Old May 25th, 2011, 06:56 PM   #1
2fiddy
2fiddy's Avatar
Motorcycle(s): 2010 Red Ninja 250r
Idling around 2.5-3k - Should I bring it back?
Hey guys. I bought my 2010 Ninja 250r from someone that bought the bike and then bought a house and couldn't afford both. The bike had 89 miles on it and was basically brand new. I had the 600 mile maintenance done to it and stuff and everything seemed to check out ok with the shop that did it.
I was hanging out with some people tonight and they work at a hardware shop and they work on motors and stuff and they were checking out the bike and they said that it seemed to be revving high, and also it was going up and down fluctuating a little almost as if I was giving a tiny bit of throttle. It will go from 2.5k to 3k. It happens a lot when stopping at a light or something it will stay at around 3k.
Let me assure you that they choke is not on.
I don't know a lot about motors and the bike is still under warranty so I just want to be sure that anything that could be wrong with it gets checked out before the warranty runs out.
So please give me your input and please no flaming.
2fiddy is offline   Reply With Quote
Old May 25th, 2011, 06:59 PM   #2
adjust the idle speed to 1500 rpm and then tell us how the bike runs then...
http://www.ninjette.org/forums/showp...55&postcount=5
Old May 25th, 2011, 07:07 PM   #3
red
Motorcycle(s): TR7, Trident, SuperIII, BMW, HD, Duc, Vespa, MP3
Maybe unrelated, but I had similar problems with a relatively new bike. Would return to idle veeery slowly and in general not run well at all in the lower rpms.
I ended up pulling carbs to check for clogged pilot jets but all seemed pretty clean. While the carbs were out I took the opportunity to reset the idle mixture and shim the needles while they were out.
The idle return thing turned out to be a misadjusted throttle return cable (idle cable) end at the carb end. It would sometimes bind and keep the throttle from returning properly as it was not seated squarely and the slack was misadjusted too loose from the factory, or it had slipped since delivery. All runs perfectly now.
I think idle speed (through the idle speed adjustment knob on the carb) should be set around 1300-1500 as most people do. You have checked that, right?
http://www.ninjette.org/forums/showthread.php?t=70526
2010 Ninja 250R SE - I got this bike for my wife. It was a good trade.
red is offline   Reply With Quote
Old May 25th, 2011, 07:53 PM   #4
2fiddy
2fiddy's Avatar
Should I bring this back to the shop that did my 600 maintenance since this should have been checked / adjusted?
Old May 25th, 2011, 07:57 PM   #5
have you read your owners manual? it tells you how to adjust you idle speed.... turn the knob and see if it fixes your problem.
Old May 25th, 2011, 08:09 PM   #6
2fiddy
2fiddy's Avatar
K. Is it really that easy?
Old May 25th, 2011, 08:12 PM   #7
did you read the link I posted in post #2?
Old May 25th, 2011, 08:21 PM   #8
2fiddy
2fiddy's Avatar
Yeah. I'll do it tomorrow and let you know how it goes.
Old May 25th, 2011, 08:28 PM   #9
okay... it may not solve all your problems, but it's a start to where we can figure out if you do in fact have other problems. The high idle may be masking it.
yes, the dealer should have set the idle, but really, there's no reason for it to change too drastically once it was set correctly. did it idle fine before the checkup?
Old May 25th, 2011, 09:39 PM   #10
2fiddy
2fiddy's Avatar
No it was high before the checkup.
Old May 26th, 2011, 05:47 AM   #11
2fiddy
2fiddy's Avatar
Ok, I adjusted the idle after riding to work this morning and it went down as you guys said. Is there anything I should look out for?
Also, the bike sounds a little more mean while revving now. Is this normal?
Old May 26th, 2011, 11:00 AM   #12
sounds normal to me. the ninjette loves to rev.
Old May 26th, 2011, 12:31 PM   #13
2fiddy
2fiddy's Avatar
Thank you for the help. It's not unnormal for the bike to spike sometimes with the idle (nothing drastic but the needle jumps a little)?
Old May 26th, 2011, 12:35 PM   #14
how much of a jump? (variations on the tach)
Old May 26th, 2011, 12:57 PM   #15
2fiddy
2fiddy's Avatar
Maybe 1350-1500 it'll fluctuate a little.
Old May 26th, 2011, 01:22 PM   #16
well, it should be rock steady, but many bikes vary like this. unless it's causing you ridability problems, it seems like your bike is fine.
get out there and put some miles on it.
have fun, ride safe
Old May 31st, 2011, 01:01 AM   #17
ratlab
ratlab
ratlab's Avatar
Motorcycle(s): gsxr1000,R3x2,RC390,FZ07,XR100
i rode mine from the dealer and noticed it was set for 3000 rpm-set it at 1200 with no problems so far -i have noticed on this forum that there are a lot of strange problems with these bikes i havn't encountered with other makes and models-should i get prepared for weirdness to come?
ratlab is offline   Reply With Quote
Old June 1st, 2011, 04:31 AM   #18
Mine fluctuates a bit. Many dealers assume it's a problem but they also forget that it's a carb'd bike just because it's sporty. I've heard others say that their dealers were insisting that there was a problem when it was just the bike's cold nature (take a while to warm up fully).
Anyway, your avatar is going to get you confused for phr3ek/Kevin. :P
[roadracingworld.com] - Local Government Guarantees Funding To Bring MotoGP Back To B Ninjette Newsbot Motorcycling News 0 August 18th, 2014 09:20 AM
[cyclenews.com] - MotoGP Editorial: Bring Back The War Ninjette Newsbot Motorcycling News 0 September 17th, 2013 01:40 PM
[cyclenews.com] - MotoGP Editorial: Bring Back The War Ninjette Newsbot Motorcycling News 0 September 17th, 2013 01:00 PM
Bring back 1989!! What has happened to the baby ninja? Brittas General Motorcycling Discussion 15 September 2nd, 2011 07:49 AM
[motorcyclistonline] - Red Bull Catalina Grand Prix to Bring Motorcycle Racing Back t Ninjette Newsbot Motorcycling News 0 November 9th, 2010 07:20 PM
