Old August 8th, 2021, 01:52 PM   #1
The Toe Cutter
Motorcycle(s): 99 zrx1100, 03 Zx6r, 14 Ex300
ODB2 Scanner App
I have a 2013 Ninja 300 non abs. I just did the valve service, when everything was buttoned up and started. Bike sounds normal, no funny sounds, but service engine light is on. I connected my blue tooth odb2 scanner while using the Garage Pro app on my phone. It had Kawasaki listed as one of the vech it can scan. Scanned while motor was running, it came up with no codes found. Light is still on.
I am wondering if there is another app that I can use and see if there is an issue. This is being converted to a track bike, I do not have the turn signals on, would that cause the light to come on? Thanks for the info.
The Toe Cutter is offline   Reply With Quote
[webbikeworld.com] - HEX Code GS-911: A Scanner for Your BMW Bikes Ninjette Newsbot Motorcycling News 0 September 11th, 2020 08:21 AM
[RideApart] - Meet MotorScan: The Tiny OBD Scanner for Harley-Davidsons Ninjette Newsbot Motorcycling News 0 December 15th, 2017 08:21 PM
Need to use a Vehicle code scanner rojoracing53 Off-Topic 19 May 5th, 2013 07:55 PM
[superbikeplanet.com] - There's An App For That. WSBK iPhone App Debuts Ninjette Newsbot Motorcycling News 0 April 9th, 2010 07:30 AM
Hub/Printers/Scanner/Sword/GeForce/more Erin_S Miscellaneous 0 August 24th, 2009 06:32 AM
