February 24th, 2009, 08:39 PM | #1 |
TIP: How to keep track of loose vacuum hoses and wires during a DIY.
To start, my Ninja 250R is my first motorcycle. When I first started working on my bike most of the wires and hoses were unfamiliar to me, so I got into the habit of tying a piece of bright line to the hoses and wiring harnesses I disconnected while working on the bike, and then I left the other end hanging out of the frame.
I did this because if you start a project and need to walk away from it for a while it can be easy to forget to reconnect a hose or wire you had to remove, at least I did and it pissed me off when I had to take the fairings back off to find a loose vacuum hose. What I do now basically works like a bright "Remove Before Flight" ribbon on an aircraft, and if you see one of these sticking out while your bolting the bike back together you know you've missed something. I got a 250 foot spool of the line at Lowes for a couple bucks and it's the stuff you see being used to layout construction sites, usually sold in bright pink or orange for visibility. I also used it while aligning the rear tire with The String Method because it's easier to see and work with than fishing line. I thought I would share this after reading comments from other newer riders who worry about tearing into the bike and loosing track of their project, and also because of the occasional thread that starts "I'm in the middle of a DIY and I found loose hoses that I don't remember removing". (For those that don't know, some are vent lines and don't connect to anything.) Here's a few pics from my iPhone. There were a lot more of these hanging off my bike a few days ago because I had all of the wire harnesses disconnected while I took the airbox out, but I didn't think about taking pics until today: |
February 24th, 2009, 08:47 PM | #2 |
Great idea!
Now, put that tank that's lying on the concrete on a blanket or cloth so you don't end up chipping the paint... also, put something under the tank to raise one end so it doesn't rest on the fuel petcock. |
February 24th, 2009, 08:52 PM | #3 |
LOL, thanks I already did that. I carefully set it there for a second while my wife took my folding table, now it's resting in the shed on an old blanket.
February 24th, 2009, 09:03 PM | #4 |
do you have one end propped up so it's not resting on the petcock? The service manual specifically tells you not to rest the tank on it. I don't want to find out what happens if I don't.
The string idea will really come in handy for someone taking apart things for the first time. it is quite daunting to see all the loose hoses and wires when you dissect the bike to get that damned airbox out! |
February 24th, 2009, 09:18 PM | #5 |
Live Life
Join Date: Nov 2008 Motorcycle(s): 2009 Green SE Ninja 250 Posts: A lot.
Great idea Nate. Everyday there is another good tip that comes up on this site. I love it.
- ATGATT - Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots |
February 24th, 2009, 09:19 PM | #6 | |
February 25th, 2009, 02:12 AM | #7 |
That's me!
Join Date: Nov 2008 Motorcycle(s): 2008 Ninja 250r (Tis blue), 2008 CBR600RR Posts: 454
hehehehe THIS is the other forum you posted that on I see
Yeah you get quite a different response between the two forums eh? |
February 25th, 2009, 02:20 AM | #8 |
I'm lovin' it.
Join Date: Feb 2009 Motorcycle(s): '09 Black 250R Posts: A lot.
Great idea, would really help people who are new to motorbikes.
Son: When I grow up I want to ride a motorbike. Father: You can't do both son. |
March 31st, 2012, 08:08 PM | #9 |
Join Date: Mar 2012 Motorcycle(s): 2008 Ninja 250R Posts: 1
2008 Ninja 250 Carb Hose
So I have a 2008 ninja 250 and there is a T fitting connecting both of the carbs. My question is where does the hose that connects to that T fitting connect to?
Please anyone that knows. Thank You |
DIY- Removing the Kleen Air System Hoses and Plugging the Holes on a 08 250R | kkim | 2008 - 2012 Ninja 250R Tech Talk | 152 | March 15th, 2019 07:37 PM |
Loose vacuum line. Major backfire. | lockdun1 | 2008 - 2012 Ninja 250R Tech Talk | 4 | October 13th, 2014 01:33 PM |
Help with new bike - vacuum hoses | eric78 | 1986 - 2007 Ninja 250R Tech Talk | 1 | May 7th, 2014 09:16 PM |
Where do these vacuum hoses go? | blackss06 | 2008 - 2012 Ninja 250R Tech Talk | 2 | April 11th, 2014 03:42 AM |
Need help with vacuum hoses | Jordan91 | 2008 - 2012 Ninja 250R Tech Talk | 1 | December 25th, 2010 09:57 PM |
