Old June 16th, 2017, 07:07 PM   #1
scotty
scotty's Avatar
Motorcycle(s): Yahama v star 650 classic
Anyone own a Yamaha v star?
Working on my v star 650. I'm replacing the clutch. That's not the issue. The exhaust is.. I have to drop the exhaust on the front, but there isn't enough room to slide it off the bolts. It hits the frame. I manged to work the clutch cover off by loosening the exhaust, but going back on will be an issue.
Anyone know any tricks to get it off? Both the nuts came off with ease. Im not sure if the studs can come out or not.
Last futzed with by scotty; June 17th, 2017 at 12:19 PM.
scotty is offline   Reply With Quote
Old June 16th, 2017, 07:09 PM   #2
scotty
scotty's Avatar
The picture is horrible and sideways. The exhaust rest right above the frame. That's the lowest it'll go.
Old June 17th, 2017, 12:11 PM   #3
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
I've never heard of the Yahama. Is it a Barack Yahama?
Old June 17th, 2017, 12:19 PM   #4
scotty
scotty's Avatar
Total spell error! Haha yamaha....
Old June 17th, 2017, 03:23 PM   #5
Finesse
ran when parked
Finesse's Avatar
Motorcycle(s): Freeride 250R, KLX250SF, mopeds
MOTM - Sep '17, Dec '14
Is the heat shield of the exhaust what's hitting the frame? If so, take that off first. Take that off first anyway. Can you send a short video of the issue? I've worked on a lot of these @scotty
Finesse is offline   Reply With Quote
Old June 17th, 2017, 03:31 PM   #6
scotty
scotty's Avatar
Yes, the heat shield is off. If the studs on the exhaust were a just a hair shorter, I'd be good. I'll post a video and a few pictures tonight. I got my new clutch in the mail today so I would like to get it rolling. @Finesse
Old June 17th, 2017, 03:33 PM   #7
Finesse
ran when parked
Finesse's Avatar
sounds good I'll check back tonight. that stuff is infuriating. the v star 1100 you have to drop the exhaust to change the oil filter.
Old June 17th, 2017, 09:33 PM   #8
scotty
scotty's Avatar
You can see the exhaust is touching the frame and the other picture, you can see how much of the studs are still showing.
Old June 17th, 2017, 09:38 PM   #9
Finesse
ran when parked
Finesse's Avatar
@scotty try taking those allen bolts off the engine, I believe they are holding on fake engine cover type things. if that is the case it should give you the clearance you need
Old June 17th, 2017, 09:40 PM   #10
scotty
scotty's Avatar
Awesome! I shall give that a go! I got the clutch installed and ready to go. Just need the cover on now. I'll finish it tomorrow. Thanks again @Finesse
Old June 17th, 2017, 09:41 PM   #11
Finesse
ran when parked
Finesse's Avatar
no problem, let me know how it goes, I want to see if I was right... hahaha
Old June 22nd, 2017, 07:23 AM   #12
scotty
scotty's Avatar
Well, I wasn't able to remove the exhaust fully. I manged to persuade the exhaust down a bit more and was able to work the cover back on. It was a PIA, but it's done! Thanks again for the help @Finesse
Old June 22nd, 2017, 08:46 AM   #13
Finesse
ran when parked
Finesse's Avatar
[motorcycle.com] - Bell Helmets Shows Us Race Star and Pro Star Lids Ninjette Newsbot Motorcycling News 0 July 25th, 2016 04:10 PM
[speedTV.com] - BIKES: 2013 Star V Star 1300 Deluxe First Ride Ninjette Newsbot Motorcycling News 0 June 5th, 2013 10:20 AM
[topix.net] - Star Motorcycles V Star 1300 Deluxe First Ride Ninjette Newsbot Motorcycling News 0 March 6th, 2013 05:10 AM
[usridernews.com] - Yahama Takes Hard Hit Ninjette Newsbot Motorcycling News 0 August 12th, 2009 03:10 PM
[usridernews.com] - Star Motorcycles? V-Star 1300 chosen Best Motorcycle Value of 200 Ninjette Newsbot Motorcycling News 0 June 19th, 2008 04:30 AM
