Old October 3rd, 2014, 02:34 PM   #1
sailorninja
sailorninja's Avatar
Motorcycle(s): 2006 Kawasaki Ninja ex250
Vibration while idling.
Hello!
I've had some issues with my 2006 Ninja 250 as of recently, solved all of the other ones with a simple cleaning of the oil filter screen, change of filter and oil, however there is quite a bit of vibration in the front end while the bike is idling, any idea what this could be? I've googled a little but I'm going to be honest I have very little bike mechanic skills, any help welcome!!
sailorninja is offline   Reply With Quote
Old October 3rd, 2014, 03:15 PM   #2
sync the carbs
Old October 3rd, 2014, 05:06 PM   #3
sailorninja
sync the carbs
Is this difficult?
Like I said I basically have 0 mechanic skills with bikes...
Old October 3rd, 2014, 05:10 PM   #4
i would not call it difficult.
Old October 3rd, 2014, 06:46 PM   #5
sailorninja
Is it damaging to the bike? Leaving it as it is right now?
Old October 3rd, 2014, 06:58 PM   #6
maybe try running some seafoam in a tank of gas. it might help.
Old October 3rd, 2014, 06:58 PM   #7
why don't you take a video of it idling and post it here and we can give you a better answer?
Old October 3rd, 2014, 07:36 PM   #8
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Yeah, take a video of her idling. The worst part about working on carbs is getting the damn things out.
Be careful. Remember you are
invisible
Old October 3rd, 2014, 07:58 PM   #9
Originally Posted by sailorninja View Post
Is this difficult?
Carb sync how-to - http://faq.ninja250.org/wiki/How_do_...carburetors%3F
Old October 4th, 2014, 12:23 AM   #10
maybe its missing an engine bolt, or the frame is cracked. or maybe its only running on one cylinder
Old October 4th, 2014, 10:28 AM   #11
sailorninja
I actually can do this part!! When I first bought the bike, I had to take them out, the first time took forever and sucked but the other times wasn't as bad, ended up cleaning the carbs and the bike never had any other issues cold starting!
Originally Posted by jkv45 View Post
Thank you so much!!
I actually found out that the bolt on the bottom of the engine was half way out, due to a nut missing, I replaced it and it still does it, how would I check for cracks in the frame? I know I have to sound awfully dumb, but I am trying to learn at least!! haha
Old October 7th, 2014, 07:26 AM   #12
Rustitution
World Class Ninja
Rustitution's Avatar
Motorcycle(s): 2002 Ninja 250, 96 VFR750, 79 Yamaha XS1100 Special
+1 for the video as this could help us identify where to start.
Some simple things to test would be make sure you are getting a spark in both cylinders by using an inline spark tester.
Video Here
you could also pull the spark plugs and check for proper gap. 0.023 to 0.027 inch use a feeler guage
VIDEO HERE
Life is not a journey to the grave with the to arrive safely in one pretty and well preserved piece, but to skid across the line, thoroughly used up, worn out, leaking oil, shouting, GERONIMO!
Rustitution is offline   Reply With Quote
Old October 7th, 2014, 07:28 AM   #13
Rustitution
World Class Ninja
Just thinking of some super simple things to look at.
Old October 8th, 2014, 10:32 AM   #14
sailorninja
I'm actually trying to get the video to upload right now, the vibration isn't really shown in the video but the sound of the bike is weird.
It will only vibrate enough to show on video if I've been riding it for a while beforehand.
Old October 8th, 2014, 11:06 AM   #15
Rustitution
World Class Ninja
That's actually a good observation that is good to let us know. the vibration gets worse as the bike reaches operating temperature.
Old October 8th, 2014, 01:46 PM   #16
sailorninja
Only while sitting still/idling.
Old October 8th, 2014, 06:47 PM   #17
I'm guessing it's just not tuned properly and it's idling roughly.
A few things need to be right for it to idle smoothly. The idle speed needs to be set at 1300 hot, the idle mixture screws need to be set correctly (approximately 2 1/2 turns out), and the carbs need to be synced.
Old October 9th, 2014, 12:04 PM   #18
sailorninja
Well, I figured out the problem.
Vacuum leak from the hose.
I plugged it, put it on PRI and rode around a bit, ran perfectly as long as the hose is plugged.
The petcock nipple came out before, somehow forgot to mention that!
All ears for suggestions on how to fix this?
Last futzed with by sailorninja; October 9th, 2014 at 03:24 PM.
Idling on one cylinder? Compression? RBN 1986 - 2007 Ninja 250R Tech Talk 6 July 10th, 2013 02:06 PM
Is that a boat idling in the distance? Mista Bob The Ex-Ninjetters Lair 3 November 5th, 2012 01:06 PM
Engine shuts off when idling. AppleRings 1986 - 2007 Ninja 250R Tech Talk 5 September 6th, 2011 07:40 PM
Weird Idling? GottaLoveLucy 2008 - 2012 Ninja 250R Tech Talk 5 August 20th, 2011 06:43 PM
Idling around 2.5-3k - Should I bring it back? 2fiddy 2008 - 2012 Ninja 250R Tech Talk 17 June 1st, 2011 04:31 AM
