Old April 14th, 2021, 03:42 PM   #41
punishum808
punishum808's Avatar
Motorcycle(s): Suzuki JPN Katana 750 , 1994 Suzuki Pro Stock Motorcycle , 2001 Ninja 250
ALoooooHA,
So one of the things I did was fine tune the CV carbs, it already had a Jet Kit in it. The hard part was fine tuning the carbs for open use, no airbox or filters.
Last futzed with by punishum808; April 15th, 2021 at 01:11 PM.
punishum808 is offline   Reply With Quote
Old April 14th, 2021, 03:44 PM   #42
punishum808
*** It Was ALL in the Jetting ***
So I modified some cheap stacks to fit and got the mains situated and the needles height set, and man it worked GREAT, snappy all the way through, no stutter nothing.
Sorry, didn't remember to take video.
Last futzed with by punishum808; April 15th, 2021 at 01:12 PM.
Old April 14th, 2021, 03:50 PM   #43
punishum808
*** Couldn't Leave IT Alone, COULD YOU ***
So I knew a guy who raced drag bikes on the east coast and I remember years ago he had a set of nearly new CRs for the 250. I got ahold of him and he still had them.
Sold the GREAT running set of CVs and now got a set of shiny new CRs. Made a set of custom vel stacks to fit and then tried to get them to run. Damn thing was leaking like a sieve.
After several cleaning, dipping, retrying and still, gas everywhere. So I narrowed the problem down to the needle jets and possibly the O rings on the needle seats.
Waiting on parts now to solve that problem.
Old April 14th, 2021, 03:52 PM   #44
punishum808
*** Moving Onto Other Things ***
Found a pair of used rearsets, and got them fitted on.
It really changes the tuck factor nicely.
Old April 14th, 2021, 03:58 PM   #45
punishum808
*** Race Only ***
Because this bike will never see the street I am using a sequential shift light.
Old April 14th, 2021, 04:01 PM   #46
punishum808
*** More Weight Loss ***
So I got to remove the OEM gauge cluster and other unnecessary weight.
I also added in a separate water temp gauge as well and made a panel out of carbon fibre to hold it all on.
I also added on vinyl skin to protect the lcds from chips and damages.
Last futzed with by punishum808; April 15th, 2021 at 01:09 PM.
Old April 14th, 2021, 04:05 PM   #47
punishum808
*** Mahalo to Danno ***
Danno has been helping me offline and thanks to him I have now converted over the pregen suspension to a newgen with the 17 inch wheels both front and rear.
I also got another motor from a newgen that will be torn down and maxed out with +4 pistons, racecut trans, slipper clutch, cams ported head and oversized valves etc. In the end every nut and bolt will be titanium and carbon fiber wheels with race slicks, ti axles and swingarm pivot bolt as well etc. Goal is to get it as light as possible, hopefully in the 250 range, it is already down to 306 as it sits. As you can see price will be no object.
Waiting for the suspension from Thailand and will slowly have pics forthcoming.
So till next time Keep R off the street and on a track and 'Speed Safely' ALoooHA, Book UM DanO
Old April 15th, 2021, 10:08 AM   #48
Old April 15th, 2021, 01:08 PM   #49
punishum808
Originally Posted by Alex View Post
Mahalo Alex
Old June 4th, 2021, 02:13 PM   #50
punishum808
ALooooooHA,
Its been awhile but it has been trying to juggle so many projects at the same time.
So one of the challenges is a lot of part swapping or making parts so you can fit newgen on pregen for road racing.
So I got the newgen 17" wheels for a deal and swapped them on and the old arm and its adjustments left a lot to be desired.
Old June 4th, 2021, 02:15 PM   #51
punishum808
So thanks to Danno basically the newgen arm can swap onto the pregen chassis.
So that's what I did.
Old June 4th, 2021, 02:17 PM   #52
punishum808
I am happy to say after 22 years of being just a award winning Hawaii motorsports program PunishUM Motorsports will be on a national network in the 2nd quarter of 2022.
So we been busy gathering a lot of content.
This 250 build will be on the first seasons first episode.
Will keep everyone posted as to when that will be.
Old June 4th, 2021, 02:22 PM   #53
punishum808
That old crusty OEM shock was NO WAY this was staying in there.
Old June 4th, 2021, 02:24 PM   #54
punishum808
Nothing is always JUST A BOLT ON or IN when swapping out or upgrading.
The new rear shock was no exception. The banjo to the reservoir was not clearing the mount to secure the inner fender. Which also adds rigidity to the upper mount.
Old June 4th, 2021, 02:32 PM   #55
punishum808
So after that situation was remedied the install was a breeze.
Old June 4th, 2021, 02:33 PM   #56
punishum808
Also added in some adjustable dogbones as well.
Old June 4th, 2021, 02:36 PM   #57
punishum808
Another mod was adding a linear damper to the front end. As we all know there are no kits for pregen for this upgrade.
So after acquiring a universal unit I upgraded the bushings and made a mount to be able to get a linear damper to function on our project build.
Well that's it for now and until next time 'Keep it off the Street and on a Track' and 'SPEED SAFELY', ALooooooHA
Last futzed with by punishum808; June 4th, 2021 at 03:47 PM.
Old November 24th, 2021, 12:16 PM   #58
GXXRDRVR
Motorcycle(s): 2001 EX250R, 2005 ST1300
Subscribing to this thread. The amount of work and effort you are putting into this is amazing! Cant wait to see the final product!
GXXRDRVR is offline   Reply With Quote
Old November 29th, 2021, 08:19 PM   #59
punishum808
Mahalo, I got sidetracked and just ordered a prefab oil tray. The one I made didn't sit and look right. If anyone will be at PRI dm me and let me know.
ALooooooHA
Last futzed with by punishum808; January 22nd, 2022 at 11:30 AM.
Old January 22nd, 2022, 11:11 AM   #60
punishum808
ALoooooHA and Hauoli Makahiki Hou ( Happy New Year )
Its been awhile but a lot has been on the plate. A week after my last post I was off to PRI. PRI is the SEMA for the racing industry and it takes place in Indy.
Lots of meetings and connecting with existing sponsors and reaching out to new potential ones as my TV show heads on to Motortrend TV later this year where builds like this thread covers will be featured on the show and more in depth features will be on our Amazon Prime programming.
This also means connecting with folks like Farm and Azn for some projects we have going on in Hawaii that they will be involved with.
Old January 22nd, 2022, 11:15 AM   #61
punishum808
Soooo, after trying to fab a lower pan myself there were just fitment issues and tbh it just didn't look right so I got tired of wasting time trying to make it work.
I ordered a lower pan and although it is not application specific some massaging will be needed to make it fit and look like it belongs on this bike.
It took over a month before the part arrived and then the holidays thus the delay in getting more posts.
Old January 22nd, 2022, 11:24 AM   #62
punishum808
A 'BIG' Mahalo . . .
Thanks to my new friends from Rodio Racing they helped me out and sent me this for our 250 build.
Young Gus Rodio competes in the Moto America Jr Cup and this season he will also be aboard a Warhorse HSBK prepped Aprilla in the Twins Cup class as well.
Stay tuned as a lot of other parts are arriving this coming week and since the body work can move ahead we will proceed after to complete tear down, powder coating, paint, upgrading the brakes and a whole bunch more custom parts and pieces will be added.
So Till next time Y'all stay warm, 'Keep it off the Street and on a Track' and 'SPEED SAFELY' 'ALoooooooHA' fellow Ninjetters, Book UM Danno
Last futzed with by punishum808; January 27th, 2022 at 11:48 PM.
Old January 27th, 2022, 12:55 PM   #63
punishum808
*** Affordable Today ***
When i began racing in the 80s titanium parts were scarce and very expensive.
We called it 'Un-ob-tanium' back in the day. Now days it is not that much more than steel fasteners.
Will show the weight diff on a gram scale between the oem and the ti.
Titanium is also corrosion resistant which means they will look great for a long time, especially in the salty air enviro of the 808.
Stay tuned as builds like these will be showcased on PunishUM on Motortrend TV later this season.
So until next time 'Keep it off the Street and on a Track and SPEED SAFELY' ALooooooHA and Book UM Danno.
Old January 27th, 2022, 01:42 PM   #64
hi!!!
Coming along nicely!!!
Where'd you get those cool titanium tidbits?
Old January 27th, 2022, 11:46 PM   #65
punishum808
hi!!!
Aloha Danno, I can't recall specifically. There are so many different vendors on ebay. I just made a sheet with bolt size, thread pitch and hit search. From there you can specify length in the drop down as well as amount. The more you get the cheaper it becomes. Most won't ship to Hawaii but they will to the mainland so it will be easier for you.
Mahalo
Old January 28th, 2022, 07:37 PM   #66
Ceeloo Yello
Motorcycle(s): 250
Do you know if it will be on cable or streaming only?
Old January 29th, 2022, 01:24 AM   #67
punishum808
Cable and Amazon Prime. Thanks for asking. Mahalo 🤙🏽
Old January 31st, 2022, 05:59 PM   #68
Ceeloo Yello
Motorcycle(s): 250
Thanks for the info, will set my DVR when the time comes.
Old February 18th, 2022, 12:51 AM   #69
punishum808
*** Howzit Ninjetters ***
We had a lot of great weather recently so i have been diving into the body work.
Old February 18th, 2022, 12:56 AM   #70
punishum808
*** Morphing Fenders ***
It took two fenders from a pregen and a newgen to make one fender. Also had to use pieces from a car bumper cover to get the proper angles and stray pieces from other parts of the bike.
Cutting and splicing 24 pieces to be exact.
Old February 18th, 2022, 01:17 AM   #71
punishum808
*** Moseying Along ***
The various layers of body filler are being laid and shaped.
Will have everything 2K in the next week and will unveil a bunch of other pieces that will make this PunishUM 808 on Motortrend TV worthy.
Do things you ENJOY Everyday so there are 'No Weekends'
So till next time Ninjetters, Keep it off the Street and on a Track and 'Speed Safely', ALooooooHA, Book UM Danno.
Old February 28th, 2022, 09:16 AM   #72
punishum808
*** ALoooooHA ***
Sanding, lots and lots of sanding.
Til next time . . . 🤙🏽🍍🌴☀️
Old March 3rd, 2022, 09:20 AM   #73
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
Absolutely can't wait for the episode!
The Bike | The Truck
Old March 4th, 2022, 07:07 AM   #74
punishum808
ALooooHA,
As with any project challenges will always arise.
But it is a blessing when it makes itself known well before its all done and painted.
Mahalo
Last futzed with by punishum808; March 7th, 2022 at 10:19 AM.
Old March 9th, 2022, 12:07 AM   #75
punishum808
*** Got Wings? ***
ALoooooooHA
Old March 9th, 2022, 06:34 AM   #76
It's even got end-plate, cool!!! Never seen wings on Ninjette before, this should look awesome!!
Old March 9th, 2022, 11:58 PM   #77
punishum808
Mahalo Danno, there are 3 sets on each side. This is for a display bike for a major project coming up on Oahu.
I was supposed to lay 2K tmrw but things kept popping up. So hopefully by next week and I can tease some more pics.
Book UM Dannoooo
Old March 11th, 2022, 07:25 PM   #78
punishum808
*** Always Sumting ***
When things don't lineup you can either A) Ignore it and live with it or
B) You can Fix It which takes more time.
Like a doc having to rebreak a bone that didn't heal properly.
Till Next Time ALOoooooooHA
Old March 20th, 2022, 04:12 PM   #79
punishum808
It took a couple of xtra days to sort out the gap on the fairing.
Ready for a 2K Monday.
BTW this is oem pregen fairings.
Have a GREAT week errybody.
ALooooHA
Old March 26th, 2022, 09:48 PM   #80
punishum808
"A truly lucky man is one who knows what he wants to do in this world and that man will never work a day in his life."
- Carol Shelby
Have a GREAT Weekend Errrybody.
ALooooooooHA
[webbikeworld.com] - Harley-Davidson Announces New Parts for Customizing You Bike Ninjette Newsbot Motorcycling News 0 March 19th, 2020 07:30 AM
[motorcyclistonline] - Harley-Davidson Custom Kings Dealer Customizing Contest: Sport Ninjette Newsbot Motorcycling News 0 March 1st, 2016 10:21 AM
Customizing Accessories bbbrandy19 General Motorcycling Discussion 12 March 24th, 2011 10:13 AM
