   #9
atl-ninja250
The Website Guy
SOOOOOO.... guess what?!! LOL
I put 2 more washers (3 total) on both of my bikes and both are now running too rich!!!
AHHHHHH lol.... gotta do it all over again! guess only 2 will work!
Old July 17th, 2010, 01:43 PM   #10
headshrink
headshrink's Avatar
The washers most are using are actually 0.5mm thick. So unless that was a typo, you're raising your needles twice as much as you may think.
Old July 17th, 2010, 01:49 PM   #11
okay, but if the washers he is using are twice as thick, shouldn't the bike have run fine when he had one washer in there? ie... the same as 2x.5mm washers?
we need to see the washers you're using. pics, please?
Old July 17th, 2010, 03:17 PM   #12
headshrink
headshrink's Avatar
Absolutely.... I didn't read that closely, but I did want to make sure he was comparing "like kind," or was at least aware of the difference.
Old July 17th, 2010, 04:17 PM   #13
HKr1
IC2(SW)
HKr1's Avatar
Buy a nice exhaust..... then skimp out for washers, instead of a nice set of needles
Old July 18th, 2010, 09:34 AM   #14
atl-ninja250
The Website Guy
yeah you're right! they are a bit larger. but for some reason 1 washer was just too lean! and 3 was way too rich. so now ive got 2 on there and its running a tiny bit too rich but not enough to really notice. no backfiring, just a tiny tiny bit of slowed acceleration. im pretty tired after doing this 3 times on both bikes!
so .... ill search around for a .25 washer and replace one of the two 1mm washers on there now and it should be perfect. until then... relaxing time
thanks for the help guys!!!
Old July 18th, 2010, 10:38 AM   #15
Ken08Ninja
Motorcycle(s): 08 Ninja 250R Candy Plasma Blue
I used some 5x8x0.5MM Teflon washers from my RC monster truck. Your local hobby shop should have them in stock. They are TRAXXAS #1985.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJJ88
Ken08Ninja is offline   Reply With Quote
Old July 18th, 2010, 10:58 AM   #16
larger or thicker? any larger (overall diameter) and it can cause problems.
Old July 18th, 2010, 11:12 AM   #17
headshrink
headshrink's Avatar
0.5mm thickness is probably more common than 0.25mm. But as long as you know what you have, and are intentional about how much you are raising/lowering, you should be good. It takes several tries, as you are finding out. I'm on my twentieth, attempt to re-jet (probably more times than the average bear, but I'm chasing down some gremlins)!
Old July 18th, 2010, 07:03 PM   #18
atl-ninja250
The Website Guy
well the size is perfect, they are just 1mm thick. :S
i need to get some .25mm or .50mm washers. these are 1mm thick
Old July 18th, 2010, 08:08 PM   #19
bdavison
Wartown, USA
bdavison's Avatar
I really wish the exhaust manufacturers would stop telling people to shim the needles.
A carb doesnt just work off the main jet....a carb works in stages.
1. Idle to mid-range runs off the pilot jet.
2. Mid-range to WOT runs off the main jet.
There is overlap between each...for example once you hit mid-range, its going to being drawing fuel from both the pilot jet and the main jet.
Thats why shimming the needles is not the best way to do it, and the only correct way is by re-jetting the carb.
The needle you are shimming only richens the mixture once the bike enters the mid range. From idle to mid-range, the mixture is controlled by the pilot jet. Because of this...at your first 1/4 of throttle while the bike is pulling off the too small pilot jet...its starving for fuel and running lean until it gets to the point of pulling fuel from the main jet.
The correct way to fix this is to re-jet the pilot first, and THEN re-jet or shim the main.
Old July 18th, 2010, 08:47 PM   #20
lol... AFAIK, I've not heard of one manufacturer that recommends shimming... the idea to do so came from us.
what you state is almost all true, but when you compare the gain you get from just shimming for pennies vs $100 for a jet kit, can you see the attraction?
to get the jetting perfect, yes, nothing but a jet kit and time will do, but to gain 75% of what a jet kit does and for pennies, I think you'll have a hard sell to everyone that wants to overcome that lean spot on the bottom from the too lean pilot circuit from the manufacturer.
Old July 19th, 2010, 04:44 AM   #21
g21-30
g21-30's Avatar
Just thought I would post a refresher on carb tuning. kkim and I love posting the following pic:
The picture was found in the following article, which should be mandatory reading for anyone new to carb tuning:
http://www.gadgetjq.com/keihin_carb.htm
Old July 19th, 2010, 04:54 AM   #22
bdavison
Wartown, USA
bdavison's Avatar
Actually, that diagram is misleading...in reality, the pilot jet is working all the way to the 3/4 throttle mark, in somewhat of a sine wave. And the fact that it and the pilot screw get ignored by 90% of the garage tuners, is the reason for the myriad of poor results and lousy running engines.
Old July 19th, 2010, 05:03 AM   #23
g21-30
g21-30's Avatar
From the referenced article: "The primary purpose of the pilot system is to supply the mixture at idle. It continues to supply fuel throughout the entire throttle range, but after about 1/8 throttle is reached the MAIN SYSTEM starts to put out an increasing percentage of the total mixture up to full throttle."
Old July 19th, 2010, 07:51 AM   #24
atl-ninja250
The Website Guy
Not working 4 me ...
Old July 19th, 2010, 08:38 AM   #25
dubojr1
dubojr1's Avatar
Working fine for me with Internet Explorer 8.
Shimmed my needles, but didn't need to. peteypetepeep 2008 - 2012 Ninja 250R Tech Talk 11 April 10th, 2014 07:26 PM
So I shimmed the needles today... ChickenRun 2008 - 2012 Ninja 250R Tech Talk 6 August 25th, 2013 08:09 PM
Shimmed my needles and discovered something kaiserz 2008 - 2012 Ninja 250R Tech Talk 10 June 6th, 2011 06:36 PM
Shimmed Needles ? overload 2008 - 2012 Ninja 250R Tech Talk 5 October 26th, 2009 01:18 AM
I shimmed the needles and.... :( Gbug 2008 - 2012 Ninja 250R Tech Talk 12 January 25th, 2009 09:14 PM
