Old March 16th, 2009, 11:20 PM   #1
Gbug
Why the sucky gas mileage?
I'm running the stock exhaust, desnorkled, needles shimmed with one 4mm washer. For about the last 5 or 6 tanks, I'm only getting about 35 mpg. Sometimes a couple better/worse. I usually cruise on the highway at about an indicated 80mph. I'm geared +1, so that usually puts me at about 8-9k rpms. City driving is not really any better. In the city, I cruise anywhere from 5-8k rpm, and don't redline very often. I guess I can accept 45 mpg, but 35? It's a 250 for crying out loud! What gives?
Gbug is offline   Reply With Quote
Old March 16th, 2009, 11:26 PM   #2
Verus Cidere
Verus Cidere's Avatar
Motorcycle(s): '91 Honda CBR600 F2
Mine did that to me for a little while too. Don't quote me on this, 'cause I'm definitely not an expert, but you might try going a little bit lower in RPMs inside the city. There's not many places in my city where the speed limit goes above 45 mph. You should be able to hit that in 6th without going past 6k. I'd suggest getting up to 6th as soon as possible after getting going and staying there as long as possible. Also, don't keep the gas held for very long if you're coming up to a red light or stop sign. The longer you hold it, the more you use. I can't say for sure that's what was going on with mine, but I did notice a difference in gas mileage after trying the lower RPM trick (aka went from 40 to 55). Try it out.
Verus Cidere is offline   Reply With Quote
Old March 16th, 2009, 11:27 PM   #3
I've gotten as low as 33 mpg for a tank, but that's a tank that has been held at full throttle and high revs for the vast majority of the tank. With the usage you've described, I'd expect 40-45 on my bike, and I think I'm on the low end for fuel efficiency. Did you used to get significantly better mileage? Can you think of anything that may have changed that could be a contributing factor? How are you calculating your fuel mileage?
Old March 16th, 2009, 11:28 PM   #4
how are you calculating your gas mileage?
Old March 17th, 2009, 09:44 AM   #5
Nemy
Nemy's Avatar
Motorcycle(s): 2009 SE Ninja 250R
and how many clicks do you have on the bike? There've been reports that the ninjette doesn't have the best mileage during its early stages of life.
Nemy is offline   Reply With Quote
Old March 17th, 2009, 10:16 AM   #6
OldGuy
Live Life
OldGuy's Avatar
Motorcycle(s): 2009 Green SE Ninja 250
I may have a "non-conforming" Ninja but my first fill up yesterday after only 152 miles gave me 54.5 mpg. 25 of the first 50 miles were out on back roads varying the speed/rpm in all gears but never exceeding 6K or 55 mph. Rest of the miles are on my daily commute in town 8 miles each way.
- ATGATT -
Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots
OldGuy is offline   Reply With Quote
Old March 17th, 2009, 10:28 AM   #7
Gbug
How I calculate: Fill gas tank to full, reset trip. Next time I fill up to full, divide miles on trip by amount of gas I just put in.
Its an '08 with 7k miles on it. I bought the bike used, and only had it for a short while before I shimmed the needles. I think I got about 55 mpg before shimming. I started out with two washers per needle, but it bogged when I got above 10k rpm, so I cut it back to one per needle. Now it pulls great up to redline, so I don't think it's running rich. I went with 4mm washers cause I couldn't find 3mm ones anywhere. I don't think the 1mm difference is the problem though.
One other thing that might be the culprit. I noticed when I removed the washers that I had a slight tear around the edge of one of the rubber diaghram things that covers the carb. Is it possible that this could be jacking with my gas mileage?
Old March 17th, 2009, 11:05 AM   #8
That may have some bearing on the problem. how bad is the tear? they can be repaired, you know.
Old March 17th, 2009, 05:32 PM   #9
Gbug
Hmmm, how would I go about repairing it? I checked and its about $35 for a new one.
Old March 17th, 2009, 05:44 PM   #10
I've heard it's more like a hundred.
where is it $35?
Use a vinyl rubber repair kit like they have to repair tire tubes. You'll need a relatively light pice of rubber/vinyl to use as a patch.
For more info, PM member TheDuck as he is the only one I know of that has repaired a torn diaphragm.
Picture of the tear before you patch it once you're in there?
Old March 17th, 2009, 06:05 PM   #11
Gbug
Crap, I just double checked and its definetely about $100. I'll probably just try to repair it when I ever get around to it. And I'll be sure to snap a pic.
Gas Mileage: Beyond the Basics tnr4 General Motorcycling Discussion 39 July 28th, 2013 09:08 AM
Low Gas Mileage, why? Dhillon92 2008 - 2012 Ninja 250R Tech Talk 32 July 27th, 2013 04:51 PM
Poor Gas Mileage? Bones85 2008 - 2012 Ninja 250R Tech Talk 47 April 29th, 2013 01:54 AM
what's your worst gas mileage? boyonfire 1986 - 2007 Ninja 250R Tech Talk 24 October 25th, 2012 06:46 AM
gas mileage motorcycle_munge General Motorcycling Discussion 23 May 16th, 2009 01:54 PM
