Old August 20th, 2011, 06:08 PM   #1
GottaLoveLucy
GottaLoveLucy's Avatar
Motorcycle(s): 2008 Ninja 250- Red (First Bike- aka Lucy)
Weird Idling?
Hey, so I have no previous motorcycle experience, other than seeing my BF's Honda 919 or his dad's BMW RF1000. My little ninja tends to need 5-10 minutes of idling before she'll rev. It sounds like it's idling very very slow for awhile before finally sounding normal. This is rather annoying when I just want to get going! The other bikes I've seen just start right up and go.
Is this normal for a ninja? I've got an appointment to get my valves adjusted next week. Is there anything that might cause this that I should ask them about?
(FYI she's a 2008 250r with ~20k miles)
GottaLoveLucy is offline   Reply With Quote
Old August 20th, 2011, 06:25 PM   #2
Kawinja
FNG
Motorcycle(s): 08 Kawi Ninja 250r
Do you turn on the choke to let it warm up first before you ride? because the 250's are fuel injected. They have to warm up first. but it shouldn't take that long!
Kawinja is offline   Reply With Quote
Old August 20th, 2011, 06:32 PM   #3
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
Actually the 250 is carbureted, not injected. That is why it has a choke and takes more time to warm up than an FI bike like a 919. Does its idle speed increase with the choke on? If not it might be out of adjustment. Also these bikes are lean, the choke richens the mixture to help with starting. There should be some threads here re the choke and jetting to make the bike run better. Depending on location and jetting 5 minutes is not extreme, 10 would indicate a problem
Old August 20th, 2011, 06:39 PM   #4
Kawinja
FNG
dang it my fast typing lol i meant to say "aren't lol not are) haha my bad. but should have been able to tell that from the context of the sentence
Old August 20th, 2011, 06:41 PM   #5
The trick is often to just get going. The bike warms up much better under a light load rather than sitting idling. Once it's running smoothly, even if it won't rev much, getting moving down the road (being careful with the clutch to not stall it), can be all it needs. Check out this thread on how different ninjette owners warm up their bikes:
http://www.ninjette.org/forums/showthread.php?t=77150
Old August 20th, 2011, 06:43 PM   #6
Then again some Euro and Canada models have FI. Some FI bikes (not the 250) have a fast idle knob or lever.
I think the OP should have the clutch cable checked when she brings it in for valves, it might be stretched and not working when she pulls the lever.
Vibration while idling. sailorninja 1986 - 2007 Ninja 250R Tech Talk 17 October 9th, 2014 12:04 PM
Idling on one cylinder? Compression? RBN 1986 - 2007 Ninja 250R Tech Talk 6 July 10th, 2013 02:06 PM
Is that a boat idling in the distance? Mista Bob The Ex-Ninjetters Lair 3 November 5th, 2012 01:06 PM
Engine shuts off when idling. AppleRings 1986 - 2007 Ninja 250R Tech Talk 5 September 6th, 2011 07:40 PM
Idling around 2.5-3k - Should I bring it back? 2fiddy 2008 - 2012 Ninja 250R Tech Talk 17 June 1st, 2011 04:31 AM
