Old July 6th, 2012, 01:54 PM   #1
FrankW
Motorcycle(s): ZRX1100 & Ninja 250
Fuel Petcock Leaking
Hi I am trying to get my new to me 03 250 going but noticed fuel leaking from the petcock. Any ideas on what could be causing this would be appreciated.
Thanks.
FrankW is offline   Reply With Quote
Old July 6th, 2012, 02:01 PM   #2
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Thanks.
Failed gasket would be my guess. A rebuild would be in order methinks...
Old July 6th, 2012, 04:21 PM   #3
FrankW
Thanks, what parts do you normally replace, is it o-ring and diaphragm ?
Old July 7th, 2012, 06:08 AM   #4
Where is it leaking from?
It can leak from the lever side or the side to which the hoses connect (diaphragm).
These are two systems in one: a two-way valve (handle lever) and a vacuum activated valve (diaphragm).
Old July 7th, 2012, 08:00 AM   #5
FrankW
Thanks Moto, Its leaking from the diaphragm side. going to pull it apart and inspect, anything special to look out for ?
Old July 7th, 2012, 12:19 PM   #6
Yes, be careful when you pull the plates apart, because the two neoprene diaphragms are very thin and delicate and can be broken even if they are in good shape (they are expensive).
Old July 7th, 2012, 12:50 PM   #7
FrugalNinja250
The diaphragm runs around $22 plus shipping from Ron Ayers http://www.ronayers.com/ProductDetails/N/687/SKU/594512
Another option would be to buy a used petcock in known good condition.
Old July 8th, 2012, 07:22 AM   #8
FrankW
Thanks guys, I will try and get around to it this weekend and see what I can find.
Old July 8th, 2012, 03:09 PM   #9
FrankW
Update. Pulled petcock apart and couldnt see anything with the naked eye so will go ahead and order new diaphragm unless I can find anyone here that may have a good used fuel petcock that they would like to sell.
Old July 8th, 2012, 04:19 PM   #10
FrugalNinja250
Might be a good idea to check for flatness of mating surfaces, if either half of the petcock assembly is warped then a new diaphragm may not stop the leak. I run pieces across a large mill file, it's really obvious if one part is warped significantly.
petcock leaking s3an78 1986 - 2007 Ninja 250R Tech Talk 15 August 18th, 2014 06:32 AM
fuel petcock Sebastian f7 1986 - 2007 Ninja 250R Tech Talk 2 July 13th, 2013 02:54 AM
Fuel Petcock Issue ans008 2008 - 2012 Ninja 250R Tech Talk 6 June 7th, 2013 07:14 PM
Leaking fuel from carbs haze5736 1986 - 2007 Ninja 250R Tech Talk 18 July 19th, 2011 07:34 AM
leaking petcock crackerjack 1986 - 2007 Ninja 250R Tech Talk 4 September 15th, 2010 11:47 AM
